ارور ریسایکلر
montazeranmahdi
سلام خدمت اساتید عزیز
خط زیر ارور میده :
lv.Initializer("LV").ListView.StackFromEnd.Build
متن ارور :
** Activity (main) Resume **
*** Service (starter) Create ***
** Service (starter) Start **
Error occurred on line: 156 (Main)
android.view.InflateException: Binary XML file line #5 in database.online.chat:layout/recyclerandfastscroll1: Binary XML file line #5 in database.online.chat:layout/recyclerandfastscroll1: Error inflating class android.support.v7.widget.RecyclerView
Caused by: android.view.InflateException: Binary XML file line #5 in database.online.chat:layout/recyclerandfastscroll1: Error inflating class android.support.v7.widget.RecyclerView
Caused by: java.lang.ClassNotFoundException: android.support.v7.widget.RecyclerView
	at java.lang.Class.classForName(Native Method)
	at java.lang.Class.forName(Class.java:454)
	at android.view.LayoutInflater.createView(LayoutInflater.java:815)
	at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:1006)
	at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:961)
	at android.view.LayoutInflater.rInflate(LayoutInflater.java:1123)
	at android.view.LayoutInflater.rInflateChildren(LayoutInflater.java:1084)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:682)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:534)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:481)
	at wir.hitex.recycler.Hitex_LayoutView.InnerInitialize(Hitex_LayoutView.java:415)
	at ir.Type.Hitex_RecyclerView.Build(Hitex_RecyclerView.java:21)
	at database.online.chat.main._activity_create(main.java:547)
	at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
	at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:351)
	at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
	at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
	at database.online.chat.main.afterFirstLayout(main.java:110)
	at database.online.chat.main.access$000(main.java:22)
	at database.online.chat.main$WaitForLayout.run(main.java:88)
	at android.os.Handler.handleCallback(Handler.java:883)
	at android.os.Handler.dispatchMessage(Handler.java:100)
	at android.os.Looper.loop(Looper.java:237)
	at android.app.ActivityThread.main(ActivityThread.java:7860)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1075)
	... 29 more
در 16 دقیقه قبل، YareGomnam گفته است :
Additional Libraries مگه همون پوشه libraries که تو پووشه نصب بیسیک هست نیست ؟
نه دو نوع پوشه برای لایبرری ها است:
1- Internal Libraries که این کتابخونه های پیشفرض بیسیک هست مثل Phone و .... که بعد از هر آپدیت، بروزرسانی میشن
2- Additional Libraries این برای کتابخونه هایی هست که تو سایتها موجوده و خودتون باید ایجاد کنید.
سلام دوست عزیز
ریسورس های کتابخونه رو دستی اضاف میکنین؟
البته تو هر اروری متن زیر رو دیدید، باید از جتیفایر استفاده کنید(معمولا مشکل حل میشه):
java.lang.ClassNotFoundException: android.support.....
ازمنوی تولز، jetifier رو باز کنید و روی Jetify کلیک کنید.
در 2 ساعت قبل، Salar82 گفته است :
روش کلیک میکنم این پیغام میاد
additional libraries folder not set
از Androidx استفاده میکنید درسته؟
مشکل شما اینه که کتابخونه هایی رو که دانلود میکنید، میریزید تو کتابخونه های داخلی(در محل نصب بیسیک) که این بدترین کار ممکنه.
اولین کاری که باید انجام بدید، اینه که Additional Library رو اضافه کنید و کتابخونه هایی که دانلود کردین، از پوشه کتابخونه در محل نصب به این پوشه منتقل کنید.(آموزش Additional Libraries، زیاد هست. کاری هم نداره)
تازه باید جتیفایر رو باز کنید و اجرا کنید.
نکته مهم زیر رو هم داشته باشید:
*حتما کتابخونه هایی که در محل نصب هستن رو پاک کنید. چون اون کتابخونه هایی که در هر دو پوشه Libraries هستن، جتیفای نمیشن و مشکل رفع نمیشه*
در 17 دقیقه قبل، Salar82 گفته است :
بله اندروید ایکس هست ، چشم فرمایشتون رو انجام میدم ،
در 40 دقیقه قبل، Salar82 گفته است :
ممنونم از راهنماییتون ،
من اینا رو جدا میکنم و مجددا امتحان میکنم و بیسیک رو کتابخونه هاشو حدف میکنم مجددا نصب میکنم که فقط کتابخونه های خودش توش باشن ،بقیه کتابخونه های دانلود شده رو هم یه پوشه به اون نامی که فرمو ید درست میکنم ،  انشاءالله مشکل ارور برطرف بشه
در 51 دقیقه قبل، Salar82 گفته است :
بعد از جتیفای آخرش این پیام میاد ،
چیز مهمی نیست...
نتونسته اون کتابخونه رو جتیفای کنه.
الان کامپایل کنید ببینید مشکل رفع میشه
در 30 دقیقه قبل، Salar82 گفته است :
چیز مهمی نیست...
بله درست شد ، خداخیرتون بده از دیشب درگیرش بودم :53::53::53::ok:
