Salar82 919 ارسال شده در 5 مهر، 2020 اشتراک گذاری ارسال شده در 5 مهر، 2020 سلام لیست دسترسی ها رو یه جا براتون آماده کردم تا مواقعی که خواستین یه دسترسی رو به برنامتون بدین، مشکلی نداشته باشین AddPermission(android.permission.ACCESS_CHECKIN_PROPERTIES) ' Allows read/write access to the "properties" table in the checkin database, to change values that get uploaded. AddPermission(android.permission.ACCESS_COARSE_LOCATION) ' Allows an app to access approximate location derived from network location sources such as cell towers and Wi-Fi. AddPermission(android.permission.ACCESS_FINE_LOCATION) ' Allows an app to access precise location from location sources such as GPS, cell towers, and Wi-Fi. AddPermission(android.permission.ACCESS_LOCATION_EXTRA_COMMANDS) ' Allows an application to access extra location provider commands. AddPermission(android.permission.ACCESS_MOCK_LOCATION) ' Allows an application to create mock location providers for testing. AddPermission(android.permission.ACCESS_NETWORK_STATE) ' Allows applications to access information about networks. AddPermission(android.permission.ACCESS_SURFACE_FLINGER) ' Allows an application to use SurfaceFlinger's low level features. AddPermission(android.permission.ACCESS_WIFI_STATE) ' Allows applications to access information about Wi-Fi networks. AddPermission(android.permission.ACCOUNT_MANAGER) ' Allows applications to call into AccountAuthenticators. AddPermission(android.permission.ADD_VOICEMAIL) ' Allows an application to add voicemails into the system. AddPermission(android.permission.AUTHENTICATE_ACCOUNTS) ' Allows an application to act as an AccountAuthenticator for the AccountManager. AddPermission(android.permission.BATTERY_STATS) ' Allows an application to collect battery statistics. AddPermission(android.permission.BIND_ACCESSIBILITY_SERVICE) ' Must be required by an AccessibilityService, to ensure that only the system can bind to it. AddPermission(android.permission.BIND_APPWIDGET) ' Allows an application to tell the AppWidget service which application can access AppWidget's data. AddPermission(android.permission.BIND_DEVICE_ADMIN) ' Must be required by device administration receiver, to ensure that only the system can interact with it. AddPermission(android.permission.BIND_INPUT_METHOD) ' Must be required by an InputMethodService, to ensure that only the system can bind to it. AddPermission(android.permission.BIND_NFC_SERVICE) ' Must be required by a HostApduService or OffHostApduService to ensure that only the system can bind to it. AddPermission(android.permission.BIND_NOTIFICATION_LISTENER_SERVICE) ' Must be required by an NotificationListenerService, to ensure that only the system can bind to it. AddPermission(android.permission.BIND_PRINT_SERVICE) ' Must be required by a PrintService, to ensure that only the system can bind to it. AddPermission(android.permission.BIND_REMOTEVIEWS) ' Must be required by a RemoteViewsService, to ensure that only the system can bind to it. AddPermission(android.permission.BIND_TEXT_SERVICE) ' Must be required by a TextService (e.g. AddPermission(android.permission.BIND_VPN_SERVICE) ' Must be required by a VpnService, to ensure that only the system can bind to it. AddPermission(android.permission.BIND_WALLPAPER) ' Must be required by a WallpaperService, to ensure that only the system can bind to it. AddPermission(android.permission.BLUETOOTH) ' Allows applications to connect to paired bluetooth devices. AddPermission(android.permission.BLUETOOTH_ADMIN) ' Allows applications to discover and pair bluetooth devices. AddPermission(android.permission.BLUETOOTH_PRIVILEGED) ' Allows applications to pair bluetooth devices without user interaction. AddPermission(android.permission.BRICK) ' Required to be able to disable the device (very dangerous!). AddPermission(android.permission.BROADCAST_PACKAGE_REMOVED) ' Allows an application to broadcast a notification that an application package has been removed. AddPermission(android.permission.BROADCAST_SMS) ' Allows an application to broadcast an SMS receipt notification. AddPermission(android.permission.BROADCAST_STICKY) ' Allows an application to broadcast sticky intents. AddPermission(android.permission.BROADCAST_WAP_PUSH) ' Allows an application to broadcast a WAP PUSH receipt notification. AddPermission(android.permission.CALL_PHONE) ' Allows an application to initiate a phone call without going through the Dialer user interface for the user to confirm the call being placed. AddPermission(android.permission.CALL_PRIVILEGED) ' Allows an application to call any phone number, including emergency numbers, without going through the Dialer user interface for the user to confirm the call being placed. AddPermission(android.permission.CAMERA) ' Required to be able to access the camera device. AddPermission(android.permission.CAPTURE_AUDIO_OUTPUT) ' Allows an application to capture audio output. AddPermission(android.permission.CAPTURE_SECURE_VIDEO_OUTPUT) ' Allows an application to capture secure video output. AddPermission(android.permission.CAPTURE_VIDEO_OUTPUT) ' Allows an application to capture video output. AddPermission(android.permission.CHANGE_COMPONENT_ENABLED_STATE) ' Allows an application to change whether an application component (other than its own) is enabled or not. AddPermission(android.permission.CHANGE_CONFIGURATION) ' Allows an application to modify the current configuration, such as locale. AddPermission(android.permission.CHANGE_NETWORK_STATE) ' Allows applications to change network connectivity state. AddPermission(android.permission.CHANGE_WIFI_MULTICAST_STATE) ' Allows applications to enter Wi-Fi Multicast mode. AddPermission(android.permission.CHANGE_WIFI_STATE) ' Allows applications to change Wi-Fi connectivity state. AddPermission(android.permission.CLEAR_APP_CACHE) ' Allows an application to clear the caches of all installed applications on the device. AddPermission(android.permission.CLEAR_APP_USER_DATA) ' Allows an application to clear user data. AddPermission(android.permission.CONTROL_LOCATION_UPDATES) ' Allows enabling/disabling location update notifications from the radio. AddPermission(android.permission.DELETE_CACHE_FILES) ' Allows an application to delete cache files. AddPermission(android.permission.DELETE_PACKAGES) ' Allows an application to delete packages. AddPermission(android.permission.DEVICE_POWER) ' Allows low-level access to power management. AddPermission(android.permission.DIAGNOSTIC) ' Allows applications to RW to diagnostic resources. AddPermission(android.permission.DISABLE_KEYGUARD) ' Allows applications to disable the keyguard. AddPermission(android.permission.DUMP) ' Allows an application to retrieve state dump information from system services. AddPermission(android.permission.EXPAND_STATUS_BAR) ' Allows an application to expand or collapse the status bar. AddPermission(android.permission.FACTORY_TEST) ' Run as a manufacturer test application, running as the root user. AddPermission(android.permission.FLASHLIGHT) ' Allows access to the flashlight. AddPermission(android.permission.FORCE_BACK) ' Allows an application to force a BACK operation on whatever is the top activity. AddPermission(android.permission.GET_ACCOUNTS) ' Allows access to the list of accounts in the Accounts Service. AddPermission(android.permission.GET_PACKAGE_SIZE) ' Allows an application to find out the space used by any package. AddPermission(android.permission.GET_TASKS) ' Allows an application to get information about the currently or recently running tasks. AddPermission(android.permission.GET_TOP_ACTIVITY_INFO) ' Allows an application to retrieve private information about the current top activity, such as any assist context it can provide. AddPermission(android.permission.GLOBAL_SEARCH) ' This permission can be used on content providers to allow the global search system to access their data. AddPermission(android.permission.HARDWARE_TEST) ' Allows access to hardware peripherals. AddPermission(android.permission.INJECT_EVENTS) ' Allows an application to inject user events (keys, touch, trackball) into the event stream and deliver them to ANY window. AddPermission(android.permission.INSTALL_LOCATION_PROVIDER) ' Allows an application to install a location provider into the Location Manager. AddPermission(android.permission.INSTALL_PACKAGES) ' Allows an application to install packages. AddPermission(android.permission.INSTALL_SHORTCUT) ' Allows an application to install a shortcut in Launcher. AddPermission(android.permission.INTERNAL_SYSTEM_WINDOW) ' Allows an application to open windows that are for use by parts of the system user interface. AddPermission(android.permission.INTERNET) ' Allows applications to open network sockets. AddPermission(android.permission.KILL_BACKGROUND_PROCESSES) ' Allows an application to call killBackgroundProcesses(String). AddPermission(android.permission.LOCATION_HARDWARE) ' Allows an application to use location features in hardware, such as the geofencing api. AddPermission(android.permission.MANAGE_ACCOUNTS) ' Allows an application to manage the list of accounts in the AccountManager. AddPermission(android.permission.MANAGE_APP_TOKENS) ' Allows an application to manage (create, destroy, Z-order) application tokens in the window manager. AddPermission(android.permission.MANAGE_DOCUMENTS) ' Allows an application to manage access to documents, usually as part of a document picker. AddPermission(android.permission.MASTER_CLEAR) ' Not for use by third-party applications. AddPermission(android.permission.MEDIA_CONTENT_CONTROL) ' Allows an application to know what content is playing and control its playback. AddPermission(android.permission.MODIFY_AUDIO_SETTINGS) ' Allows an application to modify global audio settings. AddPermission(android.permission.MODIFY_PHONE_STATE) ' Allows modification of the telephony state - power on, mmi, etc. AddPermission(android.permission.MOUNT_FORMAT_FILESYSTEMS) ' Allows formatting file systems for removable storage. AddPermission(android.permission.MOUNT_UNMOUNT_FILESYSTEMS) ' Allows mounting and unmounting file systems for removable storage. AddPermission(android.permission.NFC) ' Allows applications to perform I/O operations over NFC. AddPermission(android.permission.PERSISTENT_ACTIVITY) ' This constant was deprecated in API level 9. This functionality will be removed in the future; please do not use. Allow an application to make its activities persistent. AddPermission(android.permission.PROCESS_OUTGOING_CALLS) ' Allows an application to see the number being dialed during an outgoing call with the option to redirect the call to a different number or abort the call altogether. AddPermission(android.permission.READ_CALENDAR) ' Allows an application to read the user's calendar data. AddPermission(android.permission.READ_CALL_LOG) ' Allows an application to read the user's call log. AddPermission(android.permission.READ_CONTACTS) ' Allows an application to read the user's contacts data. AddPermission(android.permission.READ_EXTERNAL_STORAGE) ' Allows an application to read from external storage. AddPermission(android.permission.READ_FRAME_BUFFER) ' Allows an application to take screen shots and more generally get access to the frame buffer data. AddPermission(android.permission.READ_HISTORY_BOOKMARKS) ' Allows an application to read (but not write) the user's browsing history and bookmarks. AddPermission(android.permission.READ_INPUT_STATE) ' This constant was deprecated in API level 16. The API that used this permission has been removed. AddPermission(android.permission.READ_LOGS) ' Allows an application to read the low-level system log files. AddPermission(android.permission.READ_PHONE_STATE) ' Allows read only access to phone state. AddPermission(android.permission.READ_PROFILE) ' Allows an application to read the user's personal profile data. AddPermission(android.permission.READ_SMS) ' Allows an application to read SMS messages. AddPermission(android.permission.READ_SOCIAL_STREAM) ' Allows an application to read from the user's social stream. AddPermission(android.permission.READ_SYNC_SETTINGS) ' Allows applications to read the sync settings. AddPermission(android.permission.READ_SYNC_STATS) ' Allows applications to read the sync stats. AddPermission(android.permission.READ_USER_DICTIONARY) ' Allows an application to read the user dictionary. AddPermission(android.permission.REBOOT) ' Required to be able to reboot the device. AddPermission(android.permission.RECEIVE_BOOT_COMPLETED) ' Allows an application to receive the ACTION_BOOT_COMPLETED that is broadcast after the system finishes booting. AddPermission(android.permission.RECEIVE_MMS) ' Allows an application to monitor incoming MMS messages, to record or perform processing on them. AddPermission(android.permission.RECEIVE_SMS) ' Allows an application to monitor incoming SMS messages, to record or perform processing on them. AddPermission(android.permission.RECEIVE_WAP_PUSH) ' Allows an application to monitor incoming WAP push messages. AddPermission(android.permission.RECORD_AUDIO) ' Allows an application to record audio. AddPermission(android.permission.REORDER_TASKS) ' Allows an application to change the Z-order of tasks. AddPermission(android.permission.RESTART_PACKAGES) ' This constant was deprecated in API level 8. The restartPackage(String) API is no longer supported. AddPermission(android.permission.SEND_RESPOND_VIA_MESSAGE) ' Allows an application (Phone) to send a request to other applications to handle the respond-via-message action during incoming calls. AddPermission(android.permission.SEND_SMS) ' Allows an application to send SMS messages. AddPermission(android.permission.SET_ACTIVITY_WATCHER) ' Allows an application to watch and control how activities are started globally in the system. AddPermission(android.permission.SET_ALARM) ' Allows an application to broadcast an Intent to set an alarm for the user. AddPermission(android.permission.SET_ALWAYS_FINISH) ' Allows an application to control whether activities are immediately finished when put in the background. AddPermission(android.permission.SET_ANIMATION_SCALE) ' Modify the global animation scaling factor. AddPermission(android.permission.SET_DEBUG_APP) ' Configure an application for debugging. AddPermission(android.permission.SET_ORIENTATION) ' Allows low-level access to setting the orientation (actually rotation) of the . AddPermission(android.permission.SET_POINTER_SPEED) ' Allows low-level access to setting the pointer speed. AddPermission(android.permission.SET_PREFERRED_APPLICATIONS) ' This constant was deprecated in API level 7. No longer useful, see addPackageToPreferred(String) for details. AddPermission(android.permission.SET_PROCESS_LIMIT) ' Allows an application to set the maximum number of (not needed) application processes that can be running. AddPermission(android.permission.SET_TIME) ' Allows applications to set the system time. AddPermission(android.permission.SET_TIME_ZONE) ' Allows applications to set the system time zone. AddPermission(android.permission.SET_WALLPAPER) ' Allows applications to set the wallpaper. AddPermission(android.permission.SET_WALLPAPER_HINTS) ' Allows applications to set the wallpaper hints. AddPermission(android.permission.SIGNAL_PERSISTENT_PROCESSES) ' Allow an application to request that a signal be sent to all persistent processes. AddPermission(android.permission.STATUS_BAR) ' Allows an application to open, close, or disable the status bar and its icons. AddPermission(android.permission.SUBSCRIBED_FEEDS_READ) ' Allows an application to allow read access the subscribed feeds ContentProvider. AddPermission(android.permission.SUBSCRIBED_FEEDS_WRITE) ' Allows an application to allow write access the subscribed feeds ContentProvider. AddPermission(android.permission.SYSTEM_ALERT_WINDOW) ' Allows an application to open windows using the type TYPE_SYSTEM_ALERT, shown on top of all other applications. AddPermission(android.permission.TRANSMIT_IR ALLOWS) ' Allows using the device's IR transmitter, if available. AddPermission(android.permission.UNINSTALL_SHORTCUT) ' Allows an application to uninstall a shortcut in Launcher. AddPermission(android.permission.UPDATE_DEVICE_STATS) ' Allows an application to update device statistics. AddPermission(android.permission.USE_CREDENTIALS) ' Allows an application to request authtokens from the AccountManager. AddPermission(android.permission.USE_SIP) ' Allows an application to use SIP service. AddPermission(android.permission.VIBRATE) ' Allows access to the vibrator. AddPermission(android.permission.WAKE_LOCK) ' Allows using PowerManager WakeLocks to keep processor from sleeping or screen from dimming. AddPermission(android.permission.WRITE_APN_SETTINGS) ' Allows applications to write the apn settings. AddPermission(android.permission.WRITE_CALENDAR) ' Allows an application to write (but not read) the user's calendar data. AddPermission(android.permission.WRITE_CALL_LOG) ' Allows an application to write (but not read) the user's contacts data. AddPermission(android.permission.WRITE_CONTACTS) ' Allows an application to write (but not read) the user's contacts data. AddPermission(android.permission.WRITE_EXTERNAL_STORAGE) ' Allows an application to write to external storage. AddPermission(android.permission.WRITE_GSERVICES) ' Allows an application to modify the Google service map. AddPermission(android.permission.WRITE_HISTORY_BOOKMARKS) ' Allows an application to write (but not read) the user's browsing history and bookmarks. AddPermission(android.permission.WRITE_PROFILE) ' Allows an application to write (but not read) the user's personal profile data. AddPermission(android.permission.WRITE_SECURE_SETTINGS) ' Allows an application to read or write the secure system settings. AddPermission(android.permission.WRITE_SETTINGS) ' Allows an application to read or write the system settings. AddPermission(android.permission.WRITE_SMS) ' Allows an application to write SMS messages. AddPermission(android.permission.WRITE_SOCIAL_STREAM) ' Allows an application to write (but not read) the user's social stream data. AddPermission(android.permission.WRITE_SYNC_SETTINGS) ' Allows applications to write the sync settings. AddPermission(android.permission.WRITE_USER_DICTIONARY) ' Allows an application to write to the user dictionary. فایل txt : permissions.rar موفق باشید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
