ارور Invalid double + درون پراخت بازار
mortezasaidi
با سلام
دوستان گرامی
من می خواهم مطالب دیتابیسم را محدود کنم
برای این کار کد صفحه :
#Region  Activity Attributes
	#FullScreen: false
	#IncludeTitle: false
#End Region
Dim pos As Int
Dim shomare As Int
Dim payment As bazaarpay
Dim Id As PhoneId
Dim Pardakht As Boolean
Dim RSACode As String ="MIHNMA0GCSqGSIb3DQEBAQUAA4G7ADCBtwKBrwCtKxVlPrEu29e11B2zPI3ukYu4bVj+Pd9a1ydGw+oXkeUD00RFNd6RNz7trrpoYn7D8xZa29w1IUb2lN+yYdvSll014zgCmHeTqYPuRWipstczra0uZ5akEYSd9XDfrsyZOCfxooe52r13BovgzXM5GXMQXjgNFXttUSvL/EdqPXnamyxEvCqlaqq6pEws7slMLHusX/OWcKc7SelKPpuO7OxMKbqhJgDNHjca/+cCAwEAAQ=="
	Private ListViewFehrest As ListView
	Private ListViewData As ListView
	Dim bitmap1 As BitmapDrawable
	Dim LayoutNumber As Int
	Private btnExam As Button
	Private Button1 As Button
	Private Button2 As Button
	Private Button3 As Button
	Private Button4 As Button
	Activity.LoadLayout("LayoutFehrest")
	bitmap1.Initialize(LoadBitmap(File.DirAssets,"btnclick1.png"))
		    Dim verticalPosition As String = "bottom" '"top" or "bottom"
    Dim horizontalPosition As String = "center" '"left", "right" or "center"
    Dim r As Reflector
    Dim args(3) As Object = Array As Object(r.GetActivity, verticalPosition, horizontalPosition)
    Dim types(3) As String = Array As String("android.app.Activity", "java.lang.String", "java.lang.String")
    r.RunStaticMethod("ir.adad.AdadB4APlugin", "createAdView", args, types)
	payment.Initialize("pardakht", RSACode)
	If File.Exists(File.DirInternal,"Success-pay.txt") Or File.Exists(File.DirDefaultExternal,"Success-pay.txt") Then
Sub Activity_Resume
Sub AddSubjects
Sub btnha
	 Activity.RemoveAllViews
	 LayoutNumber = 1
	 Activity.LoadLayout("LayoutData")
	 ListViewData.SingleLineLayout.Background = bitmap1
	 ListViewData.SingleLineLayout.Label.TextColor = Colors.Black
	 ListViewData.SingleLineLayout.Label.Gravity = Gravity.RIGHT
	 ListViewData.SingleLineLayout.Label.Gravity = Gravity.CENTER_VERTICAL
	 ListViewData.SingleLineLayout.ItemHeight = 15%y
	 Main.cur1 = Main.sql1.ExecQuery("SELECT * FROM tbl1 WHERE daste='"&shomare&"'")
	 For i=0 To Main.cur1.RowCount-1
	 Main.cur1.Position=i
	 ListViewData.AddSingleLine("   " & Main.cur1.GetString("onvan"))
	  	If LayoutNumber = 0 Then
		Activity.Finish
		StartActivity(Main)
		Else If LayoutNumber = 1 Then
		AddSubjects
		LayoutNumber = 0
		Return True
Sub ListViewData_ItemClick (Position As Int, Value As Object)
Dim cur As Cursor
Main.cur1=Main.SQL1.ExecQuery("SELECT * FROM tbl1")
Main.cur1.Position=Value-1
	 If cur.GetInt("kharid")=1 Then
	    StartActivity(txtv)
	 Dim p As  Int
	 p = Msgbox2("تنها با پرداخت 1500 تومان از سایر مطالب جذاب کتاب لذت ببرید","پرداخت درون برنامه","پرداخت ","انصرف","",LoadBitmap(File.DirAssets ,"pay.png"))
	 If p=DialogResponse.POSITIVE Then
	 payment.RequestPayment("eshterak","inapp","pardakht1")
Sub Button4_Click
	 shomare =4
	 btnha
Sub Button3_Click
	 shomare =3
	 btnha
Sub Button2_Click
	 shomare =2
	 btnha
Sub Button1_Click
	 shomare =1
	 btnha
Sub pardakht_PurchaseCompleted (Success As Boolean, Product As Purchase)
Dim cur As Cursor
If Success=True Then
	For j=0 To cur.RowCount
		Main.SQL1.ExecNonQuery("update tbl1 set kharid=1 where id="&j)
		ToastMessageShow("پرداخت با موفقیت انجام شد",False)
		ToastMessageShow("پرداخت انجام نشد",False)
را قرار دادم
اما هنگامی که کاربر بر روی مطالب کلیک کرد
ارور
java.lang.NumberFormatException: Invalid double: "مطلب 2"
می آید
در ضمن در دیتابیس یک ستون با نام kharid ساختم و مقدار ان را برای مطالب رایگان بر روی 1 و برای مطالب پولی بر روی 0  تنظیم کردم
ممنون می شوم راهنمایی کنید
