متاسفانه با منو های متریال مشکل داره
بدون هم مشکلی ندارن
هم   JK_MaterialDrawer
و هم
MSMaterialDrawer
هردو رو تست کردم
*** Service (starter) Create ***
** Service (starter) Start **
** Activity (main) Resume **
** Activity (main) Pause, UserClosed = true **
java.lang.IllegalArgumentException: DrawerLayout must be measured with MeasureSpec.EXACTLY.
    at androidx.drawerlayout.widget.DrawerLayout.onMeasure(DrawerLayout.java:1090)
    at android.view.View.measure(View.java:19857)
    at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:6110)
    at android.widget.FrameLayout.onMeasure(FrameLayout.java:185)
    at androidx.appcompat.widget.ContentFrameLayout.onMeasure(ContentFrameLayout.java:146)
    at android.widget.LinearLayout.measureChildBeforeLayout(LinearLayout.java:1464)
    at android.widget.LinearLayout.measureVertical(LinearLayout.java:758)
    at android.widget.LinearLayout.onMeasure(LinearLayout.java:640)
    at com.android.internal.policy.DecorView.onMeasure(DecorView.java:690)
    at android.view.ViewRootImpl.performMeasure(ViewRootImpl.java:2275)
    at android.view.ViewRootImpl.measureHierarchy(ViewRootImpl.java:1339)
    at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1619)
    at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1254)
    at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:6338)
    at android.view.Choreographer$CallbackRecord.run(Choreographer.java:874)
    at android.view.Choreographer.doCallbacks(Choreographer.java:686)
    at android.view.Choreographer.doFrame(Choreographer.java:621)
    at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:860)
    at android.os.Handler.handleCallback(Handler.java:751)
    at android.os.Looper.loop(Looper.java:154)
    at android.app.ActivityThread.main(ActivityThread.java:6161)
    at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:892)
    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:782)
  • پاسخ 102
  • ایجاد شده
  • آخرین پاسخ
بیشترین ارسال‌ها در این موضوع
ارسال‌های محبوب
مشاهده فایل Poolakey با سلام و درود خدمت دوستان عزیز انسرسنتر . برایتان کتابخونه آورده ایم اونم چه کتابخونه ای. پولکی  بله. بازار کتابخونه درون پرداختشو
سلام مرسی آقامحمدرضا عزیز دمتون گرم کمک بزرگی کردین به بچه های B4A 😍
عزیز توی آموزش توضیح داده شده. نسخه بیسیکتون باید ۱۱.۵ به بالا باشه همینطور توی sdk هم باید یه سری تغییرات بدین.قبل از کار با کتابخونه حتما آموزش رو ببینید
تصاویر ارسال شده
در ۱۴۰۱/۵/۲۱ در 17:10، vistamobile گفته است:
سلام دوستان . یه خسته نباشید حسابی هم خدمت آقای شاهپیری عزیز. من وقتی خط :
#Extends : androidx.appcompat.app.AppCompatActivity
رو به پروژه اضافه میکنم، کلا اکتیویتی خرید باز نمیشه و برنامه متوقف میشه. سورس خودتون همچین مشکلی نداره. ولی واسه من اینجوریه. حین کامپایل هم اروری ندارم. ولی وقتی لاگ میگیرم، خطا به این شکله.
سلام مختارجان. عزیز توی کتابخونه از appcompat استفاده شده. حتما تم برنامه باید appcompat باشه. تو سورس میتونی ببینی. اما در کل تو منیفست کد زیر رو بزاری اکی هست. البته تم پیشفرض رو باید حذف کنی
SetApplicationAttribute(android:theme, "@style/Theme.AppCompat.Light.NoActionBar")
در ۱۴۰۱/۵/۲۱ در 20:59، محمدرضا شاهپیری گفته است:
سلام داداش گل. مثل همیشه عالی. خودم پوشه ها رو مقایسه کردم و متوجه شدم ، در کل کتابخونه ساده ایه و عالی شده. فقط یه ذره بدقلقه. 😅
من تست میکنم همینجا خبر میدم. ممنونم بابت تمام زحماتت 🙏
در ۱۴۰۱/۵/۲۱ در 19:56، Ebi99 گفته است:
سلام. لطفا یک سورس که دوتا کتابخونه توش استفاده شده رو پیوست کنید به همراه کتابخانه های استفاده شده.
من راه اندازی کردم و خرید موفقه ، ولی تو بازی هیچ سکه ای اضافه نشد. یعنی تایید خرید به بازی برنگشت تا سکه اضافه بشه. دلیلش چیه احتمالا؟
به جای اون   "buy_100_coin"   ای دی خرید بازار رو گذاشتم، کلا برنامه متوقف شد و پرداکت ای دی رو که میزارم هیچ اتفاقی نمیافته.
پ ن :استرینگ  buy_100_coin  تو سورس من هم به همین نامه
Private Sub poolakey_purchaseSucceed(purchaseInfo As PurchaseInfo)
	If purchaseInfo.payload=="buy_100_coin" Then
		ToastMessageShow("سکه افزوده شد",False)
		Main.sekke=Main.sekke + 100
		coiner.Text=Main.sekke
		File.WriteString(File.DirInternal,"raad.txt",Main.sekke)
		poolakey.consumeProduct(purchaseInfo.purchaseToken)
		'	CallSubDelayed2(Me,"consumeProduct",purchaseInfo.purchaseToken)
در ۱۴۰۱/۵/۲۲ در 17:07، vistamobile گفته است:
خط زیر رو برای چی کامنت کردین؟
در ۱۴۰۱/۵/۲۲ در 17:33، محمدرضا شاهپیری گفته است:
والا داداش این غیر فعاله دقت کنی . کلا برگشت خرید رو نمیگیره. ایراد از مد نویسی بندس ولی نمیدونم کجاشه.  من اینو از کامنت درآوردم باز همونجوری بود
در ۱۴۰۱/۵/۲۲ در 18:10، vistamobile گفته است:
سورس پیشفرض رو با اطلاعات خودتون جایگزین کنید(پکیج نیم و ساین کی برنامه و کلید بازار) و تست کنید. در کل کتابخونه چیز خاصی نداره واقعا. طبق سورس پیش برید نباید موردی باشه
ممنون بخاطر بروزرسانی کتابخونه مشکلات قبلی تقریبا حل شده.عالی...
فقط یه درخواست نمیشه از fragment 1.3.6 به fragment1.2.5 انتقال بدین؟ یا حداقل راهنمایی کنید چطوری بقیه کتابخونه ها رو با این هماهنگ کنم. بخدا هرچقدر گشتم آموزشی چیزی پیدا نکردم
داداش من توی همین دستور شرطی که این خط کد در ساب مربوطه هست یه درستور اضافه کردن به دیتابیس sqlite گذاشتم که به هیچ وجه کار نمیکنه ولی در ساب های اصلی برنامه کار میکنه
در ۱۴۰۱/۵/۲۴ در 17:26، 73amirrrco گفته است:
عزیز توی آموزش ویدویی هم این موضوع توضیح داده شده. توی متد poolakey_purchaseSucceed شما نباید کدی بنویسید. یه تابع بنویسید و کدهاتون رو اونجا بنویسید و بعد با دستور CallSubDelayed2 تابع رو صدا بزنید.
در ۱۴۰۱/۵/۲۴ در 10:49، fz km گفته است:
خیر حتما باید همین نسخه باشه. خطارو پیوست کنید ببینم چیه
در ۱۴۰۱/۵/۲۴ در 08:32، محمدرضا شاهپیری گفته است:
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.exam.plus/com.poolakey.activity.PaymentActivity}: java.lang.IllegalArgumentException: Can only use lower 16 bits for requestCode
    at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2668)
    at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2729)
    at android.app.ActivityThread.-wrap12(ActivityThread.java)
    at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1480)
    at android.os.Handler.dispatchMessage(Handler.java:102)
    at android.app.ActivityThread.main(ActivityThread.java:6138)
    at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893)
    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783)
Caused by: java.lang.IllegalArgumentException: Can only use lower 16 bits for requestCode
    at androidx.fragment.app.FragmentActivity.checkForValidRequestCode(FragmentActivity.java:714)
    at androidx.fragment.app.FragmentActivity.startActivityForResult(FragmentActivity.java:672)
    at androidx.core.app.ActivityCompat.startActivityForResult(ActivityCompat.java:234)
    at androidx.activity.ComponentActivity$2.onLaunch(ComponentActivity.java:210)
    at androidx.activity.result.ActivityResultRegistry$3.launch(ActivityResultRegistry.java:226)
    at androidx.activity.result.ActivityResultLauncher.launch(ActivityResultLauncher.java:47)
    at ir.cafebazaar.poolakey.billing.connection.ServiceBillingConnection$purchase$intentFire$1.invoke(ServiceBillingConnection.kt:173)
    at ir.cafebazaar.poolakey.billing.connection.ServiceBillingConnection$purchase$intentFire$1.invoke(ServiceBillingConnection.kt:45)
    at ir.cafebazaar.poolakey.billing.purchase.PurchaseFunction.launchBuyIntentV3(PurchaseFunction.kt:69)
    at ir.cafebazaar.poolakey.billing.purchase.PurchaseFunction.function(PurchaseFunction.kt:41)
    at ir.cafebazaar.poolakey.billing.connection.ServiceBillingConnection.purchase(ServiceBillingConnection.kt:219)
    at ir.cafebazaar.poolakey.billing.connection.ServiceBillingConnection.purchase(ServiceBillingConnection.kt:177)
    at ir.cafebazaar.poolakey.BillingConnection$purchase$2.invoke(BillingConnection.kt:86)
    at ir.cafebazaar.poolakey.BillingConnection$purchase$2.invoke(BillingConnection.kt:25)
    at ir.cafebazaar.poolakey.BillingConnection.runOnCommunicator(BillingConnection.kt:163)
    at ir.cafebazaar.poolakey.BillingConnection.purchase(BillingConnection.kt:85)
    at ir.cafebazaar.poolakey.Payment.purchaseProduct(Payment.kt:91)
    at com.poolakey.wrapper.PoolakeyWrapper.purchaseProduct(PoolakeyWrapper.kt:52)
    at com.poolakey.activity.PaymentActivity.onCreate(PaymentActivity.kt:20)
    at android.app.Activity.performCreate(Activity.java:6785)
    at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1146)
    at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2621)
با فراگمنت 1.3.6 مشکلی پیش نمیاد و کار میکنه ولی این رو که جایگزین میکنم یه کتابخونه دیگم کار نمیکنه و ارور میده(اونم با فراگمنت1.2.5 کار میکنه).
سلام خسته نباشید جناب شاهپیری، مشابه ویدئو مراحل رو انجام دادم و با خطای زیر مواجه شدم :
ObfuscatorMap.txt file created in Objects folder.
Compiling layouts code.    (0.00s)
Organizing libraries.    Error
Could not find a part of the path 'D:\Anywhere Software\resources_06_21\SDK Answercenter\extras\b4a_remote\androidx\annotation\annotation-experimental\1.1.0\annotation-experimental-1.1.0.pom'.
درحالی که annotation-experimental وجود داره و مشکل با کلین کردن پروژه و رفرش کتابخانه ها رفع نشد
آپدیت : در نوشتن فایل installed-components اشتباه انجام داده بودم ، مشکل رفع شد.
  • 2 هفته بعد...
سلام دوستان من وقتی فایل های sdk که جناب آقای شاهییری گفتن را توی SDK خودم تغیر میدم خطا زیر رخ میده لطفا راهنمایی کنید چیکار کنم؟
B4A Version: 11.80
Parsing code.    (0.00s)
	Java Version: 11
Building folders structure.    (0.01s)
Compiling code.    (0.02s)
Length cannot be less than zero.
Parameter name: length
  • 3 هفته بعد...
PushPoleسلام
بنده یه بازی ساختم.
از کتابخانه پولکی استفاده کردم و زمان کامپایل خطای زیر رو نمایش میده.
B4A Version: 11.80
Parsing code.    (0.38s)
	Java Version: 11
Building folders structure.    (0.00s)
Compiling code.    (0.35s)
Organizing libraries.    (0.01s)
	(AndroidX SDK)
Compiling resources    (0.87s)
Linking resources    (0.75s)
Compiling generated Java code.    (3.41s)
Finding libraries that need to be dexed.    (0.01s)
Dex code    (3.33s)
Dex merge    Error
Error in d:\amin\source\b4a config\sdk\tools\..\extras\b4a_local\unpacked-poolakey-63795917240000\jars\kotlin-stdlib-1.7.10.zip:classes.dex:
Type kotlin.ArrayIntrinsicsKt is defined multiple times: d:\amin\source\b4a config\sdk\tools\..\extras\b4a_local\unpacked-poolakey-63795917240000\jars\kotlin-stdlib-1.7.10.zip:classes.dex, D:\amin\source\b4a config\SDK\tools\..\extras\b4a_local\unpacked-kotlin-stdlib-1.6.10-63792602270000\dex_v1\kotlin-stdlib-1.6.10.zip:classes.dex
Compilation failed
Exception in thread "main" java.lang.RuntimeException: com.android.tools.r8.CompilationFailedException: Compilation failed to complete, origin: d:\amin\source\b4a config\sdk\tools\..\extras\b4a_local\unpacked-poolakey-63795917240000\jars\kotlin-stdlib-1.7.10.zip:classes.dex
	at com.android.tools.r8.internal.Mi.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:98)
	at com.android.tools.r8.D8.main(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:4)
Caused by: com.android.tools.r8.CompilationFailedException: Compilation failed to complete, origin: d:\amin\source\b4a config\sdk\tools\..\extras\b4a_local\unpacked-poolakey-63795917240000\jars\kotlin-stdlib-1.7.10.zip:classes.dex
	at Version.fakeStackEntry(Version_3.3.11-dev.java:0)
	at com.android.tools.r8.internal.Mi.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:75)
	at com.android.tools.r8.internal.Mi.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:28)
	at com.android.tools.r8.internal.Mi.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:27)
	at com.android.tools.r8.internal.Mi.b(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:2)
	at com.android.tools.r8.D8.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:22)
	at com.android.tools.r8.D8.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:17)
	at com.android.tools.r8.internal.Mi.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:85)
	... 1 more
Caused by: com.android.tools.r8.internal.f: Type kotlin.ArrayIntrinsicsKt is defined multiple times: d:\amin\source\b4a config\sdk\tools\..\extras\b4a_local\unpacked-poolakey-63795917240000\jars\kotlin-stdlib-1.7.10.zip:classes.dex, D:\amin\source\b4a config\SDK\tools\..\extras\b4a_local\unpacked-kotlin-stdlib-1.6.10-63792602270000\dex_v1\kotlin-stdlib-1.6.10.zip:classes.dex
	at com.android.tools.r8.internal.WR.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:14)
	at com.android.tools.r8.internal.WR.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:22)
	at com.android.tools.r8.internal.kM.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:36)
	at com.android.tools.r8.internal.kM.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:10)
	at java.base/java.util.concurrent.ConcurrentHashMap.merge(ConcurrentHashMap.java:2048)
	at com.android.tools.r8.internal.kM.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:6)
	at com.android.tools.r8.graph.q2$a.e(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:4)
	at com.android.tools.r8.dex.b.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:105)
	at com.android.tools.r8.dex.b.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:28)
	at com.android.tools.r8.D8.d(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:582)
	at com.android.tools.r8.D8.c(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:1)
	at com.android.tools.r8.internal.Mi.a(R8_3.3.11-dev_a350433e5961361fb5d2c0c09f5c50272fe5d0325415e1337df07a674f97f77e:24)
	... 5 more
جناب استاد شاهپیری فرمودند: خطایی کا گذاشتین به نظر از تداخل کتابخونه ها هست. یه کتابخونه دیگه از کاتلین استفاده کرده. پید کنید و از فایل xml وابستگیشون حذف کنید
بنده از کتابخانه های زیر استفاده کردم :
https://s6.uupload.ir/files/library_sh25.jpg
(چون تصویر بالا رو در اینجا نمایش نمیداد ناچارا لینکش رو گذاشتم)
کتابخانه هایی که جدید هستن و حس کردم شاید کاتلین باشن (از جمله کتابخانه های PushPole ، XUI و JpegUtils) رو جهت تست غیرفعال کردم اما کماکان خطا پابرجا بود.
بنده اصلا نمیدونم چطور باید مشکل رو پیدا کنم.
ممنون میشم اگر بلدید راهنماییم کنید. 🙏
در تکمیل پیام قبلیم ،
تست کردم و متوجه شدم که کتابخانه های زیر موجب بروز این مشکل زمان کامپایل میشن :
OkHttp
OkHttpUtils2
اما نمیدونم دقیقا چطور باید مشکل رو برطرف کنم. 🤔
طبق پست زیر هم عمل کردم و دو کتابخانه OkHttp و OkHttpUtils2 هرچی وابستگی داشتن رو پاک کردم اما مشکل حل نشد.
https://answercenter.ir/topic/37990-تداخل-کتابخانه-ها-نجوا-بیسیک-فور-اندروید/
در ۱۴۰۱/۶/۲۶ در 19:15، fun_code گفته است:
OkHttp
OkHttpUtils2
فایل OkHttp.xml رو باز کنید و خط زیر رو حذف کنید
1 ساعت قبل، محمدرضا شاهپیری گفته است:
سلام استاد
کتابخانه okhttp مورد استفاده بنده نسخه 1.31 هست و در فایل xml اون اصلا این خط که شما فرمودین نیست.
و من کلا وابستگی ها رو پاک کردم.
اما الان آپدیت میکنم و طبق دستور شما عمل میکنم.
ممنون استاد عزیز 🙏
الان چک کردم و متوجه شدم که یکسری از کتابخانه ها رو از دایرکتوری اصلی که نسخه آخر B4A در اون قرار داره بارگزاری میشن.
18 ساعت قبل، محمدرضا شاهپیری گفته است:
سلام استاد
بسیار ممنون بابت راهنماییتون 🙏
مشکل حل شد و بخوبی خریدها انجام میشن.
انشالله سالم و تندرست باشید
  • 3 ماه بعد...
با سلام. تشکر از آقای شاهپیری. برای قسمت تخفیف پویا باید چیکار کنیم. ممنون میشم در پیاده سازی اون راهنمایی بفرمایید
به گفتگو بپیوندید
ارسال پاسخ به این موضوع ...
