با سلام من هرچی سرچ کردم نتونستم یک چیزی برای درست کردن یک سرچ برای دیتابیس 1000تایی پیدا کنم
کد نوشتم معمولی ارور داد
ScrollView1.Panel.RemoveAllViews
top = ScrollView1.Height - ScrollView1.Height + 2%y
ScrollView1.ScrollPosition = top
'cur = sql.ExecQuery("Select * From Matn Where Matn Like '%" & EditText1.Text & "%'")
'cur = Main.SQL.ExecQuery("SELECT * FROM Matn WHERE Titr LIKE '"&EditText1.Text&"%' ")
' cur = Main.SQL.ExecQuery("SELECT Titr,Favo FROM MatnWHERE Titr ='"& Value &"'")
cur=sql.ExecQuery("SELECT * FROM Matn WHERE Titr Like '%"&EditText1.Text&"%' OR Matn Like '%"&EditText1.Text&"%' ")
For i = 0 To cur.RowCount -1
cur.Position = i
Dim pnl As Panel
pnl.Initialize("")
ScrollView1.Panel.AddView(pnl,2%x,top,96%x,30%y)
pnl.LoadLayout("multi")
anim.InitializeScaleCenter("scale",0,0,1,1,Panel1)
anim.Duration = 1000
anim.Start(Panel1)
Label1.Text = cur.GetString("Titr")
Label1.Tag = cur.GetString("id")
Label1.Typeface = ACTMENU.typ
Label1.TextSize = 20
Label1.TextColor = Colors.Black
top = top + 15%y
ScrollView1.Panel.Height = top + 3%y
cur.Close
HAMEDDDR 15
ScrollView1.Panel.RemoveAllViews top = ScrollView1.Height - ScrollView1.Height + 2%y ScrollView1.ScrollPosition = top 'cur = sql.ExecQuery("Select * From Matn Where Matn Like '%" & EditText1.Text & "%'") 'cur = Main.SQL.ExecQuery("SELECT * FROM Matn WHERE Titr LIKE '"&EditText1.Text&"%' ") ' cur = Main.SQL.ExecQuery("SELECT Titr,Favo FROM MatnWHERE Titr ='"& Value &"'") cur=sql.ExecQuery("SELECT * FROM Matn WHERE Titr Like '%"&EditText1.Text&"%' OR Matn Like '%"&EditText1.Text&"%' ") For i = 0 To cur.RowCount -1 cur.Position = i Dim pnl As Panel pnl.Initialize("") ScrollView1.Panel.AddView(pnl,2%x,top,96%x,30%y) pnl.LoadLayout("multi") anim.InitializeScaleCenter("scale",0,0,1,1,Panel1) anim.Duration = 1000 anim.Start(Panel1) Label1.Text = cur.GetString("Titr") Label1.Tag = cur.GetString("id") Label1.Typeface = ACTMENU.typ Label1.TextSize = 20 Label1.TextColor = Colors.Black top = top + 15%y ScrollView1.Panel.Height = top + 3%y Next cur.Close
ولی وقتی سرچ میکنم هنگ میکنه دستگاه
