محمد مهدی کمالی 19 ارسال شده در 1 بهمن، ۱۳۹۶ اشتراک گذاری ارسال شده در 1 بهمن، ۱۳۹۶ سلام تقریبا همه کتابخونه ها رو تست زدم با هم تداخلی ندارن ولی ارور زیر کلافم کرده B4A Version: 7.30 Parsing code. (0.02s) Compiling code. (0.07s) Compiling layouts code. (0.00s) Organizing libraries. (0.00s) Generating R file. (0.38s) Compiling generated Java code. (1.33s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionBar; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACButtonWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACCheckBoxWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACEditTextWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACFlatButtonWrapper; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313) at com.android.dx.command.dexer.Main.run(Main.java:279) at com.android.dx.command.dexer.Main.main(Main.java:247) at com.android.dx.command.Main.main(Main.java:106) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681) ... 4 more کتابخونه هایی که استفاده کردم: کلاس customlistveiw کلاس id3(برای نمایش کاور اهنگ) لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمد مهدی کمالی 19 ارسال شده در 1 بهمن، ۱۳۹۶ سازنده اشتراک گذاری ارسال شده در 1 بهمن، ۱۳۹۶ خودم دریافتم کلاسid3 که برای نمایش کاور اهنگه با appcompat تداخل داره گفتمش که شاید کسی مث خودم به مشکل بخوره شاید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمد رشوند 1,208 ارسال شده در 1 بهمن، ۱۳۹۶ اشتراک گذاری ارسال شده در 1 بهمن، ۱۳۹۶ در 2 ساعت قبل، mmkmmk گفته است : خودم دریافتم کلاسid3 که برای نمایش کاور اهنگه با appcompat تداخل داره گفتمش که شاید کسی مث خودم به مشکل بخوره شاید سلام دوست عزیز کلاس id3 فکر نمیکنم با اپ کامپت تداخل داشته باشه شما از تگ #MultiDex:true در پروژه خود استفاده کنید و دوباره کامپایل بگیرید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمد مهدی کمالی 19 ارسال شده در 1 بهمن، ۱۳۹۶ سازنده اشتراک گذاری ارسال شده در 1 بهمن، ۱۳۹۶ در 10 ساعت قبل، محمد رشوند گفته است : سلام دوست عزیز کلاس id3 فکر نمیکنم با اپ کامپت تداخل داشته باشه شما از تگ #MultiDex:true در پروژه خود استفاده کنید و دوباره کامپایل بگیرید استفاده کردم باز خطا داد لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 2 بهمن، ۱۳۹۶ اشتراک گذاری ارسال شده در 2 بهمن، ۱۳۹۶ در در 1396/11/01, 02:32:44، mmkmmk گفته است : سلام تقریبا همه کتابخونه ها رو تست زدم با هم تداخلی ندارن ولی ارور زیر کلافم کرده B4A Version: 7.30 Parsing code. (0.02s) Compiling code. (0.07s) Compiling layouts code. (0.00s) Organizing libraries. (0.00s) Generating R file. (0.38s) Compiling generated Java code. (1.33s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionBar; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACButtonWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACCheckBoxWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACEditTextWrapper; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACFlatButtonWrapper; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313) at com.android.dx.command.dexer.Main.run(Main.java:279) at com.android.dx.command.dexer.Main.main(Main.java:247) at com.android.dx.command.Main.main(Main.java:106) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681) ... 4 more کتابخونه هایی که استفاده کردم: کلاس customlistveiw کلاس id3(برای نمایش کاور اهنگ) سلام وقتی تعداد کتابخانه هایی که در پروژه تون استفاده کردین خیلی زیاد باشه که نتونید کتابخانه هایی که باهمدیگر تداخل دارند رو پیداکنید ، یک راه ساده اش اینه که فایلهای کتابخانه هایی که استفاده کردید رو داخل یک پوشه خالی بریزید و سپس پسوند همه کتابخانه ها رو تبدیل به zip کنید وبعدش همه کتابخانه ها رو unzip کنید ، بعد بااستفاده از نرم افزار سرچ فایل دنبال فایلهای همنام بگردید ، (مثلا نرم افزار Everything سرعت بالایی درسرچ فایل داره) لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمد مهدی کمالی 19
کلاس customlistveiw
