بروز مشکلات بعد از آپدیت SDK
Siaic
سلام دوستان من ویندوزم عوض کردم و نسخه 7.1 بیسیک نصب کردم
و بعد appcompat ورژن 3.42 معرفی کردم بهش و بدون مشکل هت
ولی زمانی که میخوام پروژه هایی که از قبل با sdk قدیمی و appcompat قدیمی run کنم خطاهای زیر رو میده:
B4A version: 7.01
Parsing code.    (0.05s)
Compiling code.    (0.25s)
ObfuscatorMap.txt file created in Objects folder.
Compiling layouts code.    (0.08s)
Organizing libraries.    (3.76s)
Generating R file.    Error
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:28: error: Attribute "title" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:29: error: Attribute "height" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:31: error: Attribute "isLightTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:43: error: Attribute "windowActionBar" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:46: error: Attribute "windowNoTitle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:51: error: Attribute "windowActionBarOverlay" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:55: error: Attribute "windowActionModeOverlay" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:60: error: Attribute "windowFixedWidthMajor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:64: error: Attribute "windowFixedHeightMinor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:69: error: Attribute "windowFixedWidthMinor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:73: error: Attribute "windowFixedHeightMajor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:79: error: Attribute "windowMinWidthMajor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:84: error: Attribute "windowMinWidthMinor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:94: error: Attribute "actionBarTabStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:95: error: Attribute "actionBarTabBarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:96: error: Attribute "actionBarTabTextStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:97: error: Attribute "actionOverflowButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:98: error: Attribute "actionOverflowMenuStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:101: error: Attribute "actionBarPopupTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:103: error: Attribute "actionBarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:108: error: Attribute "actionBarSplitStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:112: error: Attribute "actionBarTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:120: error: Attribute "actionBarWidgetTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:123: error: Attribute "actionBarSize" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:127: error: Attribute "actionBarDivider" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:129: error: Attribute "actionBarItemBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:132: error: Attribute "actionMenuTextAppearance" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:135: error: Attribute "actionMenuTextColor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:142: error: Attribute "actionModeStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:143: error: Attribute "actionModeCloseButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:145: error: Attribute "actionModeBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:147: error: Attribute "actionModeSplitBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:149: error: Attribute "actionModeCloseDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:151: error: Attribute "actionModeCutDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:153: error: Attribute "actionModeCopyDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:155: error: Attribute "actionModePasteDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:157: error: Attribute "actionModeSelectAllDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:159: error: Attribute "actionModeShareDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:161: error: Attribute "actionModeFindDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:163: error: Attribute "actionModeWebSearchDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:166: error: Attribute "actionModePopupWindowStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:174: error: Attribute "textAppearanceLargePopupMenu" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:176: error: Attribute "textAppearanceSmallPopupMenu" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:185: error: Attribute "dialogTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:187: error: Attribute "dialogPreferredPadding" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:189: error: Attribute "listDividerAlertDialog" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:197: error: Attribute "actionDropDownStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:199: error: Attribute "dropdownListPreferredItemHeight" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:201: error: Attribute "spinnerDropDownItemStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:203: error: Attribute "homeAsUpIndicator" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:206: error: Attribute "actionButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:209: error: Attribute "buttonBarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:211: error: Attribute "buttonBarButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:215: error: Attribute "selectableItemBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:217: error: Attribute "selectableItemBackgroundBorderless" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:219: error: Attribute "borderlessButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:221: error: Attribute "dividerVertical" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:223: error: Attribute "dividerHorizontal" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:225: error: Attribute "activityChooserViewStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:228: error: Attribute "toolbarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:230: error: Attribute "toolbarNavigationButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:233: error: Attribute "popupMenuStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:235: error: Attribute "popupWindowStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:238: error: Attribute "editTextColor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:240: error: Attribute "editTextBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:243: error: Attribute "imageButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:250: error: Attribute "textAppearanceSearchResultTitle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:252: error: Attribute "textAppearanceSearchResultSubtitle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:254: error: Attribute "textColorSearchUrl" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:256: error: Attribute "searchViewStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:264: error: Attribute "listPreferredItemHeight" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:266: error: Attribute "listPreferredItemHeightSmall" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:268: error: Attribute "listPreferredItemHeightLarge" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:271: error: Attribute "listPreferredItemPaddingLeft" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:273: error: Attribute "listPreferredItemPaddingRight" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:276: error: Attribute "dropDownListViewStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:277: error: Attribute "listPopupWindowStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:280: error: Attribute "textAppearanceListItem" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:282: error: Attribute "textAppearanceListItemSmall" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:291: error: Attribute "panelBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:293: error: Attribute "panelMenuListWidth" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:295: error: Attribute "panelMenuListTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:297: error: Attribute "listChoiceBackgroundIndicator" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:306: error: Attribute "colorPrimary" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:310: error: Attribute "colorPrimaryDark" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:314: error: Attribute "colorAccent" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:317: error: Attribute "colorControlNormal" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:320: error: Attribute "colorControlActivated" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:323: error: Attribute "colorControlHighlight" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:326: error: Attribute "colorButtonNormal" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:329: error: Attribute "colorSwitchThumbNormal" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:332: error: Attribute "controlBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:338: error: Attribute "alertDialogStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:339: error: Attribute "alertDialogButtonGroupStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:340: error: Attribute "alertDialogCenterButtons" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:342: error: Attribute "alertDialogTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:345: error: Attribute "textColorAlertDialogListItem" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:348: error: Attribute "buttonBarPositiveButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:351: error: Attribute "buttonBarNegativeButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:354: error: Attribute "buttonBarNeutralButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:362: error: Attribute "autoCompleteTextViewStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:364: error: Attribute "buttonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:366: error: Attribute "buttonStyleSmall" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:368: error: Attribute "checkboxStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:370: error: Attribute "checkedTextViewStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:372: error: Attribute "editTextStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:374: error: Attribute "radioButtonStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:376: error: Attribute "ratingBarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:378: error: Attribute "ratingBarStyleIndicator" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:380: error: Attribute "ratingBarStyleSmall" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:382: error: Attribute "seekBarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:384: error: Attribute "spinnerStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:386: error: Attribute "switchStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:402: error: Attribute "navigationMode" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:411: error: Attribute "displayOptions" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:423: error: Attribute "subtitle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:425: error: Attribute "titleTextStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:427: error: Attribute "subtitleTextStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:429: error: Attribute "icon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:431: error: Attribute "logo" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:433: error: Attribute "divider" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:435: error: Attribute "background" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:437: error: Attribute "backgroundStacked" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:439: error: Attribute "backgroundSplit" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:441: error: Attribute "customNavigationLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:445: error: Attribute "homeLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:447: error: Attribute "progressBarStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:449: error: Attribute "indeterminateProgressStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:451: error: Attribute "progressBarPadding" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:456: error: Attribute "itemPadding" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:458: error: Attribute "hideOnContentScroll" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:461: error: Attribute "contentInsetStart" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:464: error: Attribute "contentInsetEnd" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:467: error: Attribute "contentInsetLeft" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:470: error: Attribute "contentInsetRight" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:472: error: Attribute "elevation" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:475: error: Attribute "popupTheme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:499: error: Attribute "closeItemLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:504: error: Attribute "paddingStart" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:506: error: Attribute "paddingEnd" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:515: error: Attribute "theme" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:525: error: Attribute "backgroundTint" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:528: error: Attribute "backgroundTintMode" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:562: error: Attribute "preserveIconSpacing" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:644: error: Attribute "showAsAction" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:669: error: Attribute "actionLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:674: error: Attribute "actionViewClass" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:680: error: Attribute "actionProviderClass" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:699: error: Attribute "layout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:702: error: Attribute "iconifiedByDefault" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:706: error: Attribute "queryHint" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:709: error: Attribute "defaultQueryHint" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:715: error: Attribute "closeIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:717: error: Attribute "goIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:719: error: Attribute "searchIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:721: error: Attribute "searchHintIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:723: error: Attribute "voiceIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:725: error: Attribute "commitIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:727: error: Attribute "suggestionRowLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:729: error: Attribute "queryBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:731: error: Attribute "submitBackground" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:738: error: Attribute "initialActivityCount" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:745: error: Attribute "expandActivityOverflowButtonDrawable" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:750: error: Attribute "textAllCaps" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:777: error: Attribute "measureWithLargestChild" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:781: error: Attribute "showDividers" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:788: error: Attribute "dividerPadding" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:799: error: Attribute "titleTextAppearance" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:800: error: Attribute "subtitleTextAppearance" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:804: error: Attribute "titleMargins" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:805: error: Attribute "titleMarginStart" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:806: error: Attribute "titleMarginEnd" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:807: error: Attribute "titleMarginTop" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:808: error: Attribute "titleMarginBottom" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:813: error: Attribute "maxButtonHeight" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:815: error: Attribute "collapseIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:817: error: Attribute "collapseContentDescription" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:823: error: Attribute "navigationIcon" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:826: error: Attribute "navigationContentDescription" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:836: error: Attribute "logoDescription" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:838: error: Attribute "titleTextColor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:840: error: Attribute "subtitleTextColor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:845: error: Attribute "state_above_anchor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:857: error: Attribute "overlapAnchor" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:863: error: Attribute "color" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:865: error: Attribute "spinBars" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:867: error: Attribute "drawableSize" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:869: error: Attribute "gapBetweenBars" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:871: error: Attribute "arrowHeadLength" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:873: error: Attribute "arrowShaftLength" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:875: error: Attribute "barLength" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:877: error: Attribute "thickness" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:880: error: Attribute "drawerArrowStyle" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:895: error: Attribute "buttonTint" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:898: error: Attribute "buttonTintMode" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:920: error: Attribute "track" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:926: error: Attribute "thumbTextPadding" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:928: error: Attribute "switchTextAppearance" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:930: error: Attribute "switchMinWidth" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:932: error: Attribute "switchPadding" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:934: error: Attribute "splitTrack" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:936: error: Attribute "showText" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:954: error: Attribute "buttonPanelSideLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:955: error: Attribute "listLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:956: error: Attribute "multiChoiceItemLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:957: error: Attribute "singleChoiceItemLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:958: error: Attribute "listItemLayout" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:965: error: Attribute "allowStacking" has already been defined
e:\android\sdk\extras\android\support\v7\appcompat\res\values\attrs.xml:971: error: Attribute "srcCompat" has already been defined
E:\Android\Application\My app\قفل\srs\flhsiavash.dv1\new_v\v3.1\Objects\bin\extra\res2\res\values-v24\values-v24.xml:3: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
E:\Android\Application\My app\قفل\srs\flhsiavash.dv1\new_v\v3.1\Objects\bin\extra\res2\res\values-v24\values-v24.xml:4: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Colored'.
آدرس دهی ریسورس هام به شکل زیر:
#AdditionalRes: E:\Android\B4a\Basic4android\Libraries\b4a_appcompat2, de.amberhome.objects.appcompat
#AdditionalRes: E:\Android\Sdk\extras\android\support\v7\appcompat\res, android.support.v7.appcompat
#AdditionalRes: E:\Android\B4a\Basic4android\Libraries\additional_res\afollestad_material-dialogs\res
#AdditionalRes: E:\Android\Sdk\extras\android\support\design\res, android.support.design
#AdditionalRes: E:\Android\B4a\Basic4android\Libraries\md-app\res
#AdditionalRes: E:\Android\B4a\Basic4android\Libraries\md-lib\res
#AdditionalRes: E:\Android\Sdk\extras\android\support\v7\cardview\res
و تصاویری از SDK:
خب build-tools فقط 25.0.3 رو بزار بمون بقیه شونو پاک کن
تم رو هم از مانیفست بده
و ریسور هات هم اینارو پاک کن:
اینارو انجام بده نباید مشکلی پیش بیاد ولی اگه اروری بود بزار
خود android-support-v7  رو چک کردید؟
این مطالب رو هم بخونید!
در 45 دقیقه قبل، mamalliii گفته است :
ممنون از شما
build-tools 25.0.3 هست فقط بقیه پاک کردم
خطا زیر داد:
B4A version: 7.01
Parsing code.    (0.26s)
Compiling code.    (0.15s)
Compiling layouts code.    (0.03s)
Organizing libraries.    (0.00s)
Failed to generate resource table for split ''
e:\android\b4a\basic4android\libraries\additional_res\afollestad_material-dialogs\res\values-v11\styles.xml:16: error: Error: No resource found that matches the given name (at 'android:actionModeCloseDrawable' with value '@drawable/abc_ic_ab_back_mtrl_am_alpha').
ریسورس به شکل زیر شد:
#AdditionalRes: ..\resource
مانیفست به شکل زیر:
AddManifestText(
<uses-sdk android:minSdkVersion="14" android:targetSdkVersion="21"/>
    android:normalScreens="true"
    android:smallScreens="true"
    android:anyDensity="true"/>)
SetApplicationAttribute(android:theme, "@style/MyAppTheme")
و کدهای داخل ریسورس که کنار پروژه مربوط به رنگ ها و تم و...
<?xml version="1.0" encoding="utf-8"?>
<resources>
      <style name="MyAppTheme" parent="Theme.AppCompat.Light.NoActionBar">
        <item name="colorPrimary">#9c27b0</item>
        <item name="colorPrimaryDark">#7B1FA2</item>
        <item name="colorAccent">#9c27b0</item>
        <item name="android:windowNoTitle">true</item>
        <item name="windowActionBar">false</item>
   <item name="md_background_color">#9c27b0</item>
        By default, the title text color is derived from the
        ?android:textColorPrimary system attribute.
    <item name="md_title_color">#ffffff</item>
        By default, the content text color is derived from the
        ?android:textColorSecondary system attribute.
    <item name="md_content_color">#ffffff</item>
        By default, the positive action text color is derived
        from the colorAccent attribute of AppCompat or android:colorAccent
        attribute of the Material theme.
    <item name="md_positive_color">#2196f3</item>
        By default, the neutral action text color is derived
    <item name="md_neutral_color">#ffffff</item>
        By default, the negative action text color is derived
    <item name="md_negative_color">#ffffff</item>
        By default, a progress dialog's progress bar, check boxes, and radio buttons
        have a color that is derived from the colorAccent attribute of AppCompat or
        android:colorAccent attribute of the Material theme.
    <item name="md_widget_color">#ffffff</item>
        By default, the list item text color is black for the light
        theme and white for the dark theme.
    <item name="md_item_color">#ffffff</item>
        This overrides the color used for the top and bottom dividers used when
        content is scrollable
    <item name="md_divider_color">#ffffff</item>
        This sets the gravity used while displaying the dialog title, defaults to start.
        Can be start, center, or end.
    <item name="md_title_gravity">start</item>
        This sets the gravity used while displaying the dialog content, defaults to start.
    <item name="md_content_gravity">start</item>
        This sets the gravity used while displaying the list items (not including custom adapters), defaults to start.
    <item name="md_items_gravity">start</item>
        This sets the gravity used while displaying the dialog action buttons, defaults to start.
        START (Default)    Neutral     Negative    Positive
        CENTER:            Negative    Neutral     Positive
        END:               Positive    Negative    Neutral
    <item name="md_buttons_gravity">start</item>
        This sets the gravity used while displaying the stacked action buttons, defaults to end.
    <item name="md_btnstacked_gravity">end</item>
    </style>
</resources>
این 2 تا فرقشون چیه؟ ممکنه مشکل ساز بشه؟
تو پوشه ی پروژه  فولدری به اسم Resource داری؟ :| توش تم هست؟ اگه هست پاکش کن . هرچیزی میتونی تو پوشه ی resource بزاری ولی تم نباید باشه یعنی شاید پوشه ی Values رو لازم داشته باشی (برای فایل های دیگه) ولی فایل Themes.xml رو پاک کن
تم باید توی مانیفست باشه :
AddManifestText(
<uses-sdk android:minSdkVersion="14" android:targetSdkVersion="24"/>
  android:name=".Dex"
  android:configChanges="locale"/>)
'MaterialDrawerTheme
CreateResource(values, theme.xml,
<resources>
    <style name="MyAppTheme" parent="@style/Theme.AppCompat.Light.NoActionBar">
        <item name="colorPrimary">#03a9f4</item>
		<item name="colorPrimaryDark">#006CB7</item>
        <item name="colorAccent">#17B0F4</item>
        <item name="windowNoTitle">true</item>
    </style>
</resources>
این ریسورس رو هم پاک کن(فعلا با کتابخونه و کد هاش) :
ران بگیر
در ۱ ساعت قبل، mamalliii گفته است :
AddManifestText(
  android:name=".Dex"
<resources>
    </style>
</resources>
ران بگیر
با سلام آره اون پوشه Resource دارم که کدهای داخلشم فرستادم براتون،  برای تم و رنگ دیالوگ های متریال بود.
الان کلا اون پوشه Resource پاک کردم ، کتابخونه دیالوگ و ریسورسشم داخل کد غیرفعال کردم الان آدرس دهی ریسورس هام شده این:
کدهای مانیفست هم شده این، که از کدی که دادید عینا کپی گرفتم:
AddManifestText(
  android:name=".Dex"
<resources>
    </style>
</resources>
ولی باز ارور زیر میده:
B4A version: 7.01
Parsing code.    (0.17s)
Compiling code.    (0.14s)
Compiling layouts code.    (0.09s)
res\values\theme.xml:12: error: Error parsing XML: not well-formed (invalid token)
در 6 دقیقه قبل، Siaic گفته است :
B4A version: 7.01
خب شما وقتی کتابخونه ی afollestad message dialog و غیرفعال کردی باید ریسورس هاش رو هم برداری :|
در ضمن پوشه ی b4a_appcompat رو توی پوشه sdk یا پوشه ی پروژه نباید باشه
راستی نسخه Appcompat هم باید 3.42 یا 3.52 باشه
راستی اینو که داری؟؟
#Extends: android.support.v7.app.ActionBarActivity
شما بیا کلا یک پروژه جدید بزن! تم توی مانیفست بدون هیچ ریسورسی (فقط اون extend# که بالا دادم) کتابخونه Appcompat رو هم بزن یه تولبار هم بساز اگه مشکلی نداشت یعنی این پروژه تون ک الان روش کار می کنید مشکل داره. در
یک پروژه دیگه درست کردم یه اکشن بار گذاشتم و درست اجرا شد، حالا میخوام به متریال دیالوگ بزارم داخلش ولی ارور میده!
ببینید این کدهای برنامم و آدرس ریسورس:
#Extends: android.support.v7.app.AppCompatActivity
#AdditionalRes: E:\Android\B4a\Basic4android\Libraries\additional_res\afollestad_material-dialogs\res,com.afollestad.materialdialogs
	Activity.LoadLayout("11")
	Dim mdf As MD_BasicDialog
		mdf.Initialize("mdf")
			mdf.Show("...","....","...","","",Null,True,False)
این هم منیفست:
AddManifestText(
'End of default text.
<resources>
        <item name="colorPrimary">#FF9800</item>
        <item name="colorPrimaryDark">#F57C00</item>
        <item name="colorAccent">#FFA726</item>
    </style>
</resources>
ارور زیر میده بهم:
B4A version: 7.01
Parsing code.    (0.01s)
Compiling code.    (0.08s)
Compiling layouts code.    (0.00s)
فکر کنم مشکل از آدرس دهی ریسورس در ضمن من نمیدونم باید برای متریال دیالوگ حتما رنگ و ... تعیین کنم یا خودش یه مقدار پیشفرض داره (یادم رفته) چون قبلا یه پوشه ریسورس کنار برنامم میزاشتم و داخلش رنگ متن و دکمه ها تعیین میکردم ولی الان این کار نکردم...
ورژن متریال دیالوگ 0.74
ورژن اپکامپت 3.4.2
از پلتفرم 25 هم دارم استفاده میکنم
من الان برای خودمم تمام کتابخونه های متریال به درستی اجرا میشه به جز همین متریال دیالوگ
شما مشکل اصلیت (پست اول) حل شده و اگه سوال دیگه ای داری باید یک تاپیک دیگه بزنی!
موفق باشی
