#Region Project Attributes
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
If File.Exists(File.DirInternal,"aa.txt")=False Then
File.Copy(File.DirAssets,"aa.txt",File.DirInternal,"aa.txt")
Dim auto As AutoSizeScroll
Dim st As String
Dim label1 As Label
Dim font As Typeface
font=Typeface.LoadFromAssets("ariblk.ttf")
label1.Initialize("label1")
st=File.ReadString(File.DirInternal,"aa.txt")
label1.Text=st
label1.Typeface=font
ScrollView1.Panel.AddView(label1,0,0,100%x,100%y)
auto.set(label1,ScrollView1)
Sub Activity_Resume
amirsafari 116
سلام دوستان من یه فایل متنی رو میخونم توی برنامم.
ولی زبان فارسی رو نمایش نمیده .
چرا؟؟؟
اینم کدم :
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private ScrollView1 As ScrollView End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("Layout1") If File.Exists(File.DirInternal,"aa.txt")=False Then File.Copy(File.DirAssets,"aa.txt",File.DirInternal,"aa.txt") End If Dim auto As AutoSizeScroll Dim st As String Dim label1 As Label Dim font As Typeface font=Typeface.LoadFromAssets("ariblk.ttf") label1.Initialize("label1") st=File.ReadString(File.DirInternal,"aa.txt") label1.Text=st label1.Typeface=font ScrollView1.Panel.AddView(label1,0,0,100%x,100%y) auto.set(label1,ScrollView1) End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subلینک ارسال
