Private Panel1 As Panel
Activity.LoadLayout("1")
Dim Panel2 As Panel
Panel2.Initialize("")
Panel2.RemoveAllViews
Panel2.AddView(Panel1,0,0,Panel1.Width,Panel1.Height)
خطای زیر رو میده
Error occurred on line: 37 (Main)
java.lang.IllegalStateException: The specified child already has a parent. You must call removeView() on the child's parent first.
at android.view.ViewGroup.addViewInner(ViewGroup.java:4311)
at android.view.ViewGroup.addView(ViewGroup.java:4147)
at android.view.ViewGroup.addView(ViewGroup.java:4119)
at anywheresoftware.b4a.objects.PanelWrapper.AddView(PanelWrapper.java:65)
at anywheresoftware.b4a.shell.Shell.runVoidMethod(Shell.java:755)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:345)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:249)
bahman2012 13
سلام مشکل کد زیر چیه که خطا میده
Sub Globals Private Panel1 As Panel End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("1") Dim Panel2 As Panel Panel2.Initialize("") Panel2.RemoveAllViews Panel2.AddView(Panel1,0,0,Panel1.Width,Panel1.Height) End Subخطای زیر رو میده
Error occurred on line: 37 (Main) java.lang.IllegalStateException: The specified child already has a parent. You must call removeView() on the child's parent first. at android.view.ViewGroup.addViewInner(ViewGroup.java:4311) at android.view.ViewGroup.addView(ViewGroup.java:4147) at android.view.ViewGroup.addView(ViewGroup.java:4119) at anywheresoftware.b4a.objects.PanelWrapper.AddView(PanelWrapper.java:65) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.shell.Shell.runVoidMethod(Shell.java:755) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:345) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:249) at java.lang.reflect.Method.invoke(Native Method)لینک ارسال
