MR.B4A 270 ارسال شده در 18 تیر اشتراک گذاری ارسال شده در 18 تیر با استفاده از این سورس کابردی میتوانید یک جدول بسیار کاربردی برای برنامه تان بسازید سورس: ابتدا کی کلاس تعریف کرده و کدهای زیر را در آن کپی میکنید: Sub Class_Globals Private StringUtils1 As StringUtils Private SV As ScrollView Private Header As Panel Private Callback As Object Private Event As String Private SelectedRow As Int Private Data As List Private LabelsCache As List Private minVisibleRow, maxVisibleRow As Int Private visible As Boolean Private visibleRows As Map Private NumberOfColumns, ColumnWidth As Int Public RowHeight, HeaderColor, TableColor, FontColor, HeaderFontColor As Int Public FontSize As Float Type RowCol (Row As Int, Col As Int) Public Alignment As Int Public SelectedDrawable(), Drawable1(), Drawable2() As Object 'Table settings HeaderColor = Colors.Gray RowHeight = 30dip TableColor = Colors.LightGray FontColor = Colors.Black HeaderFontColor = Colors.White FontSize = 14 Alignment = Gravity.CENTER 'change to Gravity.LEFT or Gravity.RIGHT for other alignments. End Sub Public Sub Initialize (CallbackModule As Object, EventName As String, vNumberOfColumns As Int) SV.Initialize2(0, "SV") SV.Panel.Color = TableColor Callback = CallbackModule Event = EventName innerClearAll(vNumberOfColumns) End Sub 'Clears the table Public Sub ClearAll innerClearAll(NumberOfColumns) End Sub 'Sets the columns widths. 'Example: <code>Table1.SetColumnsWidths(Array As Int(100dip, 30dip, 30dip, 100%x - 160dip))</code> Public Sub SetColumnsWidths(Widths() As Int) Dim v As View For i = 0 To Widths.Length - 1 v = Header.GetView(i) v.Width = Widths(i) - 1dip If i > 0 Then v.Left = Header.GetView(i-1).Left + Widths(i-1) + 1dip End If Next Dim lbls() As Label For i = 0 To visibleRows.Size - 1 lbls = visibleRows.GetValueAt(i) For lbl = 0 To lbls.Length - 1 lbls(lbl).SetLayout(Header.GetView(lbl).Left, lbls(lbl).Top, _ Header.GetView(lbl).Width, RowHeight) Next Next End Sub Private Sub innerClearAll(vNumberOfColumns As Int) For i = SV.Panel.NumberOfViews -1 To 0 Step -1 SV.Panel.RemoveViewAt(i) Next NumberOfColumns = vNumberOfColumns Dim Drawable1(NumberOfColumns) As Object Dim Drawable2(NumberOfColumns) As Object Dim SelectedDrawable(NumberOfColumns) As Object For i = 0 To NumberOfColumns - 1 Dim cd1, cd2, cd3 As ColorDrawable cd1.Initialize(Colors.White, 0) cd2.Initialize(0xFF98F5FF, 0) cd3.Initialize(0xFF007FFF, 0) Drawable1(i) = cd1 Drawable2(i) = cd2 SelectedDrawable(i) = cd3 Next SV.Panel.Height = 0 SelectedRow = -1 minVisibleRow = -1 maxVisibleRow = 0 Data.Initialize LabelsCache.Initialize visibleRows.Initialize SV.ScrollPosition = 0 DoEvents SV.ScrollPosition = 0 For i = 1 To 80 'fill the cache to avoid delay on the first touch LabelsCache.Add(CreateNewLabels) Next If visible Then SV_ScrollChanged(0) End If End Sub Private Sub SV_ScrollChanged(Position As Int) Dim currentMin, currentMax As Int currentMin = Max(0, Position / RowHeight - 30) currentMax = Min(Data.Size - 1, (Position + SV.Height) / RowHeight + 30) If minVisibleRow > -1 Then If minVisibleRow < currentMin Then 'need to hide the upper rows For I = minVisibleRow To Min(currentMin - 1, maxVisibleRow) HideRow(I) Next Else If minVisibleRow > currentMin Then 'need to show the upper rows For I = currentMin To Min(minVisibleRow - 1, currentMax) ShowRow(I) Next End If If maxVisibleRow > currentMax Then 'need to hide the lower rows For I = maxVisibleRow To Max(currentMax + 1, minVisibleRow) Step -1 HideRow(I) Next Else If maxVisibleRow < currentMax Then 'need to show the lower rows For I = currentMax To Max(maxVisibleRow + 1, currentMin) Step -1 ShowRow(I) Next End If End If minVisibleRow = currentMin maxVisibleRow = currentMax End Sub 'Adds the tablet to the activity. Public Sub AddToActivity(Act As Activity, Left As Int, Top As Int, Width As Int, Height As Int) visible = True Header.Initialize("") Header.Color = TableColor Act.AddView(Header, Left, Top , Width, RowHeight) Act.AddView(SV, Left, Top + RowHeight, Width, Height - RowHeight) ColumnWidth = SV.Width / NumberOfColumns SV_ScrollChanged(0) End Sub 'Adds a row to the table 'Example:<code>Table1.AddRow(Array As String("aaa", "ccc", "ddd", "eee"))</code> Public Sub AddRow(Values() As String) If Values.Length <> NumberOfColumns Then Log("Wrong number of values.") Return End If Data.Add(Values) Dim lastRow As Int lastRow = Data.Size - 1 If lastRow < (SV.ScrollPosition + SV.Height) / RowHeight + 1 Then ShowRow(lastRow) End If SV.Panel.Height = Data.Size * RowHeight End Sub Private Sub ShowRow(row As Int) If visibleRows.ContainsKey(row) Then Return 'Log("ShowRow: " & row) Dim lbls() As Label Dim values() As String lbls = GetLabels(row) values = Data.Get(row) visibleRows.Put(row, lbls) Dim rowColor() As Object If row = SelectedRow Then rowColor = SelectedDrawable Else If row Mod 2 = 0 Then rowColor = Drawable1 Else rowColor = Drawable2 End If For I = 0 To lbls.Length - 1 SV.Panel.AddView(lbls(I), Header.GetView(I).Left, row * RowHeight, Header.GetView(I).Width, _ RowHeight - 1dip) lbls(I).Text = values(I) lbls(I).Background = rowColor(I) Next End Sub Private Sub IsRowVisible(Row As Int) As Boolean Return Row < (SV.ScrollPosition + SV.Height) / (RowHeight + 1) And _ Row > SV.ScrollPosition / RowHeight End Sub Private Sub HideRow (Row As Int) 'Log("HideRow: " & row) Dim lbls() As Label lbls = visibleRows.Get(Row) If lbls = Null Then Log("HideRow: (null) " & Row) Return End If For I = 0 To lbls.Length - 1 lbls(I).RemoveView Next visibleRows.Remove(Row) LabelsCache.Add(lbls) End Sub Private Sub GetLabels(Row As Int) As Label() Dim lbls() As Label If LabelsCache.Size > 0 Then 'Log("from cache") lbls = LabelsCache.Get(LabelsCache.Size - 1) LabelsCache.RemoveAt(LabelsCache.Size - 1) Else lbls = CreateNewLabels End If For I = 0 To lbls.Length - 1 Dim rc As RowCol rc = lbls(I).Tag rc.Row = Row Next Return lbls End Sub Private Sub CreateNewLabels As Label() Dim lbls(NumberOfColumns) As Label For I = 0 To NumberOfColumns - 1 Dim rc As RowCol rc.Col = I Dim l As Label l.Initialize("cell") l.Gravity = Alignment l.TextSize = FontSize l.TextColor = FontColor l.Tag = rc lbls(I) = l Next Return lbls End Sub 'Set the headers values 'Example:<code>Table1.SetHeader(Array As String("Col1", "Col2", "Col3"))</code> Public Sub SetHeader(Values() As String) For I = Header.NumberOfViews - 1 To 0 Step -1 Header.RemoveViewAt(I) Next For I = 0 To NumberOfColumns - 1 Dim l As Label l.Initialize("header") l.Gravity = Gravity.CENTER l.TextSize = FontSize l.Color = HeaderColor l.TextColor = HeaderFontColor l.Text = Values(I) l.Tag = I Header.AddView(l, ColumnWidth * I, 0, ColumnWidth - 1dip, RowHeight) Next End Sub Private Sub Cell_Click Dim rc As RowCol Dim l As Label l = Sender rc = l.Tag SelectRow(rc.Row) If SubExists(Callback, Event & "_CellClick") Then CallSub3(Callback, Event & "_CellClick", rc.Col, rc.Row) End If End Sub Private Sub Header_Click Dim l As Label Dim col As Int l = Sender col = l.Tag If SubExists(Callback, Event & "_HeaderClick") Then CallSub2(Callback, Event & "_HeaderClick", col) End If End Sub 'Gets the value of the given cell. Public Sub GetValue(Col As Int, Row As Int) Dim values() As String values = Data.Get(Row) Return values(Col) End Sub 'Sets the value of the given cell. Public Sub SetValue(Col As Int, Row As Int, Value As String) Dim values() As String values = Data.Get(Row) values(Col) = Value If visibleRows.ContainsKey(Row) Then Dim lbls() As Label lbls = visibleRows.Get(Row) lbls(Col).Text = Value End If End Sub Private Sub SelectRow(Row As Int) Dim prev As Int prev = SelectedRow SelectedRow = Row 'remove the color of previously selected row If prev > -1 Then If visibleRows.ContainsKey(prev) Then HideRow(prev) ShowRow(prev) End If End If SelectedRow = Row For col = 0 To NumberOfColumns - 1 If visibleRows.ContainsKey(SelectedRow) Then HideRow(SelectedRow) ShowRow(SelectedRow) End If Next End Sub 'Makes the given row visible. Public Sub JumpToRow(Row As Int) SV.ScrollPosition = Row * RowHeight End Sub 'Clears the previous table and loads the CSV file to the table. 'You should first add the Table to the activity before calling this method. Public Sub LoadTableFromCSV(Dir As String, Filename As String, HeadersExist As Boolean) Dim List1 As List Dim h() As String If HeadersExist Then Dim headers As List List1 = StringUtils1.LoadCSV2(Dir, Filename, ",", headers) Dim h(headers.Size) As String For i = 0 To headers.Size - 1 h(i) = headers.Get(i) Next Else List1 = StringUtils1.LoadCSV(Dir, Filename, ",") Dim firstRow() As String firstRow = List1.Get(0) Dim h(firstRow.Length) For i = 0 To firstRow.Length - 1 h(i) = "Col" & (i + 1) Next End If innerClearAll(h.Length) ColumnWidth = SV.Width / NumberOfColumns SetHeader(h) For i = 0 To List1.Size - 1 Dim row() As String row = List1.Get(i) AddRow(row) Next End Sub 'Saves the table to a CSV file. Public Sub SaveTableToCSV(Dir As String, Filename As String) Dim headers(NumberOfColumns) As String For i = 0 To headers.Length - 1 Dim l As Label l = Header.GetView(i) headers(i) = l.Text Next StringUtils1.SaveCSV2(Dir, Filename, ",", Data, headers) سپس این کدها را در اکتیویتی که میخواهید جدول را در آن پیاده کنید، بنویسید: Sub Globals Dim Table1, Table2 As Table End Sub Sub Activity_Create(FirstTime As Boolean) Table1.Initialize(Me, "Table1", 4)' فراخوانی جدول Table1.AddToActivity(Activity, 0, 0dip, 100%x, 50%y) ' مقدار دهی به اندازه برنامه در اکتیویتی Table1.SetHeader(Array As String("سربرگ", "سربرگ 2", "سربرگ 3", "سربرگ 4"))'تنظیم سربرگ ها به هر اندازه که دوست دارید با آرایه میتونید For i=0 To 20 Table1.AddRow(Array As String("زیر مجموعه: " & i, "MR.", "B4A", "basic4android"))' و زیر مجموعه سر برگ ها همان ROW به اندازه هدر ها Next Table1.SetColumnsWidths(Array As Int(100dip, 30dip, 130dip, 100%x - 260dip))'اندازه هر بخش به اندازه هدر ها Activity.AddMenuItem("پریدن به 5", "Jump1")' منو برای پرش به قسمت از جدول Activity.AddMenuItem("پریدن به 0", "Jump2")' منو برای پرش به قسمت از جدول Table2.Initialize(Me, "Table2", 0)' Table2.AddToActivity(Activity, 0, 50%y, 100%x, 40%y)'مقدار دهی به اندازه برنامه در اکتیویتی Table2.LoadTableFromCSV(File.DirAssets, "citylist.csv", True)' فایل اکسل End Sub Private Sub t_Tick OpenLink("") End Sub Sub OpenLink(url As String) Dim i As Intent i.Initialize(i.ACTION_VIEW, url) StartActivity(i) End Sub 'لینک دانلود در این بخش توسط مرورگر باز میشود Sub Jump1_Click Table1.JumpToRow(5)' End Sub Sub Jump2_Click Table1.JumpToRow(0)' End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub Table2_CellClick (Col As Int, Row As Int) Log("(Table2) CellClick: " & Col & " , " & Row) Activity.Title = Table2.GetValue(Col, Row) End Sub Sub Table1_CellClick (Col As Int, Row As Int) Log("CellClick: " & Col & " , " & Row) Activity.Title = Table1.GetValue(Col, Row) End Sub Sub Table1_HeaderClick (Col As Int) Log("HeaderClick: " & Col) End Sub طراح و تهیه کننده: مرتضی صباغی MR.B4A لینک کانال ایتا: https://eitaa.com/basic4androidlan لینک کانال روبیکا: https://web.rubika.ir/#c=c0DYTXf0c992f816317cf4280db0333a لینک کانال تلگرام: https://t.me/programmingwithb4a لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
