خطا در کامپایل برنامه
mohsen12
B4A Version: 10.2
Java Version: 11
Parsing code.    (0.03s)
Building folders structure.    (0.03s)
Compiling code.    (0.14s)
Compiling layouts code.    (0.04s)
Organizing libraries.    (0.02s)
    (AndroidX SDK)
Generating R file.    (0.00s)
Compiling generated Java code.    (0.13s)
Convert byte code - optimized dex.    Error
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionBar;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionMenuWrapper$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACActionModeWrapper$1;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACButtonWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACCheckBoxWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACEditTextWrapper;
Uncaught translation error: java.lang.IllegalArgumentException: already added: Lde/amberhome/objects/appcompat/ACFlatButtonWrapper;
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: Translation has been interrupted
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692)
    at com.android.dx.command.dexer.Main.runMultiDex(Main.java:366)
    at com.android.dx.command.dexer.Main.runDx(Main.java:291)
    at com.android.dx.command.dexer.Main.main(Main.java:249)
    at com.android.dx.command.Main.main(Main.java:94)
Caused by: java.lang.InterruptedException: Too many errors
    at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684)
    ... 4 more
میخوام برنامه ام را کامپایل کنم ولی این خطا را میده !!!!
اگه خواستید سورس پروژه را هم میزارم ..
هر کی جواب بده یه دنیا ممنون میشم.
در 10 دقیقه قبل، mohsen12 گفته است :
کتابخونه هاتون با هم تداخل داره عزیز. چه کتابخونه هایی استفاده میکنید؟
در ۱ ساعت قبل، محمدرضا شاهپیری گفته است :
spacer.pngکل کتابخونه هام اینا هستن
در 15 دقیقه قبل، mohsen12 گفته است :
کتابخونه و کدهای متنظر رو دونه دونه کامنت کنید ببینید مشکل از کدومه
در 23 ساعت قبل، محمدرضا شاهپیری گفته است :
تداخل اپ کامپت با ریسایکلرویو هست
میشه کاریش کرد؟
در 22 دقیقه قبل، mohsen12 گفته است :
میشه کاریش کرد؟
بله میشه. فایل xml کتابخونه ریسایکلر رو باز کنید و به آخراش برید و وابستگی appcompat رو ازش حذف کنید
