#Region Activity Attributes
#FullScreen: False
#IncludeTitle: false
#End Region
Dim p As Panel
Dim scr As ScrollView
Dim ist As Int
ist = 0%y
Dim lbl As Label
Dim stop As Int=3%y
Private Buttondel As Button
Private Button2 As Button
Private Button1 As Button
Activity.LoadLayout("scrin")
Activity.Color=Colors.White
'برای تست وجود عکس
Dim l As List
l.Initialize
l=File.ListFiles(File.DirRootExternal&"/telgram/telegram images")
If l.Size=0 Then
Msgbox("عکسی در گالری موجود نمیباشد.","توجه!")
StartActivity(Main)
' لیست کردم فایل های داخل پوشه
Dim lst0 As List
lst0 = File.ListFiles(File.DirRootExternal&"/telgram/telegram images")
For i = 0 To lst0.Size - 1
Dim p As Panel
p.Initialize("p")
p.Color=Colors.White
stop=stop+240dip
p.LoadLayout("multipanel")
Dim sx As String=lst0.Get(i)
Buttondel.Tag=lst0.Get(i)
Button1.Tag=lst0.Get(i)
Button2.Tag=lst0.Get(i)
ImageView1.SetBackgroundImage(LoadBitmap(File.DirRootExternal&"/telgram/telegram images",sx))
ScrollView1.Color=Colors.White
ScrollView1.Panel.Height=stop+150dip
ScrollView1.Panel.Color=Colors.White
Sub Activity_Resume
Sub Label2del_Click
Sub Buttondelete_Click
Dim mm As Button
mm=Sender
Dim a12 As String
Dim a12 As String
Dim hh As String
Dim aa As Long
aa = File.Size(File.DirRootExternal&"/telgram/telegram images",mm.tag)
hh=aa/1000
a12 = Msgbox2("آیا میخواهید این عکس را پاک کنید؟"&CRLF&"حجم عکس: "&hh& "کیلو بایت"& " ","توجه!","بله","خیر","",Null)
If (a12 = DialogResponse.POSITIVE) Then
ToastMessageShow("حذف شد",False)
File.Delete(File.DirRootExternal&"/telgram/telegram images",mm.tag)
Activity.Finish
StartActivity(Me)
Return True
Sub Buttonnameshax_Click
Dim mm As Button
mm=Sender
Dim i As Intent
Dim q As String
q="file://" & File.DirRootExternal&"/instadownloader/"&mm.tag&"
i.Initialize(i.ACTION_VIEW,q)
i.SetType("image/jpeg")
StartActivity(i)
Sub Buttonshareax_Click
Dim mm As Button
mm=Sender
Dim a As AriaLib
StartActivity(a.SharePic(File.DirRootExternal&"/instadownloader/",mm.tag,"اشتراک گذاری با :"))
یه ارور میاره بعد برنامه فورس کلوز میشه
ارور:
java.longtime.outofmemory
فک کنم رم نمیکشه واسه عکسا مثلا سه تا عکس میزارم ارور نمیده ده تا میزارم برنامه کند میشه رو بیست تا فورس کلوز میشه همچنین برای هر عکس سه دکمه نداره تمام عکسارو داخل پنل لود میکنه آخرش سه تا دکمه میزاره
amin69 64
#Region Activity Attributes #FullScreen: False #IncludeTitle: false #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim p As Panel Dim scr As ScrollView Dim ist As Int ist = 0%y Dim lbl As Label Private ScrollView1 As ScrollView Dim stop As Int=3%y Private ImageView1 As ImageView Private Buttondel As Button Private Button2 As Button Private Button1 As Button End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("scrin") Activity.Color=Colors.White 'برای تست وجود عکس Dim l As List l.Initialize l=File.ListFiles(File.DirRootExternal&"/telgram/telegram images") If l.Size=0 Then Msgbox("عکسی در گالری موجود نمیباشد.","توجه!") StartActivity(Main) End If ' لیست کردم فایل های داخل پوشه Dim lst0 As List lst0 = File.ListFiles(File.DirRootExternal&"/telgram/telegram images") For i = 0 To lst0.Size - 1 Dim p As Panel p.Initialize("p") p.Color=Colors.White ScrollView1.Panel.AddView(p,0,stop,100%x,100%y) stop=stop+240dip p.LoadLayout("multipanel") Dim sx As String=lst0.Get(i) Buttondel.Tag=lst0.Get(i) Button1.Tag=lst0.Get(i) Button2.Tag=lst0.Get(i) ImageView1.SetBackgroundImage(LoadBitmap(File.DirRootExternal&"/telgram/telegram images",sx)) ScrollView1.Color=Colors.White ScrollView1.Panel.Height=stop+150dip ScrollView1.Panel.Color=Colors.White Next End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub Label2del_Click End Sub Sub Buttondelete_Click Dim mm As Button mm=Sender Dim a12 As String Dim a12 As String Dim hh As String Dim aa As Long aa = File.Size(File.DirRootExternal&"/telgram/telegram images",mm.tag) hh=aa/1000 a12 = Msgbox2("آیا میخواهید این عکس را پاک کنید؟"&CRLF&"حجم عکس: "&hh& "کیلو بایت"& " ","توجه!","بله","خیر","",Null) If (a12 = DialogResponse.POSITIVE) Then ToastMessageShow("حذف شد",False) File.Delete(File.DirRootExternal&"/telgram/telegram images",mm.tag) Activity.Finish StartActivity(Me) End If Return True End Sub Sub Buttonnameshax_Click Dim mm As Button mm=Sender Dim i As Intent Dim q As String q="file://" & File.DirRootExternal&"/instadownloader/"&mm.tag&" i.Initialize(i.ACTION_VIEW,q) i.SetType("image/jpeg") StartActivity(i) End Sub Sub Buttonshareax_Click Dim mm As Button mm=Sender Dim a As AriaLib StartActivity(a.SharePic(File.DirRootExternal&"/instadownloader/",mm.tag,"اشتراک گذاری با :")) End Subیه ارور میاره بعد برنامه فورس کلوز میشه
ارور:
استاد جواب اینم بدی رفع زحمت میکنم قول میدم جبران کنم.
