sql1.Initialize(File.DirInternal,"ghese1.db",False)
cur = sql1.ExecQuery("SELECT * FROM j111 WHERE link2 ="&meghdar)
For i = 0 To cur.RowCount-1
cur.Position = i
Dim bytes() As Byte
bytes=cur.GetBlob("picc")
addItem(cur.GetString("link1"),s,bytes)
cur.Close
Sub addItem(id As Int ,matn As String,pic1 As Byte)
Dim ImageView1 As ImageView
If pic1<>Null Then
Dim input As InputStream
input.InitializeFromBytesArray(pic1,0,pic1.Length)
Bitmap1.Initialize2(input)
input.Close
ImageView1.Initialize("Imageview1") 'اضافه کردن عکس اول'
Panel2.AddView(ImageView1,((Activity.Width/2)-(Bitmap1.Width/4))-10%x,13%y,(Bitmap1.Width/2),(Bitmap1.Height/2))
ImageView1.Bitmap=Bitmap1
' ImageView1.Bitmap=Namayesh(meghdar)
ImageView1.Gravity=Gravity.FILL
PanelHeight=(Bitmap1.Height/2)+35dip
خطای ذیل رو میده:
B4A version 4.30
Parsing code. 0.06
Compiling code. Error
Error compiling program.
Error description: Cannot cast type: {Type=Byte,Rank=0, RemoteObject=True} to: {Type=Byte,Rank=1, RemoteObject=True}
Occurred on line: 177
Word: pic1
seyed_27 170
بسمه تعالی
کد ذیل رو یه نگاهی بندازید
خطای ذیل رو میده:
مشکل کجاست
