نو پروژه وقتی از کد زیر برای انیمیشن جابجایی بین صفحات استفاده کنیم همچین خطایی میده
Sub SetAnimation(InAnimation As String, OutAnimation As String)
Dim r As Reflector
Dim package As String
Dim In, out As Int
package = r.GetStaticField("anywheresoftware.b4a.BA", "packageName")
In = r.GetStaticField(package & ".R$anim", InAnimation) 'اینجا رو خطا میده 'اینجا رو خطا میده 'اینجا رو خطا میده 'اینجا رو خطا میده
out = r.GetStaticField(package & ".R$anim", OutAnimation)
r.Target = r.GetActivity
r.RunMethod4("overridePendingTransition", Array As Object(In, out), Array As String("java.lang.int", "java.lang.int"))
خطاش هم اینه
Error occurred on line: 122 (Main)
java.lang.ClassNotFoundException: com.Bahman.SECR.TrafficControl.R$anim
at java.lang.Class.classForName(Native Method)
at java.lang.Class.forName(Class.java:324)
at java.lang.Class.forName(Class.java:285)
at anywheresoftware.b4a.agraham.reflection.Reflection.GetStaticField(Reflection.java:365)
at com.Bahman.SECR.TrafficControl.main._setanimation(main.java:571)
at com.Bahman.SECR.TrafficControl.main._passet_textchanged(main.java:532)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:710)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:339)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:249)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:139)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:170)
at anywheresoftware.b4a.objects.EditTextWrapper$1.afterTextChanged(EditTextWrapper.java:83)
at android.widget.TextView.sendAfterTextChanged(TextView.java:8270)
at android.widget.TextView$ChangeWatcher.afterTextChanged(TextView.java:10534)
at android.text.SpannableStringBuilder.sendAfterTextChanged(SpannableStringBuilder.java:1043)
at android.text.SpannableStringBuilder.replace(SpannableStringBuilder.java:560)
at android.text.SpannableStringBuilder.replace(SpannableStringBuilder.java:492)
at android.text.SpannableStringBuilder.replace(SpannableStringBuilder.java:34)
at android.text.method.NumberKeyListener.onKeyDown(NumberKeyListener.java:121)
at android.widget.TextView.doKeyDown(TextView.java:6323)
at android.widget.TextView.onKeyDown(TextView.java:6136)
at android.view.KeyEvent.dispatch(KeyEvent.java:2641)
at android.view.View.dispatchKeyEvent(View.java:9237)
at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640)
at com.android.internal.policy.PhoneWindow$DecorView.superDispatchKeyEvent(PhoneWindow.java:2437)
at com.android.internal.policy.PhoneWindow.superDispatchKeyEvent(PhoneWindow.java:1746)
at android.app.Activity.dispatchKeyEvent(Activity.java:2730)
at com.android.internal.policy.PhoneWindow$DecorView.dispatchKeyEvent(PhoneWindow.java:2352)
at android.view.ViewRootImpl$ViewPostImeInputStage.processKeyEvent(ViewRootImpl.java:4206)
at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:4168)
at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:3682)
at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:3735)
at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:3701)
at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:3709)
at android.view.ViewRootImpl$AsyncInputStage.forward(ViewRootImpl.java:3828)
at android.view.ViewRootImpl$AsyncInputStage.apply(ViewRootImpl.java:3885)
at android.view.ViewRootImpl.deliverInputEvent(ViewRootImpl.java:6001)
at android.view.ViewRootImpl.doProcessInputEvents(ViewRootImpl.java:5975)
at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:5936)
at android.view.ViewRootImpl$ViewRootHandler.handleMessage(ViewRootImpl.java
Message longer than Log limit (4000). Message was truncated.
** Activity (main) Pause, UserClosed = true **
bahman2012 13
Sub SetAnimation(InAnimation As String, OutAnimation As String) Dim r As Reflector Dim package As String Dim In, out As Int package = r.GetStaticField("anywheresoftware.b4a.BA", "packageName") In = r.GetStaticField(package & ".R$anim", InAnimation) 'اینجا رو خطا میده 'اینجا رو خطا میده 'اینجا رو خطا میده 'اینجا رو خطا میده out = r.GetStaticField(package & ".R$anim", OutAnimation) r.Target = r.GetActivity r.RunMethod4("overridePendingTransition", Array As Object(In, out), Array As String("java.lang.int", "java.lang.int")) End Sub
خطاش هم اینه
Error occurred on line: 122 (Main) java.lang.ClassNotFoundException: com.Bahman.SECR.TrafficControl.R$anim at java.lang.Class.classForName(Native Method) at java.lang.Class.forName(Class.java:324) at java.lang.Class.forName(Class.java:285) at anywheresoftware.b4a.agraham.reflection.Reflection.GetStaticField(Reflection.java:365) at com.Bahman.SECR.TrafficControl.main._setanimation(main.java:571) at com.Bahman.SECR.TrafficControl.main._passet_textchanged(main.java:532) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:710) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:339) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:249) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:139) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:170) at anywheresoftware.b4a.objects.EditTextWrapper$1.afterTextChanged(EditTextWrapper.java:83) at android.widget.TextView.sendAfterTextChanged(TextView.java:8270) at android.widget.TextView$ChangeWatcher.afterTextChanged(TextView.java:10534) at android.text.SpannableStringBuilder.sendAfterTextChanged(SpannableStringBuilder.java:1043) at android.text.SpannableStringBuilder.replace(SpannableStringBuilder.java:560) at android.text.SpannableStringBuilder.replace(SpannableStringBuilder.java:492) at android.text.SpannableStringBuilder.replace(SpannableStringBuilder.java:34) at android.text.method.NumberKeyListener.onKeyDown(NumberKeyListener.java:121) at android.widget.TextView.doKeyDown(TextView.java:6323) at android.widget.TextView.onKeyDown(TextView.java:6136) at android.view.KeyEvent.dispatch(KeyEvent.java:2641) at android.view.View.dispatchKeyEvent(View.java:9237) at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640) at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640) at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640) at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640) at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640) at android.view.ViewGroup.dispatchKeyEvent(ViewGroup.java:1640) at com.android.internal.policy.PhoneWindow$DecorView.superDispatchKeyEvent(PhoneWindow.java:2437) at com.android.internal.policy.PhoneWindow.superDispatchKeyEvent(PhoneWindow.java:1746) at android.app.Activity.dispatchKeyEvent(Activity.java:2730) at com.android.internal.policy.PhoneWindow$DecorView.dispatchKeyEvent(PhoneWindow.java:2352) at android.view.ViewRootImpl$ViewPostImeInputStage.processKeyEvent(ViewRootImpl.java:4206) at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:4168) at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:3682) at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:3735) at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:3701) at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:3709) at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:3682) at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:3735) at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:3701) at android.view.ViewRootImpl$AsyncInputStage.forward(ViewRootImpl.java:3828) at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:3709) at android.view.ViewRootImpl$AsyncInputStage.apply(ViewRootImpl.java:3885) at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:3682) at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:3735) at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:3701) at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:3709) at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:3682) at android.view.ViewRootImpl.deliverInputEvent(ViewRootImpl.java:6001) at android.view.ViewRootImpl.doProcessInputEvents(ViewRootImpl.java:5975) at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:5936) at android.view.ViewRootImpl$ViewRootHandler.handleMessage(ViewRootImpl.java Message longer than Log limit (4000). Message was truncated. ** Activity (main) Pause, UserClosed = true **
