لود نشدن فایل های پوشه دیگر در soundpool
mohammade79
سلام عزیزان یه کد تار نوشتم که دقیقا کار میکنه به بهترین نحو ممکن با soundpool ولی با زدن دکمه های دیگر میخوام ادرس اهنگ ها رو عوض کنم که متاسفانه لود نمیکنه لطفا کمکم کنید .اقعا گیز کردم خیلی تو این انجمن کار راه انداختم لطفا یکی کمک کنه اگر بلده
 #Region  Project Attributes
	#ApplicationLabel: Guitar Irani Pro +
	#VersionCode: 1
	#VersionName: 1.0
	#SupportedOrientations: landscape
	#CanInstallToExternalStorage: true
	#AdditionalRes: ..\res
#End Region
#Region  Activity Attributes
	#FullScreen: true
	#IncludeTitle: False
#End Region
Sub Process_Globals
	 Dim piano_mp As SoundPool
	Type Point(Id As Int, prevX As Int, prevY As Int)
	Private list_TOUCHING, list_TOUCHED As List
	Dim G As Gestures
	Dim TouchMap As Map
	Dim pnl_keys(6) As Panel
	Private key1,key2,key3,key4,key5,key6 As Panel
	Dim ic As ICOSScaleAnimation
	Private Button1,Button2,Button3,Button4,Button5,Button6,Button7,Button8,Button9,Button10,Button11,button12 As Button
	Dim s As String
	Dim bt As BitmapDrawable
	Dim mc1,mc2,mc3 As MediaPlayer
	Private ImageView3 As ImageView
	Private Button16 As Button
	Private Button17 As Button
	Private Button18 As Button
	Dim sd As SDialog
	Dim baz As BazaarInstallerChecker
	Dim fad As ICOSFadeAnimation
	Dim str As String
	Dim phonewake As PhoneWakeState
	Dim sdlabel As Label
	Dim MyFade As splashfade
	Dim ShowSplashScreen As Boolean : ShowSplashScreen = True
	Dim MyPan As Panel
	Dim MyB As Button
	MyB.Initialize("MyB")
	MyPan.Initialize("MyPan")
	phonewake.KeepAlive(True)
	Activity.LoadLayout("1")
	If FirstTime Then
		If ShowSplashScreen = True Then
			Activity.AddView(MyPan, 0, 0, Activity.Width, Activity.Height) :
			If FirstTime Then
				MyFade.Initialize(Activity,Me,"splash1.jpg",Gravity.FILL,3000,100,"Left")
				MyPan.Visible = False
	DoEvents
	list_TOUCHING.Initialize
	list_TOUCHED.Initialize
	G.SetOnTouchListener(Activity, "GesturesTouch")
	TouchMap.Initialize
		loadsound
	setallpanels
Sub loadsound
	If piano_mp.IsInitialized = True Then Return
	piano_mp.Initialize(6)
	For i = 0 To pnl_keys.Length-1
		piano_mp.Load(File.DirAssets, "newsound/" & i & ".mp3")
Sub am
		piano_mp.Load(File.DirAssets,"am/" & i & ".mp3")
Sub setallpanels
	pnl_keys(0) = key1
	pnl_keys(1) = key2
	pnl_keys(2) = key3
	pnl_keys(3) = key4
	pnl_keys(4) = key5
	pnl_keys(5) = key6
Sub Activity_Resume
	setallkeystofalse
Sub setallkeystofalse
	list_TOUCHING.Clear
	list_TOUCHING.Clear
	TouchMap.Clear
	resetcolors
Sub resetcolors
Sub GesturesTouch(View As Object, PointerID As Int, Action As Int, X As Float, Y As Float) As Boolean
	Dim p As Point
	Select Action
		Case G.ACTION_DOWN, G.ACTION_POINTER_DOWN
			p.Id = PointerID
			TouchMap.Put(PointerID, p)
		Case G.ACTION_POINTER_UP
			TouchMap.Remove(PointerID)
		Case G.ACTION_UP
			setallkeystofalse
	End Select
	list_TOUCHING.Clear 'reset touching list
	For i = 0 To TouchMap.Size - 1
		Dim px, py As Int
		p = TouchMap.GetValueAt(i)
		px = G.GetX(p.id)
		py = G.GetY(p.id)
		For Each pnl As Panel In pnl_keys
			If px > pnl.Left And px < pnl.Left + pnl.Width Then
				If py > pnl.Top And py < pnl.Top + pnl.Height Then
					If pnl.Tag > 4 Then
						If list_TOUCHED.IndexOf("0") > -1 Or list_TOUCHED.IndexOf("1") > -1 Or  list_TOUCHED.IndexOf("2") > -1 Or list_TOUCHED.IndexOf("3") > -1 Or list_TOUCHED.IndexOf("4") > -1 Then
							If py < pnl_keys(0).Height Then
								If pnl.Tag = "5" Or pnl.Tag = "6" Then 'right side
								 	If px > (pnl.Left + pnl.Width) - (pnl_keys(0).Width / 2) Then Continue
								else if pnl.Tag = "6" Or pnl.Tag = "11" Then 'left side
									If px < pnl.Left + (pnl_keys(0).Width / 2) Then Continue
								else if pnl.tag = "6" Then
									'do nithing - full white key
									 If px > (pnl.Left + pnl.Width) - (pnl_keys(0).Width / 2) Or px < pnl.Left + (pnl_keys(0).Width / 2) Then Continue
					list_TOUCHING.Add(pnl.Tag)
					If list_TOUCHED.IndexOf(pnl.Tag) = -1 Then
						list_TOUCHED.Add(pnl.Tag)
						piano_mp.Play(pnl.Tag+1,1,1,1,0,1)
	resetcolors
	For i = 0 To list_TOUCHING.Size - 1
		Dim index As String = list_TOUCHING.Get(i)
	For i = (list_TOUCHED.Size-1) To 0 Step -1
		If list_TOUCHING.IndexOf(list_TOUCHED.Get(i)) = -1 Then list_TOUCHED.RemoveAt(i)
	Return True
Sub button1_click
		am
هر چی رو کلید ای ام میزنم بازم همون صدایی که اول ساختم رو لود میکنه فایل رو تغییر نمیده نمیدونم مشل چیع
کسی از این کد اطلاعاتی نداره دوستان؟
