سلام دوستان من اومدم یک تست بگیرم از برنامه ارور میده نمیدونم چیه راهنمایی کنید ممنون
E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.appfatim.ghadrnight, PID: 8779
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.appfatim.ghadrnight/com.appfatim.ghadrnight.MainActivity}: android.view.InflateException: Binary XML file line #43: Binary XML file line #43: Error inflating class android.support.v7.widget.AppCompatImageView
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3320)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3416)
at android.app.ActivityThread.access$1100(ActivityThread.java:230)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1822)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:7409)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1230)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1120)
Caused by: android.view.InflateException: Binary XML file line #43: Binary XML file line #43: Error inflating class android.support.v7.widget.AppCompatImageView
at android.view.LayoutInflater.inflate(LayoutInflater.java:551)
at android.view.LayoutInflater.inflate(LayoutInflater.java:429)
at android.view.LayoutInflater.inflate(LayoutInflater.java:380)
at android.support.v7.app.AppCompatDelegateImplV9.setContentView(AppCompatDelegateImplV9.java:288)
at android.support.v7.app.AppCompatActivity.setContentView(AppCompatActivity.java:143)
at com.appfatim.ghadrnight.MainActivity.onCreate(MainActivity.java:11)
at android.app.Activity.performCreate(Activity.java:6904)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1136)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3267)
Caused by: android.view.InflateException: Binary XML file line #43: Error inflating class android.support.v7.widget.AppCompatImageView
at android.view.LayoutInflater.createView(LayoutInflater.java:657)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:776)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:716)
at android.view.LayoutInflater.rInflate(LayoutInflater.java:847)
at android.view.LayoutInflater.rInflateChildren(LayoutInflater.java:810)
at android.view.LayoutInflater.inflate(LayoutInflater.java:527)
Caused by: java.lang.reflect.InvocationTargetException
at java.lang.reflect.Constructor.newInstance(Native Method)
at android.view.LayoutInflater.createView(LayoutInflater.java:631)
Caused by: java.lang.OutOfMemoryError: Failed to allocate a 226800012 byte allocation with 4194304 free bytes and 125MB until OOM
at dalvik.system.VMRuntime.newNonMovableArray(Native Method)
at android.graphics.BitmapFactory.nativeDecodeAsset(Native Method)
at android.graphics.BitmapFactory.decodeStream(BitmapFactory.java:856)
at android.graphics.BitmapFactory.decodeResourceStream(BitmapFactory.java:675)
at android.graphics.drawable.Drawable.createFromResourceStream(Drawable.java:2230)
at android.content.res.Resources.loadDrawableForCookie(Resources.java:4282)
at android.content.res.Resources.loadDrawable(Resources.java:4156)
at android.content.res.Resources.loadDrawable(Resources.java:4006)
at android.content.res.TypedArray.getDrawable(TypedArray.java:886)
at android.widget.ImageView.<init>(ImageView.java:157)
at android.widget.ImageView.<init>(ImageView.java:145)
at android.support.v7.widget.AppCompatImageView.<init>(AppCompatImageView.java:60)
at android.support.v7.widget.AppCompatImageView.<init>(AppCompatImageView.java:56)
Application terminated.
appfatim 21
ارور ها بالا هست لطفا راهنمایی کنید ممنون
