سورس انیمیشن ضبط کردن در بیسیک فور اندروید
MR.B4A
این سورس را میخواهیم بسازیم:
https://aparat.com/v/osgpkrg
با استفاده از این سورس میتوانید یک افکت انیمیشنی بسیار زیبا به برنامه خود دهید.
سورس
#Region  Project Attributes
	#ApplicationLabel: Animation Wave
	#VersionCode: 1
	#VersionName: 1.00
#End Region
#Region  Activity Attributes
	#FullScreen: true
	#IncludeTitle: false
	#Extends :  androidx.appcompat.app.AppCompatActivity
#End Region
	#MultiDex:true
	Dim WaveView As AXWaveView
	Dim LineWaveView As AXLineWaveView
	Dim chk,chk2 As CheckBox
	Private Panel1 As Panel
	Activity.Color = 0xFF1C2229
	If File.Exists(File.DirInternal,"db.db")=False Then
		File.Copy(File.DirAssets,"db.db",File.DirInternal,"db.db")
	Dim Seekbar As ACSeekBar
	Seekbar.Initialize("Seekbar")
	Activity.AddView(Seekbar,16dip,16dip,100%x-32dip,32dip)
	WaveView.Initialize
	Dim Size As Int = 250dip
	Activity.AddView(WaveView,50%x - (Size/2), 50%y - (Size/2) , Size, Size)
	InitWaveView
	Dim MicImage As ImageView
	MicImage.Initialize("")
	Size = 64dip
	Activity.AddView(MicImage,50%x - (Size/2), 50%y - (Size/2) , Size, Size)
	Dim BD As BitmapDrawable
	BD.Initialize(LoadBitmap(File.DirAssets,"mic.png"))
	Dim AC As AppCompat
	AC.SetDrawableTint(BD,Colors.White)
	MicImage.Background = BD
	LineWaveView.Initialize
	Activity.AddView(LineWaveView,0,100%y-36dip,100%x,36dip)
	InitLineWaveView
	chk.Initialize("RedState")
	chk.TextColor = Colors.White
	chk.Checked = False
	Activity.AddView(chk , 16dip , Seekbar.Top + Seekbar.Height + 20dip , 140dip , 40dip)
	chk.Text = "Red State"
	chk2.Initialize("WaveEnabled")
	chk2.TextColor = Colors.White
	chk2.Checked = True
	Activity.AddView(chk2 , 16dip , chk.Top + chk.Height + 20dip , 140dip , 40dip)
	chk2.Text = "WaveEnabled"
	Panel1.Initialize("")
	Activity.AddView(Panel1,0,0,100%x,100%y)
	Panel1.Visible=False
Private Sub activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
	If KeyCode=KeyCodes.KEYCODE_BACK Then
		If Panel1.Visible=True Then
		Return True
Private Sub RedState_CheckedChange(Checked As Boolean)
	If chk2.Checked = False Then chk2.Checked = True
	WaveView.PrepareToRemove(Checked)
Private Sub WaveEnabled_CheckedChange(Checked As Boolean)
	WaveView.PrepareToRemoveWaveEnabled = Not(Checked)
	Dim st As AXWeavingState = WaveView.CurrentState
	st.SupportWaves = Checked
	WaveView.Invalidate
Private Sub InitWaveView
		Dim State1 As AXWeavingState
	State1.Initialize3(1,WaveView.CreateRadialShader(200,0xff2BCEFF,0xff0976E3))
	State1.Width = WaveView.Width + 20dip
	State1.Height = State1.Width
	WaveView.AddState(1,State1)
	Dim State2 As AXWeavingState
	State2.Initialize(2,WaveView.CreateRadialShader(200,0xff12B522,0xff00D6C1),"WaveState2")
	State2.Width = WaveView.Width + 20dip
	State2.Height = State2.Width
	WaveView.AddState(2,State2)
	WaveView.SetState(1)
	WaveView.CircleEnabled = True
	WaveView.Amplitude = -1
	Dim Reflection As Reflector
	Reflection.Target = WaveView
	Reflection.SetOnClickListener("Wave_Click")
	WaveView.PrepareToRemoveColor = Colors.Red
	WaveView.PrepareToRemoveSize = 250dip
	WaveView.PrepareToRemoveAngle = 45.0f
	WaveView.PrepareToRemoveShader = WaveView.CreateLinearShader(350dip,0xFFD54141, 0xFFF76E7E,Colors.Transparent)
	WaveView.PrepareToRemoveWaveEnabled = False
Private Sub WaveState2_UpdateTargets (State As AXWeavingState)
	State.TargetX = 0.2f + 0.1f * Rnd(1,100) / 100
	State.TargetY = 0.7f + 0.1f * Rnd(1,100) / 100
Private Sub Wave_Click (Tag As Object)
	Dim State As AXWeavingState = WaveView.CurrentState
	If State.State = 1 Then
		WaveView.SetState(2)
		LineWaveView.SetState(2)
		SetNavigationBarColor(0xff00D6C1)
		LineWaveView.SetState(1)
		SetNavigationBarColor(0xff0976E3)
Private Sub Seekbar_ValueChanged (Value As Int, UserChanged As Boolean)
	WaveView.Amplitude = Value * WaveView.MAX_AMPLITUDE / 100
	LineWaveView.Amplitude = Value * LineWaveView.MAX_AMPLITUDE / 100
Private Sub InitLineWaveView
	Dim State1 As AXLineWeavingState
	State1.Initialize3(1,WaveView.CreateRadialShader(200,0xff0976E3,0xff0976E3))
	LineWaveView.AddState(1,State1)
	Dim State2 As AXLineWeavingState
	State2.Initialize3(2,WaveView.CreateRadialShader(200,0xff00D6C1,0xff00D6C1))
	LineWaveView.AddState(2,State2)
	LineWaveView.MaxAlpha = 120
	LineWaveView.MainWaveEnabled = False
Sub Activity_Resume
Public Sub SetNavigationBarColor (NewColor As Int)
	Dim sdk As Phone
	If sdk.SdkVersion >= 21 Then
		Dim j1 As JavaObject
		j1.InitializeContext
		j1.RunMethodJO("getWindow",Null) _
			.RunMethod("setNavigationBarColor",Array (NewColor))
تهیه و تنظیم
مرتضی صباغی
MR.B4A
لینک کانال ایتا: https://eitaa.com/basic4androidlan
لینک کانال تلگرام: https://t.me/programmingwithb4a
