Siaic 88 ارسال شده در 21 آذر، 2017 اشتراک گذاری ارسال شده در 21 آذر، 2017 با سلام وقتی کتابخونه وانسیگنال در کنار پوشه فعال میشه مثل اینکه با هم تداخل میکنن و ارور زیر میدن میشه راهنمایی کنید. ممنون ارور زیر میده : Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/ActivityRecognitionResult; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/DetectedActivity; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence$Builder; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationListener; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationRequest; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationStatusCodes; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313) at com.android.dx.command.dexer.Main.run(Main.java:279) at com.android.dx.command.dexer.Main.main(Main.java:247) at com.android.dx.command.Main.main(Main.java:106) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681) ... 4 more لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 10 دی، 2017 اشتراک گذاری ارسال شده در 10 دی، 2017 چشم لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 11 دی، 2017 اشتراک گذاری ارسال شده در 11 دی، 2017 در در 1396/06/30, 13:07:39، Siaic گفته است : با سلام وقتی کتابخونه وانسیگنال در کنار پوشه فعال میشه مثل اینکه با هم تداخل میکنن و ارور زیر میدن میشه راهنمایی کنید. ممنون ارور زیر میده : Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/ActivityRecognitionResult; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/DetectedActivity; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence$Builder; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationListener; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationRequest; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationStatusCodes; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313) at com.android.dx.command.dexer.Main.run(Main.java:279) at com.android.dx.command.dexer.Main.main(Main.java:247) at com.android.dx.command.Main.main(Main.java:106) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681) ... 4 more سلام کتابخانه ای با کتابخانه google-play-services-gcm تداخل کرده ، حالا یا اون کتابخانه یا همین کتابخانه google-play-services-gcm.jar پسوندش را بصورت دستی تبدیل کنید به .zip بعدش با winrar فایل کتابخانه را بازکنید و فایلهای .class که در خطای پست اولتان هست را پیدا و delete کنید .سپس پسوندرا بصورت دستی به jar تغییرش بدهید . فایل هایی GoogleCloudMessaging$1.class - GoogleCloudMessaging.class و........ این فایلهاچون تکراری هست این مشکل را ایجادکرده ظاهرا فایلهای تکراری داخل فایل زیپ در این ادرس از google-play-services-gcm.zip می باشد \com\google\android\gms\gcm * البته هروقت چنین کاری را میکنید فایل تکراری را از کتابخانه ای که جزوکتابخانه های اصلی بیسیک فور نیست حذف کنید نه کتابخانه های اصلی (جایی هم این تغییر درکتابخانه راثبت کنید) وکتابخانه ای که قدیمی تر هست و تاریخ ایجادش قدیمی تر هست را دستکاری کنید . لذا پیشنهادمیشه اون کتابخانه google-play-services-gcm.jar را دستکاری نکنید و در اون کتابخانه دوم تغییرات بالا را ایجاد نمایید . من وانسیگنال رو نداشتم لذا google-play-services-gcm.jar را که در کنار کتابخانه های سایت پوشه هست رو مثال زدم موفق باشید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 21 آذر، 2017 اشتراک گذاری ارسال شده در 21 آذر، 2017 شما چرا از دوتا پیام رسان نوتیفیکیشن استفاده میکنید خوب معلوم که تداخل ایجاد میشه از وان سیگنال استفاده کنید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
Siaic 88 ارسال شده در 21 آذر، 2017 سازنده اشتراک گذاری ارسال شده در 21 آذر، 2017 در ۱ ساعت قبل، hojjatborohan گفته است : شما چرا از دوتا پیام رسان نوتیفیکیشن استفاده میکنید خوب معلوم که تداخل ایجاد میشه از وان سیگنال استفاده کنید نیاز دارم به 2 تا ولی دنبال رفع تداخلشم واقعا کسی تجربشو نداره؟ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hamed6513 1 ارسال شده در 21 آذر، 2017 اشتراک گذاری ارسال شده در 21 آذر، 2017 دوستان این مشکل بنده هم هست اگه کسی بلده راهنمایی کنه لطفا ممنون لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 دی، 2017 اشتراک گذاری ارسال شده در 12 دی، 2017 دوستان رفعش کرم اگه کسی بلد نیست اینم راهنمایی کافیه این کتابخانه ها رو جایگزین بکنید b4a-requirments-full GoogleMaps لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ehsan_pars 16 ارسال شده در 18 آبان، 2018 اشتراک گذاری ارسال شده در 18 آبان، 2018 سلام لطفا بفرمایید این مشکل رو با کتبخانه 1.4 پوشه چطور بر طرف می کنید با تشکر لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 8 دی، 2017 اشتراک گذاری ارسال شده در 8 دی، 2017 من این کارو کردم ولی باز همون اررور رو میده لطفا کمک کنید Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimatorRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnyRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/ArrayRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AttrRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/BinderThread; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/BoolRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/CallSuper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/CheckResult; این اررور رو میده لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 8 دی، 2017 اشتراک گذاری ارسال شده در 8 دی، 2017 اقا میدونم نباید پست رو بالا بیارم اما بخدا خیلی لازمش دارم لطفا راهنمایی بکنید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
پژمان نیکروان 6,055 ارسال شده در 10 دی، 2017 اشتراک گذاری ارسال شده در 10 دی، 2017 سلام برید توی کتابخانه های بیسیک و این فایل xml رو جایگزین فایل xml اصلی کتابخانه پوشه کنید. PushePlugin_v1.3.1 ببینید حل میشه یانه... لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 10 دی، 2017 اشتراک گذاری ارسال شده در 10 دی، 2017 در 6 ساعت قبل، پژمان نیکروان گفته است : سلام برید توی کتابخانه های بیسیک و این فایل xml رو جایگزین فایل xml اصلی کتابخانه پوشه کنید. PushePlugin_v1.3.1 ببینید حل میشه یانه... سلام اقا پژمان واقعا ممنونم که جواب دادید کاری که گفتید رو کردم اما اررور تغییر کرد و شد اینی که میبینید Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/ActivityRecognitionResult; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/DetectedActivity; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence$Builder; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationListener; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationRequest; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationStatusCodes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimRes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/annotation/AnimatorRes; لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
پژمان نیکروان 6,055 ارسال شده در 10 دی، 2017 اشتراک گذاری ارسال شده در 10 دی، 2017 در 4 ساعت قبل، hojjatborohan گفته است : سلام اقا پژمان واقعا ممنونم که جواب دادید کاری که گفتید رو کردم اما اررور تغییر کرد و شد اینی که میبینید کتابخانه های وان سیگنال و پوشه رو بفرستید باهم برام. لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
Siaic 88
ارور زیر میده :
Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/gcm/GoogleCloudMessaging$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/ActivityRecognitionResult; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/DetectedActivity; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/Geofence$Builder; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationListener; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationRequest; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/android/gms/location/LocationStatusCodes; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313) at com.android.dx.command.dexer.Main.run(Main.java:279) at com.android.dx.command.dexer.Main.main(Main.java:247) at com.android.dx.command.Main.main(Main.java:106) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681) ... 4 moreلینک ارسال
