خطای MSMaterialDrawer و خطا بعد از کامپایل
python
من سورسی دارم که موقع کامپایل و بعد از نصب خطا میده
تمام کتابخانه های مورد نیاز رو هم نصب کردم اما نتیجه نداده
خطای بعد از نصب:
ActionBar Height: 56
android.view.InflateException: Binary XML file line #2: Binary XML file line #2: Error inflating class android.support.v4.widget.DrawerLayout
Caused by: android.view.InflateException: Binary XML file line #2: Error inflating class android.support.v4.widget.DrawerLayout
Caused by: java.lang.ClassNotFoundException: Didn't find class "android.support.v4.widget.DrawerLayout" on path: DexPathList[[zip file "/system/framework/org.apache.http.legacy.boot.jar", zip file "/data/app/b4a.ramezan-jUJOpRplCWntht9n8k6g0Q==/base.apk"],nativeLibraryDirectories=[/data/app/b4a.ramezan-jUJOpRplCWntht9n8k6g0Q==/lib/arm64, /system/lib64, /product/lib64]]
	at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:134)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:379)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
	at android.view.LayoutInflater.createView(LayoutInflater.java:613)
	at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:801)
	at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:741)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:492)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:423)
	at com.mikepenz.materialdrawer.Drawer.withDrawerLayout(Drawer.java:334)
	at com.mikepenz.materialdrawer.Drawer.build(Drawer.java:1090)
	at com.maximussoft.msmaterialdrawer.MSMaterialDrawerBuilder.Build(MSMaterialDrawerBuilder.java:122)
	at b4a.ramezan.main._activity_create(main.java:503)
	at anywheresoftware.b4a.BA.raiseEvent2(BA.java:196)
	at b4a.ramezan.main.afterFirstLayout(main.java:104)
	at b4a.ramezan.main.access$000(main.java:17)
	at b4a.ramezan.main$WaitForLayout.run(main.java:82)
	at android.os.Handler.handleCallback(Handler.java:907)
	at android.os.Handler.dispatchMessage(Handler.java:105)
	at android.os.Looper.loop(Looper.java:216)
	at android.app.ActivityThread.main(ActivityThread.java:7625)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:524)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:987)
اسکرین شات روی گوشی بعد از نصب:
خطا موقع تاچ روی منو:
** Activity (main) Resume **
main_menui_click (java line: 665)
java.lang.RuntimeException: Object should first be initialized (MSMaterialDrawer).
	at anywheresoftware.b4a.AbsObjectWrapper.getObject(AbsObjectWrapper.java:50)
	at com.maximussoft.msmaterialdrawer.MSMaterialDrawer.OpenDrawer(MSMaterialDrawer.java:15)
	at b4a.ramezan.main._menui_click(main.java:665)
	at anywheresoftware.b4a.BA.raiseEvent2(BA.java:180)
	at anywheresoftware.b4a.BA.raiseEvent(BA.java:176)
	at anywheresoftware.b4a.objects.ViewWrapper$1.onClick(ViewWrapper.java:80)
	at android.view.View.performClick(View.java:6659)
	at android.view.View.performClickInternal(View.java:6631)
	at android.view.View.access$3100(View.java:790)
	at android.view.View$PerformClick.run(View.java:26187)
اسکرین شات از خطای روی گوشی
با دیباگ هم چک کردم به این خط گیر داد
Sub menui_Click
	MD.OpenDrawer
ممنون میشم راهنمایی کنید
اگر نیاز هست سورس رو هم ارسال کنم
این مشکل Androidx هست که متاسفانه حل نمیشه.
تو سایت مرجع هم گفته شده از این کتابخونه استفاده نکنید و از B4XDrawer استفاده کنید.
https://www.b4x.com/android/forum/threads/msmaterialdrawer-and-targetsdkversion-28-and-b4a-ver-9-30.109084/
https://www.b4x.com/android/forum/threads/msmaterialdrawer.53883/page-13
به احتمال %99 از خط Md = Mdb.Build داره ایراد میگیره که متاسفانه به هیچ وجه قابل حل نیست...
در 19 دقیقه قبل، Mr.Kafiri گفته است :
کد هاتون رو بزارید
صدرصد مشکل از اینیشیالایز هستش
این کدهای من هستش
#Region  Activity Attributes
	#FullScreen: false
	#IncludeTitle: false
#End Region
#AdditionalJar: android-support-v7-appcompat
#AdditionalRes: ..\resource
#AdditionalRes: ..\md-app\res
#AdditionalRes: ..\md-lib\res
	Dim iransans As Typeface
	Dim timClock As Timer
	Private ListView1 As ListView
	Dim AC As AppCompat
	Private ActionBar As Panel
	Dim MDB As MSMaterialDrawerBuilder
	Dim MD As MSMaterialDrawer
	Dim i As Intent
	Private saat As Label
	Dim TimeFont As Typeface
	Private Label1 As Label
	Dim menui As Button
	Dim ALabel As Label
	Dim clock As ImageView
	Dim Panel2 As Panel
	Dim Panel1 As Panel
	Activity.LoadLayout("main")
Log("ActionBar Height: " & (AC.GetMaterialActionBarHeight / DipToCurrent(1)))
	ListView1.AddSingleLine("تست 1")
	ListView1.AddSingleLine("تست 2")
	ListView1.AddSingleLine("تست 3")
	ListView1.AddSingleLine("تست 4")
	ListView1.AddSingleLine("تست 5")
	ListView1.AddSingleLine("تست 6")
	ListView1.AddSingleLine("تست 7")
	AC.SetElevation(ActionBar, 8dip)
	AC.SetElevation(Panel1, 4dip)
	AC.SetElevation(Panel2, 4dip)
	iransans = Typeface.LoadFromAssets("iransans.ttf")
	Label1.Typeface = iransans
	ALabel.Typeface = iransans
	saat.TextSize = 20
	saat.TextColor = Colors.White
	saat.Text = "00:00"
	DateTime.TimeFormat = "HH:mm:ss"
	timClock.Initialize("timClock",1)
	timClock.Enabled = True
	TimeFont = Typeface.LoadFromAssets("BNaznnBd.ttf")
	saat.Typeface = TimeFont
	Dim l As Label
		l = ListView1.SingleLineLayout.Label
		l.TextColor = Colors.RGB(124,179,66)
		l.Gravity = Gravity.CENTER
		l.TextSize = 20
		l.Typeface=Typeface.LoadFromAssets("iransans.ttf")
		Dim pnlHdr As Panel
	pnlHdr.Initialize("")
	pnlHdr.Color = Colors.DarkGray
	pnlHdr.Tag = "Header"
	Dim msa As MSAccountHeaderBuilder
	Dim HeaderBackground As BitmapDrawable
	HeaderBackground.Initialize(LoadBitmap(File.DirAssets,"header.png"))
	msa.Initialize("MSA")
	msa.withHeaderBackground(HeaderBackground)
	Dim MaterialHeaderResult As Object = msa.build
	Dim p1 As MSIconicDrawable : p1.Initialize("gmd_settings"): p1.Color = 0xFF737373
	Dim p2 As MSIconicDrawable : p2.Initialize("gmd_email"): p2.Color = 0xFF737373
	Dim p3 As MSIconicDrawable : p3.Initialize("gmd_info"): p3.Color = 0xFF737373
	Dim p4 As MSIconicDrawable : p4.Initialize("gmd_stay_current_portrait"): p4.Color = 0xFF737373
	Dim p5 As MSIconicDrawable : p5.Initialize("gmd_person"): p5.Color = 0xFF737373
	MDB.Initialize("MD")
	MDB.withAccountHeader(MaterialHeaderResult)
	'MDB.withHeader(pnlHdr, -1, 80dip)
	MDB.AddPrimaryDrawerItem  ("تنظیمات برنامه"  , p1.Drawable ,Null ,"" ,True,1, "")
	MDB.AddPrimaryDrawerItem  ("تماس با ما"  , p2.Drawable ,Null ,"" ,True,2, "")
	MDB.AddPrimaryDrawerItem  ("درباره ما"  , p3.Drawable ,Null ,"" ,True,3, "")
	MDB.AddPrimaryDrawerItem  ("برنامه های دیگر ما" , p4.Drawable ,Null ,""   ,True,4, "")
	MDB.AddSectionDrawerItem  ("سایر اطلاعات"  ,True)
	MDB.AddSecondaryDrawerItem("- نگارش 2.0" ,Null        ,Null ,""    ,False ,6)
	MDB.AddSecondaryDrawerItem("- تمامی حقوق برای  محفوظ است."       ,Null        ,Null ,""    ,False,7)
	MDB.withDrawerGravity(Gravity.RIGHT)
	MD = MDB.Build
Sub Activity_Resume
	If Position = 0 Then
	StartActivity("doa")
	If Position = 1 Then
	StartActivity("sms")
	If Position = 2 Then
	StartActivity("salavat")
	If Position = 3 Then
 If File.Exists(File.DirRootExternal,"test.pdf")=False Then
		File.copy(File.DirAssets,"test.pdf",File.DirRootExternal,"test.pdf")
	Dim pm As PackageManager
    Dim Intent1 As Intent
    Intent1.Initialize(Intent1.ACTION_VIEW, "file://" & File.Combine(File.DirRootExternal&"/", "testr.pdf"))
    Intent1.SetType("application/pdf")
	If pm.QueryIntentActivities(Intent1).Size = 0 Then
		Msgbox("برنامه ای برای نمایش فایل PDF نصب نیست.","خطا")
		Intent1.WrapAsIntentChooser("نمایش با:")
		StartActivity(Intent1)
	If Position = 4 Then
'	StartActivity(pish)
	If Position = 5 Then
'	StartActivity(zang)
Sub menui_Click
	MD.OpenDrawer
Sub timclock_Tick
	saat.Text = DateTime.Time(DateTime.Now)
Sub Activity_keypress(keycode As Int) As Boolean
Dim aa As Int
  If keycode=KeyCodes.KEYCODE_BACK Then
  aa =Msgbox2("آیا میخواهید از برنامه بیرون بروید؟","خروج","بله","","خیر",Null)
  If aa=DialogResponse.POSITIVE Then
  Return False
 Return True
در 16 دقیقه قبل، Salar82 گفته است :
راه حلی نداره؟
متاسفانه من تازه کارم نمیدونم چیکار کنم
در ۱ ساعت قبل، python گفته است :
راه حلی نداره؟
نه متاسفانه
بیسیک ضعف های خیلی زیادی داره که اینم یکی از اوناست.
ولی من پیشنهاد میکنم از این(DsNavigationDrawer) استفاده کنید و همونطور هم که میدونید، باید با تحریم شکن کار کنید.
screenshot_20160826-160906-png.47461
در در 5 اردیبهشت 1399 در 15:23، Salar82 گفته است :
نه متاسفانه
ولی من پیشنهاد میکنم از این(DsNavigationDrawer) استفاده کنید و همونطور هم که میدونید، باید از تحریم شکن کار کنید.
متاسفانه نتنونستم پیاده کنم
لینکش رو که گذاشتم
https://www.b4x.com/android/forum/threads/designsupport-additional-material-design-components.58893/
