B4A Version: 9.80
Java Version: 8
Parsing code. (0.00s)
Building folders structure. (0.03s)
Compiling code. (0.01s)
Compiling layouts code. (0.00s)
Organizing libraries. (0.00s)
(Android Support Library)
Generating R file. Error
res\values-v20\theme.xml:3: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/Theme.Material'.
DexterFstone 399
سلام به همگی
موقع اجرا ارور میگیرم
B4A Version: 9.80 Java Version: 8 Parsing code. (0.00s) Building folders structure. (0.03s) Compiling code. (0.01s) Compiling layouts code. (0.00s) Organizing libraries. (0.00s) (Android Support Library) Generating R file. Error res\values-v20\theme.xml:3: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/Theme.Material'.راهنمایی کنید دوستان
