سلام دوستان من یه کد برای اپلود فایل دارم و یه فایل پی اچ پی میام اپلود میکنم فایل رو در سرورم در پوشه اپپس ولی متاسفانه ارتباط برقرار نمیشه برای ارسال فایلم به سرور و میزنه دیس کانکت مشکل چیه ؟
#Region Project Attributes
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim cc As ContentChooser
Dim upload As UploadFilePhp
Private ProgressBar1 As ProgressBar
Private Label1 As Label
Private Button1 As Button
Dim fn As String
Dim fn2 As String
Activity.LoadLayout("1")
upload.Initialize("upload")
upload.B4A_log= True
cc.Initialize ("chooser")
' upload.doFileUpload(ProgressBar1,Label1,File.Combine(fn,fn2),"http://www.appdroids.ir/apps/upload_file.php")
Sub Activity_Resume
Sub button1_Click
cc.Show("image/*", "Choose image")
Sub chooser_Result (Success As Boolean, Dir As String, FileName As String)
If Success Then
Dir= fn
FileName = fn2
upload.doFileUpload(ProgressBar1,Label1,File.Combine(fn,fn2),"http://www.asa.ir/apps/upload_file.php")
mohammade79 127
اینم کدمه
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals Dim cc As ContentChooser End Sub Sub Globals Dim upload As UploadFilePhp Private ProgressBar1 As ProgressBar Private Label1 As Label Private Button1 As Button Dim fn As String Dim fn2 As String End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("1") upload.Initialize("upload") upload.B4A_log= True cc.Initialize ("chooser") ' upload.doFileUpload(ProgressBar1,Label1,File.Combine(fn,fn2),"http://www.appdroids.ir/apps/upload_file.php") End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub button1_Click cc.Show("image/*", "Choose image") End Sub Sub chooser_Result (Success As Boolean, Dir As String, FileName As String) If Success Then Dir= fn FileName = fn2 upload.doFileUpload(ProgressBar1,Label1,File.Combine(fn,fn2),"http://www.asa.ir/apps/upload_file.php") End If End Subلینک ارسال
