چجوری میتونم تنظیمات برای برنامه بسازم (در حد تغیر فونت و رنگ ) و بعد ازش الگو بگیرم؟
abolfazl2468
سلام خدمت دوستان چجوری میتونم تنظیمات برای برنامه بسازم (در حد تغیر فونت و رنگ ) و بعد ذخیره کنم بعد ازش الگو بگیرم ؟
این کد تنظیمات :
Sub Process_Globals
Dim cd As ColorDialog
Private SeekBar1 As SeekBar
Private Label2 As Label
Private Button1 As Button
Private Spinner1 As Spinner
Private Button2 As Button
Dim list1 As List
Dim j As Int
Activity.LoadLayout("st")
Spinner1.AddAll(Array As String("Droid.ttf","byekan.ttf"))
If File.Exists(File.DirInternal, "data.txt") = True Then
list1 = File.ReadList(File.DirInternal, "data.txt")
Label2.TextSize = list1.Get(0)
Label2.TextColor = list1.Get(1)
SeekBar1.Value = list1.Get(0)
Label2.Typeface = Typeface.LoadFromAssets(list1.Get(2))
Sub Activity_Resume
Sub SeekBar1_ValueChanged (Value As Int, UserChanged As Boolean)
Label2.TextSize = Value
Sub Button1_Click
Dim o As Int
o = cd.Show("انتخاب رنگ","ذخیره","لغو","",Null)
If o = DialogResponse.POSITIVE Then
Label2.TextColor = cd.RGB
Sub Spinner1_ItemClick (Position As Int, Value As Object)
Label2.Typeface = Typeface.LoadFromAssets(Spinner1.GetItem(Position) )
j = Position
Sub Button2_Click
list1.Initialize
list1.Add(SeekBar1.Value)
list1.Add(cd.RGB)
list1.Add(Spinner1.GetItem(j))
StartActivity("s2")
File.WriteList(File.DirInternal, "data.txt",list1)
ToastMessageShow("تغییرات انجام شد",True)
اینم کد نوشتم که میخوام تنظیمات روش اعمال شه:
Sub Process_Globals
Dim a As Bitmap
Dim panelheight As Int
Dim text As String
Dim strUtil As StringUtils
Dim ht As Float
Dim mfont As Typeface
Activity.LoadLayout("s2")
text= File.ReadString(File.DirAssets,"s2.txt")
mfont=Typeface.LoadFromAssets("byekan.ttf")
File.Copy(File.DirAssets,"6.png",File.DirInternal, "6.png")
scroll
Sub scroll
ScrollView1.Initialize(500dip)
Activity.AddView(ScrollView1, 0, 17%y, 100%x, 70%y)
panelheight=0
Dim lbltest As Label
lbltest.Initialize("lbltest")
ScrollView1.Panel.AddView(lbltest,2dip, panelheight, 100%x-5dip, 50dip)
lbltest.TextSize=18
lbltest.TextColor=Colors.Blue
ht= art (text,lbltest,mfont,20)
panelheight=panelheight+ht+25dip
panelheight=panelheight+80dip
ScrollView1.Panel.Height=panelheight
Sub art(txt As String,leb As Label,font As Typeface,size As Int) As Float
Dim before,after As Float
Dim Obj1 As Reflector
leb.text=txt
leb.TextSize=size
leb.Gravity=Gravity.CENTER
leb.Left=leb.Left
leb.Typeface=font
ht = strUtil.MeasureMultilineTextHeight(leb , txt)
Obj1.Target = leb
before = Obj1.RunMethod("getLineHeight")
Obj1.Target = leb
Obj1.RunMethod3("setLineSpacing", .10, "java.lang.float", 1.5, "java.lang.float")
Obj1.Target = leb
after = Obj1.RunMethod("getLineHeight")
ht = ((after * ht)/before)
leb.Height = ht
Return ht
Sub Activity_Resume
سلام میتونی از کتابخونه ای که اقای نیما قبادی درست کردن استفاده کنی هم میتونی باهاش تنظیمات رو ذخیره کنی و هم ازش الگو بگیری اموزش تصویرش هم تو انجمن هست اینم لینکش http://answercenter.ir/thread2044.html
دوست گرامی جوابتون رو دوستان دارن میدن دوباره یه تاپیک جدا میزنید الان یه اخطار میگیرید تاپیک قبلی پاک میشه تکرار بعدی مساویست با بن
جوابتون هم اینجاست
هرچی توی تاپیک رو که هست انجانم بدی کارت درست میشه
کتاب خونه خریداری میکنین
فیلم هارو بصورت دقیق میبینید
