سلام دوستان من با کتاب خانه ی arcmenu یه منو ساختم توی اکتیویتیم ولی توی لایوتی که لود میکنم یه webview به صورت تمام صفحه گذاشتم . بعد دیگه این منو رو نشون نمیده یعنی هستش ولی پشت webview چطور میتونم مشخصش کنم؟؟؟
اینم کد
#Region Project Attributes
#ApplicationLabel: B4A Example
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Sub Process_Globals
Private TabHost1 As TabHost
Private WebView2 As WebView
Private WebView1 As WebView
Dim arc1 As ArcMenu
Activity.LoadLayout("main")
TabHost1.AddTab("صفحه اصلی","l1")
TabHost1.AddTab("سورس","l2")
WebView1.LoadUrl("http://www.software-developer.blog.ir")
WebView2.LoadUrl("http://www.google.com")
arc1.Initialize(Activity,Me,"arc_1",LoadBitmap(File.DirAssets,"3floppy_mount.png"),LoadBitmap(File.DirAssets,"2.ico"),10%x,90%y)
arc1.SetAnimatedButtonDimensions(40dip,40dip)
arc1.AddItem(LoadBitmap(File.DirAssets,"1.png"))
Sub Activity_Resume
Sub Activity_KeyPress (KeyCode As Int) As Boolean
WebView1.back
WebView2.Back
Return True
amirsafari 116
اینم کد
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private TabHost1 As TabHost Private WebView2 As WebView Private WebView1 As WebView Dim arc1 As ArcMenu End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("main") TabHost1.AddTab("صفحه اصلی","l1") TabHost1.AddTab("سورس","l2") WebView1.LoadUrl("http://www.software-developer.blog.ir") WebView2.LoadUrl("http://www.google.com") arc1.Initialize(Activity,Me,"arc_1",LoadBitmap(File.DirAssets,"3floppy_mount.png"),LoadBitmap(File.DirAssets,"2.ico"),10%x,90%y) arc1.SetAnimatedButtonDimensions(40dip,40dip) arc1.AddItem(LoadBitmap(File.DirAssets,"1.png")) arc1.AddItem(LoadBitmap(File.DirAssets,"1.png")) End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub Activity_KeyPress (KeyCode As Int) As Boolean If KeyCode = KeyCodes.KEYCODE_BACK Then WebView1.back WebView2.Back Return True End If End Subلینک ارسال
