تو کتابخانه MaterialIntroTutorialV2 زمان کامپایل کردن خطا میده؟؟؟ خود سورس را با آدرس پوشه support_23.2.1 در sdk و کتابخانه AppCompatLib v3.20 و کتابخانه MaterialIntro v2.00 رو هم زدم. اگر از ورژن ها نیست مشکل کجاست.
B4A version: 5.80
Parsing code. (0.00s)
Compiling code. (0.01s)
Compiling layouts code. (0.00s)
Generating R file. Error
res\values\theme.xml:3: error: Error retrieving parent for item: No resource found that matches the given name 'Theme.AppCompat.Light.DarkActionBar'.
res\values\theme.xml:6: error: Error: No resource found that matches the given name: attr 'colorAccent'.
res\values\theme.xml:4: error: Error: No resource found that matches the given name: attr 'colorPrimary'.
res\values\theme.xml:5: error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'.
res\values\theme.xml:8: error: Error: No resource found that matches the given name: attr 'windowActionBar'.
res\values\theme.xml:7: error: Error: No resource found that matches the given name: attr 'windowNoTitle'.
mobah 132
در سورس MaterialIntroTutorialV2 مشکل دارم
B4A version: 5.80 Parsing code. (0.00s) Compiling code. (0.01s) Compiling layouts code. (0.00s) Generating R file. Error res\values\theme.xml:3: error: Error retrieving parent for item: No resource found that matches the given name 'Theme.AppCompat.Light.DarkActionBar'. res\values\theme.xml:6: error: Error: No resource found that matches the given name: attr 'colorAccent'. res\values\theme.xml:4: error: Error: No resource found that matches the given name: attr 'colorPrimary'. res\values\theme.xml:5: error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'. res\values\theme.xml:8: error: Error: No resource found that matches the given name: attr 'windowActionBar'. res\values\theme.xml:7: error: Error: No resource found that matches the given name: attr 'windowNoTitle'.چطوری میشه حل کرد و باید چکار کنم.
