Error:(86, 0) Cause: startup failed:
build file 'C:\Users\Amir\Documents\EGDownloads\Felegram-master(1)\Felegram-master\TMessagesProj\build.gradle': 86: Ambiguous expression could be a parameterless closure expression, an isolated open code block, or it may continue a previous statement;
solution: Add an explicit parameter list, e.g. {it -> ...}, or force it to be treated as an open block by giving it a label, e.g. L:{...}, and also either remove the previous newline, or add an explicit semicolon ';' @ line 86, column 13.
{ signingconfig flavor1signingvariable }
1 error
<ahref="openFile:C:\Users\Amir\Documents\EGDownloads\Felegram-master(1)\Felegram-master\TMessagesProj\build.gradle">Open File</a>
atakhan 3
با سلام من امروز یه سورسی رو خاستم خروجی بگیرم
اخطار داد
اینم اخطار
وفتی روی open file میزنم اینجا میاد .
ممنون میشم زود جواب بدید
