abolfazl2468 13 ارسال شده در 15 مرداد، 2015 اشتراک گذاری ارسال شده در 15 مرداد، 2015 سلام خدمت دوستان چجوری میتونم تنظیمات برای برنامه بسازم (در حد تغیر فونت و رنگ ) و بعد ذخیره کنم بعد ازش الگو بگیرم ؟ این کد تنظیمات : Sub Process_Globals End Sub Sub Globals Dim cd As ColorDialog Private SeekBar1 As SeekBar Private Label2 As Label Private Button1 As Button Private Spinner1 As Spinner Private Button2 As Button Dim list1 As List Dim j As Int End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("st") Spinner1.AddAll(Array As String("Droid.ttf","byekan.ttf")) If File.Exists(File.DirInternal, "data.txt") = True Then list1 = File.ReadList(File.DirInternal, "data.txt") Label2.TextSize = list1.Get(0) Label2.TextColor = list1.Get(1) SeekBar1.Value = list1.Get(0) Label2.Typeface = Typeface.LoadFromAssets(list1.Get(2)) End If End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub SeekBar1_ValueChanged (Value As Int, UserChanged As Boolean) Label2.TextSize = Value End Sub Sub Button1_Click Dim o As Int o = cd.Show("انتخاب رنگ","ذخیره","لغو","",Null) If o = DialogResponse.POSITIVE Then Label2.TextColor = cd.RGB End If End Sub Sub Spinner1_ItemClick (Position As Int, Value As Object) Label2.Typeface = Typeface.LoadFromAssets(Spinner1.GetItem(Position) ) j = Position End Sub Sub Button2_Click list1.Initialize list1.Add(SeekBar1.Value) list1.Add(cd.RGB) list1.Add(Spinner1.GetItem(j)) StartActivity("s2") File.WriteList(File.DirInternal, "data.txt",list1) ToastMessageShow("تغییرات انجام شد",True) End Sub اینم کد نوشتم که میخوام تنظیمات روش اعمال شه: Sub Process_Globals End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim a As Bitmap Dim panelheight As Int Dim text As String Dim strUtil As StringUtils Dim ht As Float Dim mfont As Typeface Private ScrollView1 As ScrollView End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("s2") text= File.ReadString(File.DirAssets,"s2.txt") mfont=Typeface.LoadFromAssets("byekan.ttf") File.Copy(File.DirAssets,"6.png",File.DirInternal, "6.png") scroll End Sub Sub scroll ScrollView1.Initialize(500dip) Activity.AddView(ScrollView1, 0, 17%y, 100%x, 70%y) panelheight=0 Dim lbltest As Label lbltest.Initialize("lbltest") ScrollView1.Panel.AddView(lbltest,2dip, panelheight, 100%x-5dip, 50dip) lbltest.TextSize=18 lbltest.TextColor=Colors.Blue ht= art (text,lbltest,mfont,20) panelheight=panelheight+ht+25dip panelheight=panelheight+80dip ScrollView1.Panel.Height=panelheight End Sub Sub art(txt As String,leb As Label,font As Typeface,size As Int) As Float Dim before,after As Float Dim Obj1 As Reflector leb.text=txt leb.TextSize=size leb.Gravity=Gravity.CENTER leb.Left=leb.Left leb.Typeface=font ht = strUtil.MeasureMultilineTextHeight(leb , txt) Obj1.Target = leb before = Obj1.RunMethod("getLineHeight") Obj1.Target = leb Obj1.RunMethod3("setLineSpacing", .10, "java.lang.float", 1.5, "java.lang.float") Obj1.Target = leb after = Obj1.RunMethod("getLineHeight") ht = ((after * ht)/before) leb.Height = ht Return ht End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
porya 959 ارسال شده در 15 مرداد، 2015 اشتراک گذاری ارسال شده در 15 مرداد، 2015 سلام میتونی از کتابخونه ای که اقای نیما قبادی درست کردن استفاده کنی هم میتونی باهاش تنظیمات رو ذخیره کنی و هم ازش الگو بگیری اموزش تصویرش هم تو انجمن هست اینم لینکش http://answercenter.ir/thread2044.html لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نیما قبادی 246 ارسال شده در 15 مرداد، 2015 اشتراک گذاری ارسال شده در 15 مرداد، 2015 دوست گرامی جوابتون رو دوستان دارن میدن دوباره یه تاپیک جدا میزنید الان یه اخطار میگیرید تاپیک قبلی پاک میشه تکرار بعدی مساویست با بن =================================== جوابتون هم اینجاست http://answercenter.ir/thread2044.html هرچی توی تاپیک رو که هست انجانم بدی کارت درست میشه کتاب خونه خریداری میکنین فیلم هارو بصورت دقیق میبینید موفق باشید لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
abolfazl2468 13
این کد تنظیمات :
Dim list1 As List
Dim j As Int
Sub Activity_Resume
Sub Button1_Click
Dim o As Int
j = Position
Sub Button2_Click
list1.Initialize
list1.Add(cd.RGB)
StartActivity("s2")
Dim a As Bitmap
Dim text As String
Dim ht As Float
scroll
Sub scroll
panelheight=0
lbltest.TextSize=18
leb.text=txt
leb.TextSize=size
leb.Left=leb.Left
leb.Typeface=font
Obj1.Target = leb
Obj1.Target = leb
Obj1.Target = leb
leb.Height = ht
Return ht
Sub Activity_Resume
