مشکل اینه وقتی برنامه باز میشه این اسپلش پشت منو تب هاست میاد
چرا؟
اینم کداش
Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim animation1 As Animation Private ImageView1 As ImageView Private TabHost1 As TabHostEnd Sub
Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: 'Activity.LoadLayout("Layout1") Activity.LoadLayout("w") animation1.InitializeAlpha("btnclikcanim",1,0) animation1.Duration = 50000 animation1.Start(ImageView1) Activity.Finish Activity.LoadLayout("q") TabHost1.AddTab("yek","m") TabHost1.AddTab("do","w") End Sub
Sub Activity_Resume End Sub
Sub btnclikcanim_AnimationEnd ImageView1.Visible = FalseEnd Sub
ali@ali 10
سلام خسته نباشید
من یه تب هاست دارمم و قبلس یه اسپلش گذاشتم...
چرا؟
اینم کداش
Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim animation1 As Animation Private ImageView1 As ImageView Private TabHost1 As TabHostEnd Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: 'Activity.LoadLayout("Layout1") Activity.LoadLayout("w") animation1.InitializeAlpha("btnclikcanim",1,0) animation1.Duration = 50000 animation1.Start(ImageView1) Activity.Finish Activity.LoadLayout("q") TabHost1.AddTab("yek","m") TabHost1.AddTab("do","w") End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub btnclikcanim_AnimationEnd ImageView1.Visible = FalseEnd Subلینک ارسال
