خطا اپ کامپت موقع کامپایل
Mr.Kafiri
سلام به دوستان
موقع ران گرفتن از اپ به خطای زیر برخوردم.
B4A Version: 9.80
Java Version: 8
Parsing code.    (0.48s)
Building folders structure.    (0.41s)
Compiling code.    (4.47s)
Compiling layouts code.    (2.59s)
Organizing libraries.    (0.00s)
	(AndroidX SDK)
Generating R file.    (19.16s)
Compiling generated Java code.    (14.66s)
Convert byte code - optimized dex.    Error
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionBar;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACButtonWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACCheckBoxWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACEditTextWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACFlatButtonWrapper;
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: Translation has been interrupted
	at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:315)
	at com.android.dx.command.dexer.Main.runDx(Main.java:293)
	at com.android.dx.command.dexer.Main.main(Main.java:249)
	at com.android.dx.command.Main.main(Main.java:94)
Caused by: java.lang.InterruptedException: Too many errors
	at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684)
	... 4 more
اگر مشکل اینه که من این فایل ها رو در sdk ندارم لطفا یکی این فایل ها رو برام آپلود کنه هر چی sdk رو از طریق b4a آپدیت کردم بازم نشد
یک اسکرینشات از کتابخونه هات بده
این تداخل کتابخونه ای هست
ببین کدوم با کدوم تداخل پیدا کرده
پرس و جو کردم گویا بخاطر اندروید x و این چیزهاست
شما به جای appcompat  از لینک زیر از کتابخونه jk_appcompat استفاده کنید هم سازگاره با اندروید x هم اینکه فک کنم مشکلتو برطرف کنه
کتابخونه رایگانه
JK_APPCOMPAT 3.3
در 5 ساعت قبل، mehrzad238 گفته است :
کتابخونه رایگانه
JK_APPCOMPAT 3.3
ببخشید خیلی پررویی میکنم
نتونستم وارد سایت بشم لطفا اگه میشه کتابخانه رو همینجا پیوست کنید. :)
در 4 ساعت قبل، MrPhone گفته است :
در حال جا به جایی هاست هست صاحبشون
http://s6.picofile.com/file/8387896818/jk_appcompat.zip.html
به محض درست شدن وبسایتون برید و ورژن جدیدشو بگیرید
امیدوارم مشکلتون حل شه
اگر نشد باز هم پیام بدید تا با یاری دوستان حلش کنیم
jdk  رو هم آپدیت کن ورژن 11 نصب کن
الان دیگه تو سایت بیسیک هم گفته 11 استفاده کن بهتره
