این کد های منه اما نمیدونم چرا از این ها ایراد میگیره
از خط 6 و 8 ایراد میگیره لطفا کمک کنید
Private Sub m_gozaresh_onNegative(action As String)
Activity.RemoveAllViews
Activity.LoadLayout("LGozaresht")
Main.e = 2
Dim obj As View
obj = Sender
Dim cur As Cursor
cur = sql1.ExecQuery2("SELECT * FROM TblText WHERE ID = ?" , Array As String(obj.Tag))
For i = 0 To cur.RowCount - 1
cur.Position = i
Lblteacher.Text = cur.GetString("GozareshTeacher")
su.MeasureMultilineTextHeight(Lblteacher , Lblteacher.Text)
ID = cur.GetString("ID")
LblIDteacher.Text = "یادداشتهای معلم: نکتهی" & cur.GetInt("Text")
ارورش هم اینه
Error occurred on line: 532 (Home)
java.lang.ClassCastException: com.afollestad.materialdialogs.MaterialDialog cannot be cast to android.view.View
at com.bookziste10.hassanli.home._m_gozaresh_onnegative(home.java:1751)
at java.lang.reflect.Method.invoke(Method.java:372)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:351)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
at anywheresoftware.b4a.BA$2.run(BA.java:370)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Looper.loop(Looper.java:135)
at android.app.ActivityThread.main(ActivityThread.java:5221)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)
Mthzf1384 123
Private Sub m_gozaresh_onNegative(action As String) Activity.RemoveAllViews Activity.LoadLayout("LGozaresht") Main.e = 2 Dim obj As View obj = Sender Dim cur As Cursor cur = sql1.ExecQuery2("SELECT * FROM TblText WHERE ID = ?" , Array As String(obj.Tag)) For i = 0 To cur.RowCount - 1 cur.Position = i Lblteacher.Text = cur.GetString("GozareshTeacher") su.MeasureMultilineTextHeight(Lblteacher , Lblteacher.Text) ID = cur.GetString("ID") LblIDteacher.Text = "یادداشتهای معلم: نکتهی" & cur.GetInt("Text") Next End Subارورش هم اینه
Error occurred on line: 532 (Home) java.lang.ClassCastException: com.afollestad.materialdialogs.MaterialDialog cannot be cast to android.view.View at com.bookziste10.hassanli.home._m_gozaresh_onnegative(home.java:1751) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:351) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144) at anywheresoftware.b4a.BA$2.run(BA.java:370) at android.os.Handler.handleCallback(Handler.java:739) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:135) at android.app.ActivityThread.main(ActivityThread.java:5221) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)با تشکر
