من سورسی دارم که موقع کامپایل و بعد از نصب خطا میده
تمام کتابخانه های مورد نیاز رو هم نصب کردم اما نتیجه نداده
خطای بعد از نصب:
**Activity(main)Create, isFirst =true**ActionBarHeight:56
android.view.InflateException:Binary XML file line #2: Binary XML file line #2: Error inflating class android.support.v4.widget.DrawerLayoutCaused by: android.view.InflateException:Binary XML file line #2: Error inflating class android.support.v4.widget.DrawerLayoutCaused by: java.lang.ClassNotFoundException:Didn't find class"android.support.v4.widget.DrawerLayout" on path:DexPathList[[zip file "/system/framework/org.apache.http.legacy.boot.jar", zip file "/data/app/b4a.ramezan-jUJOpRplCWntht9n8k6g0Q==/base.apk"],nativeLibraryDirectories=[/data/app/b4a.ramezan-jUJOpRplCWntht9n8k6g0Q==/lib/arm64,/system/lib64,/product/lib64]]
at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:134)
at java.lang.ClassLoader.loadClass(ClassLoader.java:379)
at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
at android.view.LayoutInflater.createView(LayoutInflater.java:613)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:801)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:741)
at android.view.LayoutInflater.inflate(LayoutInflater.java:492)
at android.view.LayoutInflater.inflate(LayoutInflater.java:423)
at com.mikepenz.materialdrawer.Drawer.withDrawerLayout(Drawer.java:334)
at com.mikepenz.materialdrawer.Drawer.build(Drawer.java:1090)
at com.maximussoft.msmaterialdrawer.MSMaterialDrawerBuilder.Build(MSMaterialDrawerBuilder.java:122)
at b4a.ramezan.main._activity_create(main.java:503)
at java.lang.reflect.Method.invoke(NativeMethod)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:196)
at b4a.ramezan.main.afterFirstLayout(main.java:104)
at b4a.ramezan.main.access$000(main.java:17)
at b4a.ramezan.main$WaitForLayout.run(main.java:82)
at android.os.Handler.handleCallback(Handler.java:907)
at android.os.Handler.dispatchMessage(Handler.java:105)
at android.os.Looper.loop(Looper.java:216)
at android.app.ActivityThread.main(ActivityThread.java:7625)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:524)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:987)
اسکرین شات روی گوشی بعد از نصب:
خطا موقع تاچ روی منو:
** Activity (main) Resume **
main_menui_click (java line: 665)
java.lang.RuntimeException: Object should first be initialized (MSMaterialDrawer).
at anywheresoftware.b4a.AbsObjectWrapper.getObject(AbsObjectWrapper.java:50)
at com.maximussoft.msmaterialdrawer.MSMaterialDrawer.OpenDrawer(MSMaterialDrawer.java:15)
at b4a.ramezan.main._menui_click(main.java:665)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:180)
at anywheresoftware.b4a.BA.raiseEvent(BA.java:176)
at anywheresoftware.b4a.objects.ViewWrapper$1.onClick(ViewWrapper.java:80)
at android.view.View.performClick(View.java:6659)
at android.view.View.performClickInternal(View.java:6631)
at android.view.View.access$3100(View.java:790)
at android.view.View$PerformClick.run(View.java:26187)
python 1
خطای بعد از نصب:
** Activity (main) Resume ** main_menui_click (java line: 665) java.lang.RuntimeException: Object should first be initialized (MSMaterialDrawer). at anywheresoftware.b4a.AbsObjectWrapper.getObject(AbsObjectWrapper.java:50) at com.maximussoft.msmaterialdrawer.MSMaterialDrawer.OpenDrawer(MSMaterialDrawer.java:15) at b4a.ramezan.main._menui_click(main.java:665) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:196) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:180) at anywheresoftware.b4a.BA.raiseEvent(BA.java:176) at anywheresoftware.b4a.objects.ViewWrapper$1.onClick(ViewWrapper.java:80) at android.view.View.performClick(View.java:6659) at android.view.View.performClickInternal(View.java:6631) at android.view.View.access$3100(View.java:790) at android.view.View$PerformClick.run(View.java:26187) at android.os.Handler.handleCallback(Handler.java:907) at android.os.Handler.dispatchMessage(Handler.java:105) at android.os.Looper.loop(Looper.java:216) at android.app.ActivityThread.main(ActivityThread.java:7625) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:524) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:987) java.lang.RuntimeException: Object should first be initialized (MSMaterialDrawer).اسکرین شات از خطای روی گوشی
با دیباگ هم چک کردم به این خط گیر داد
Sub menui_Click MD.OpenDrawer End Subممنون میشم راهنمایی کنید
اگر نیاز هست سورس رو هم ارسال کنم
