مشکل در ادرس لود صدا soundpool
mohammade79
سلام دوستان یه برنامه پیانو میسازم ک روی این دکنه ها کیلیک میکنی یه سری نت و اهنگ اجرا میشه رو هر دکمه ک میخوام وقتی روی دکمه اکورد زدم ادرس صدا ها عوض بشه که نمیشه همش یجور پخش میکنه این سورس کدامه
	 Dim piano_mp As SoundPool
	Type Point(Id As Int, prevX As Int, prevY As Int)
	Private list_TOUCHING, list_TOUCHED As List
	Dim G As Gestures
	Dim TouchMap As Map
	Dim pnl_keys(6) As Panel
	Private key1,key2,key3,key4,key5,key6 As Panel
	Dim ic As ICOSScaleAnimation
	Private Button1,Button2,Button3,Button4,Button5,Button6,Button7,Button8,Button9,Button10,Button11,button12 As Button
	Dim s As String
	Dim bt As BitmapDrawable
	Dim mc1,mc2,mc3 As MediaPlayer
	Private ImageView3 As ImageView
	Private Button16 As Button
	Private Button17 As Button
	Private Button18 As Button
	Dim sd As SDialog
	Dim baz As BazaarInstallerChecker
	Dim fad As ICOSFadeAnimation
	Dim str As String
	Dim phonewake As PhoneWakeState
	Dim sdlabel As Label
	phonewake.KeepAlive(True)
	Activity.LoadLayout("1")
	list_TOUCHING.Initialize
	list_TOUCHED.Initialize
	G.SetOnTouchListener(Activity, "GesturesTouch")
	TouchMap.Initialize
	loadsound
	setallpanels
	mc1.Initialize2("mc1")
	mc2.Initialize2("mc2")
	mc3.Initialize2("mc3")
	mc1.Load(File.DirAssets,"chord1.ogg")
	mc2.Load(File.DirAssets,"chord2.ogg")
	mc3.Load(File.DirAssets,"chord3.ogg")
	ImageView3.Visible=False
	Button16.Visible=False
	Button17.Visible=False
	Button18.Visible=False
Sub loadsound
	If piano_mp.IsInitialized = True Then Return
	piano_mp.Initialize(6)
	For i = 0 To pnl_keys.Length-1
		piano_mp.Load(File.DirAssets, "newsound/" & i & ".mp3")
Sub am
		piano_mp.Load(File.DirAssets,"am/" & i & ".mp3")
Sub bm
		piano_mp.Load(File.DirAssets,"bm/" & i & ".mp3")
Sub g1
		piano_mp.Load(File.DirAssets,"g/" & i & ".mp3")
Sub a
		piano_mp.Load(File.DirAssets,"a/" & i & ".mp3")
Sub e
		piano_mp.Load(File.DirAssets,"e/" & i & ".mp3")
Sub fm
		piano_mp.Load(File.DirAssets,"fm/" & i & ".mp3")
Sub f
		piano_mp.Load(File.DirAssets,"f/" & i & ".mp3")
Sub d
		piano_mp.Load(File.DirAssets,"d/" & i & ".mp3")
Sub c
		piano_mp.Load(File.DirAssets,"c/" & i & ".mp3")
Sub em
		piano_mp.Load(File.DirAssets,"em/" & i & ".mp3")
Sub setallpanels
	pnl_keys(0) = key1
	pnl_keys(1) = key2
	pnl_keys(2) = key3
	pnl_keys(3) = key4
	pnl_keys(4) = key5
	pnl_keys(5) = key6
Sub Activity_Resume
	setallkeystofalse
Sub setallkeystofalse
	list_TOUCHING.Clear
	list_TOUCHING.Clear
	TouchMap.Clear
	resetcolors
Sub resetcolors
Sub GesturesTouch(View As Object, PointerID As Int, Action As Int, X As Float, Y As Float) As Boolean
	Dim p As Point
	Select Action
		Case G.ACTION_DOWN, G.ACTION_POINTER_DOWN
			p.Id = PointerID
			TouchMap.Put(PointerID, p)
		Case G.ACTION_POINTER_UP
			TouchMap.Remove(PointerID)
		Case G.ACTION_UP
			setallkeystofalse
	End Select
	list_TOUCHING.Clear 'reset touching list
	For i = 0 To TouchMap.Size - 1
		Dim px, py As Int
		p = TouchMap.GetValueAt(i)
		px = G.GetX(p.id)
		py = G.GetY(p.id)
		For Each pnl As Panel In pnl_keys
			If px > pnl.Left And px < pnl.Left + pnl.Width Then
				If py > pnl.Top And py < pnl.Top + pnl.Height Then
					If pnl.Tag > 4 Then
						If list_TOUCHED.IndexOf("0") > -1 Or list_TOUCHED.IndexOf("1") > -1 Or  list_TOUCHED.IndexOf("2") > -1 Or list_TOUCHED.IndexOf("3") > -1 Or list_TOUCHED.IndexOf("4") > -1 Then
							If py < pnl_keys(0).Height Then
								If pnl.Tag = "5" Or pnl.Tag = "6" Then 'right side
								 	If px > (pnl.Left + pnl.Width) - (pnl_keys(0).Width / 2) Then Continue
								else if pnl.Tag = "6" Or pnl.Tag = "11" Then 'left side
									If px < pnl.Left + (pnl_keys(0).Width / 2) Then Continue
								else if pnl.tag = "6" Then
									'do nithing - full white key
									 If px > (pnl.Left + pnl.Width) - (pnl_keys(0).Width / 2) Or px < pnl.Left + (pnl_keys(0).Width / 2) Then Continue
					list_TOUCHING.Add(pnl.Tag)
					If list_TOUCHED.IndexOf(pnl.Tag) = -1 Then
						list_TOUCHED.Add(pnl.Tag)
						piano_mp.Play(pnl.Tag+1,1,1,1,0,1)
	resetcolors
	For i = 0 To list_TOUCHING.Size - 1
		Dim index As String = list_TOUCHING.Get(i)
		If index =0 Then
				ic.ScaleFromCenterToTopBottomBack("ic",250)
				ic.StartAnim(key1)
		If index =1 Then
				ic.StartAnim(key2)
		If index =2 Then
				ic.StartAnim(key3)
		If index =3 Then
				ic.StartAnim(key4)
		If index =4 Then
				ic.StartAnim(key5)
		If index =5 Then
				ic.StartAnim(key6)
	For i = (list_TOUCHED.Size-1) To 0 Step -1
		If list_TOUCHING.IndexOf(list_TOUCHED.Get(i)) = -1 Then list_TOUCHED.RemoveAt(i)
	Return True
Sub button1_click
	bt.Initialize(LoadBitmap(File.DirAssets,"am2.png"))
	Button1.Background = bt
		mc1.Play
		mc1.Looping=False
		bt.Initialize(LoadBitmap(File.DirAssets,"bm.png"))
		Button2.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"g1.png"))
		Button3.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"a.png"))
		Button4.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"e.png"))
		Button5.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"fm.png"))
		Button6.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"f.png"))
		Button7.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"d.png"))
		Button8.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"c.png"))
		Button9.Background = bt
		bt.Initialize(LoadBitmap(File.DirAssets,"em.png"))
		Button10.Background = bt
	'		am
Sub button2_click
	bt.Initialize(LoadBitmap(File.DirAssets,"bm1.png"))
	mc2.Play
		mc2.Looping=False
		bt.Initialize(LoadBitmap(File.DirAssets,"am1.png"))
		bm
Sub button3_click
	bt.Initialize(LoadBitmap(File.DirAssets,"g2.png"))
	mc3.Play
		mc3.Looping=False
		g1
Sub button4_click
	bt.Initialize(LoadBitmap(File.DirAssets,"a1.png"))
	mc1.Play
		mc1.Looping=False
	a
Sub button5_click
	bt.Initialize(LoadBitmap(File.DirAssets,"e1.png"))
	mc2.Play
		mc2.Looping=False
		e
Sub button6_click
	bt.Initialize(LoadBitmap(File.DirAssets,"fm1.png"))
	mc3.Play
		mc3.Looping=False
		fm
Sub button7_click
	bt.Initialize(LoadBitmap(File.DirAssets,"f1.png"))
	mc2.Play
		mc2.Looping=False
		f
Sub button8_click
	bt.Initialize(LoadBitmap(File.DirAssets,"d1.png"))
	mc1.Play
		mc1.Looping=False
		d
Sub button9_click
	bt.Initialize(LoadBitmap(File.DirAssets,"c1.png"))
	mc3.Play
		mc3.Looping=False
		c
Sub button10_click
bt.Initialize(LoadBitmap(File.DirAssets,"em1.png"))
	mc2.Play
		mc2.Looping=False
		em
Sub button11_click
	StartActivity(selectr)
	slide.SetAnimation("file3","file4")
Sub button12_click
	StartActivity(chords)
Sub button13_click
	StartActivity(help)
Sub button14_click
	fad.FadeIn("fad",500)
	fad.StartAnim(ImageView3)
	ImageView3.Visible=True
	Button16.Visible=True
	Button17.Visible=True
	Button18.Visible=True
Sub button16_click
	fad.FadeOut("fad",500)
	Activity.SetBackgroundImage(LoadBitmap(File.DirAssets,"main1.jpg"))
Sub button17_click
	Activity.SetBackgroundImage(LoadBitmap(File.DirAssets,"main2.jpg"))
Sub button18_click
