چه طوری میشه از یه اکتیویتی به ساب خاصی از اکتیویتی دیگه رفت؟
مثلا کدهای زیر رو درنظر بگیرید:
fasl1
Sub fasl1
Activity.LoadLayout("lbakhsh2")
tst = 1
If File.Exists(File.DirInternal , "etelaat.db") = False Then
File.Copy(File.DirAssets , "etelaat.db" , File.DirInternal , "etelaat.db")
Sql1.Initialize(File.DirInternal , "etelaat.db",True)
Dim stron As String
cur = Sql1.ExecQuery("SELECT * FROM etelaat Where Fasl = 1")
For i = 0 To cur.RowCount -1
cur.Position = i
stron = cur.GetString("Onvan")
ListView2.AddSingleLine2(stron, cur.GetInt("ID"))
ListView2.Height = 82.5416666666667%y
ListView2.ScrollingBackgroundColor = Colors.Transparent
ListView2.SingleLineLayout.Label.Height = 75dip
ListView2.SingleLineLayout.ItemHeight = 75dip
ListView2.SingleLineLayout.Label.TextColor = Colors.RGB(209,255,48)
ListView2.SingleLineLayout.Label.Gravity = Gravity.CENTER
ListView2.SingleLineLayout.Label.Typeface = Typeface.LoadFromAssets("sshiraz.ttf")
ListView2.SingleLineLayout.Label.TextSize = 17
Dim img As BitmapDrawable
img.Initialize (LoadBitmap(File.DirAssets , "bg-safar.png"))
ListView2.SingleLineLayout.Background = img
Sub Activity_Resume
Sub ListView2_ItemClick (Position As Int, Value As Object)
Activity.RemoveAllViews
zirbakhsh1
Sub zirbakhsh1
tst = 2
Activity.LoadLayout("lbakhsh1")
Dim stron As String
cur = Sql1.ExecQuery("SELECT * FROM etelaat where Zirbaxsh1 = 1")
cur.Position = i
ListView1.AddSingleLine2(stron,cur.GetInt("ID"))
ff = Position
zirbakhsh2
Sub zirbakhsh2
Activity.LoadLayout("lbakhsh4")
If ff = 0 Then
Main.bak = 40
Dim stron As String
cur = Sql1.ExecQuery("SELECT loqat,id FROM alefba1")
cur.Position = i
stron = cur.GetString("loqat")
ListView4.AddSingleLine2(stron,cur.GetInt("id"))
else If ff = 1 Then
Main.bak = 50
Activity.LoadLayout("lbakhsh3")
Dim stron As String
cur = Sql1.ExecQuery("SELECT [tedade horuf],id FROM alefba1 WHERE id BETWEEN 1 AND 15")
cur.Position = i
stron = cur.GetString("tedade horuf")
ListView3.AddSingleLine2(stron,cur.GetInt("id"))
می خوام وقتی دکمه بک گوشی رو زدم و به این اکتیویتی اومد به جای اجرای کدهای ساب fasl1
کدهای ساب zirbakhsh2 اجرا بشن. امیدوارم منظورم رو رسونده باشم.
arfan2x 15
سلام خدمت دوستان گرامی وقتتون بخیر.
Sub Activity_Create(FirstTime As Boolean) fasl1 End Sub Sub fasl1 Activity.LoadLayout("lbakhsh2") tst = 1 If File.Exists(File.DirInternal , "etelaat.db") = False Then File.Copy(File.DirAssets , "etelaat.db" , File.DirInternal , "etelaat.db") End If Sql1.Initialize(File.DirInternal , "etelaat.db",True) Dim stron As String cur = Sql1.ExecQuery("SELECT * FROM etelaat Where Fasl = 1") For i = 0 To cur.RowCount -1 cur.Position = i stron = cur.GetString("Onvan") ListView2.AddSingleLine2(stron, cur.GetInt("ID")) Next ListView2.Height = 82.5416666666667%y ListView2.ScrollingBackgroundColor = Colors.Transparent ListView2.SingleLineLayout.Label.Height = 75dip ListView2.SingleLineLayout.ItemHeight = 75dip ListView2.SingleLineLayout.Label.TextColor = Colors.RGB(209,255,48) ListView2.SingleLineLayout.Label.Gravity = Gravity.CENTER ListView2.SingleLineLayout.Label.Typeface = Typeface.LoadFromAssets("sshiraz.ttf") ListView2.SingleLineLayout.Label.TextSize = 17 Dim img As BitmapDrawable img.Initialize (LoadBitmap(File.DirAssets , "bg-safar.png")) ListView2.SingleLineLayout.Background = img End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub ListView2_ItemClick (Position As Int, Value As Object) Activity.RemoveAllViews zirbakhsh1 End Sub Sub zirbakhsh1 tst = 2 Activity.LoadLayout("lbakhsh1") Sql1.Initialize(File.DirInternal , "etelaat.db",True) Dim stron As String cur = Sql1.ExecQuery("SELECT * FROM etelaat where Zirbaxsh1 = 1") For i = 0 To cur.RowCount -1 cur.Position = i stron = cur.GetString("Onvan") ListView1.AddSingleLine2(stron,cur.GetInt("ID")) Next End Sub Sub ListView1_ItemClick (Position As Int, Value As Object) ff = Position Activity.RemoveAllViews zirbakhsh2 End Sub Sub zirbakhsh2 Activity.LoadLayout("lbakhsh4") If ff = 0 Then Main.bak = 40 Sql1.Initialize(File.DirInternal , "etelaat.db",True) Dim stron As String cur = Sql1.ExecQuery("SELECT loqat,id FROM alefba1") For i = 0 To cur.RowCount -1 cur.Position = i stron = cur.GetString("loqat") ListView4.AddSingleLine2(stron,cur.GetInt("id")) Next else If ff = 1 Then Main.bak = 50 Activity.LoadLayout("lbakhsh3") Dim stron As String cur = Sql1.ExecQuery("SELECT [tedade horuf],id FROM alefba1 WHERE id BETWEEN 1 AND 15") For i = 0 To cur.RowCount -1 cur.Position = i stron = cur.GetString("tedade horuf") ListView3.AddSingleLine2(stron,cur.GetInt("id")) Next End If End Subمی خوام وقتی دکمه بک گوشی رو زدم و به این اکتیویتی اومد به جای اجرای کدهای ساب fasl1
لطفاً کدهاش رو بنویسید. تشکر
