سورس xCustom در بیسیک فور اندروید
MR.B4A
یک لیست ویوی بسیار زیبا و مدرن
با قابلیت کلیک
سورس:
⭕ صفحه اول
	Dim Bitmap As Bitmap
	Private xui As XUI
	Private ImageView1 As B4XView
	Private T As Label
	Private Button1 As Button
	Private Label1  As Label
	Private CLV As CustomListView
	Private Panel1 As Panel
	Private Button2 As Button
	Dim Counter As Int
	Activity.LoadLayout("Layout")
Private Sub activity_PermissionResult (Permission As String, Result As Boolean)
Private Sub CreateItem(Width As Int, Title As String, Image As B4XBitmap,Date As String) As Panel
	Dim p       As B4XView  = xui.CreatePanel("")
	Dim height  As Int      = 120dip
	Dim Obj1    As Reflector
	p.SetLayoutAnimated(0, 0, 0, Width, height)
	p.LoadLayout("card")
	T.Text = Title
	Dim ripple As RippleView
	ripple.Initialize(Panel1, Colors.Blue, 300, True)
		Label1.TextColor = 0xFF4A0091
		Label1.Text = " Tel : @SkillPersian"&CRLF&Date
	ImageView1.SetBitmap(CreateRoundBitmap(Image, ImageView1.Width))
	Obj1.Target = T
	Obj1.RunMethod3("setLineSpacing", 1, "java.lang.float", 1.2, "java.lang.float")
	Return p
Sub CreateRoundBitmap (Input As B4XBitmap, Size As Int) As B4XBitmap
	If Input.Width <> Input.Height Then
		'if the image is not square then we crop it to be a square.
		Dim l As Int = Min(Input.Width, Input.Height)
		Input = Input.Crop(Input.Width / 2 - l / 2, Input.Height / 2 - l / 2, l, l)
	Dim c As B4XCanvas
	Dim xview As B4XView = xui.CreatePanel("")
	xview.SetLayoutAnimated(0, 0, 0, Size, Size)
	c.Initialize(xview)
	Dim path As B4XPath
	path.InitializeOval(c.TargetRect)
	c.ClipPath(path)
	c.DrawBitmap(Input.Resize(Size, Size, False), c.TargetRect)
	c.RemoveClip
	c.DrawCircle(c.TargetRect.CenterX, c.TargetRect.CenterY, c.TargetRect.Width / 2 - 2dip, xui.Color_White, False, 5dip) 'comment this line to remove the border
	c.Invalidate
	Dim res As B4XBitmap = c.CreateBitmap
	c.Release
	Return res
'درصورت فعال بودن Ripple View
'کلیک آیتم از کار می افته بنابرین باید
'seneder
'برای دسترسی به کلیک آیتم ها استفاده کنید
Sub CLV_ItemClick (Index As Int, Value As Object)
	ToastMessageShow(Value,False)
Private Sub Panel1_Click
	Dim index As Int = CLV.GetItemFromView(Sender)
	ToastMessageShow("آیتم شماره "&CLV.GetValue(index)&" کلیک شد. ",False)
Private Sub Button1_Click
	ToastMessageShow("مشاهده آیتم "&CLV.GetValue(index),False)
Private Sub Button2_Click
		For i= 0 To 10
			Bitmap= LoadBitmap(File.DirAssets,i&".jpg")
			Counter = Counter +1
			CLV.Add(CreateItem(CLV.AsView.Width,"Mohammad Reza Pirzadeh"&CRLF&"Skillpersian",Bitmap,""),Counter)
Private Sub btn_next_Click
	Activity.Finish
	StartActivity("page2")
✅ صفحه دوم
	Private xui As XUI
	Private T As Label
	Dim Counter As Int
	Private i As Int
	Activity.LoadLayout("page2")
	T.Text = Title
	Obj1.Target = T
	Return p
	Dim c As B4XCanvas
	c.Initialize(xview)
	Dim path As B4XPath
	c.ClipPath(path)
	c.RemoveClip
	c.Invalidate
	c.Release
	Return res
'seneder
	If i=11 Then
		ToastMessageShow("همه آیتم ها ساخته شدند",False)
		Return
	i=i+1
Private Sub activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
	Activity.Finish
	StartActivity("main")
	Return True
تهیه و تنظیم
مرتضی صباغی
MR.B4A
