مشکل ذخیره نشدن تنظیمات
siroos12
سلام علیکم.
دوستان من از تنظیمات خود اندروید استفاده کردم.
فقط ی مشکلی هست،اونم اینه که باید از برنامه خارج بشی و داخل بشی تا تغیرات تنظیمات اعمال بشه.
مشکل کجاست؟
اینم کد.
	Dim m As MediaPlayer
	Dim h As Boolean
	Private Label1 As Label
	Private Panel1 As Panel
	Dim c As Cursor
	Dim s As SQL
	Dim x As Int=1%y
		Dim sFontSize,sFontColor,sFontFamily As String
        Dim set As AHPreferenceManager
Private Button1 As Button
		Dim s1 As SlidingMenu
	Private Button2 As Button
	Private Label2 As Label
Sub SetlineSacing(Lbl As Label,add As Float,mult As Float)
Dim jo As JavaObject=Label1
jo.RunMethod("setLineSpacing",Array As Object(add,mult))
	Activity.LoadLayout("b")
	aa.createMenu(s1)
	If File.Exists(File.DirInternal,"123.db")= False Then
File.Copy(File.DirAssets,"123.db",File.DirInternal,"123.db")
s.Initialize(File.DirInternal,"123.db",False)
c=s.ExecQuery("SELECT * FRom A1")
For i=0 To c.RowCount-1
c.Position=i
Dim p As Panel
p.Initialize("p")
ScrollView1.Panel.AddView(p,0,x,100%x,100%y)
x=x+42%y
p.LoadLayout("a")
sFontSize = set.GetString("fontSize")
sFontColor = set.GetString("fontColor")
sFontFamily = set.GetString("fontFamily")
Label1.Text=c.GetString("see")
Label1.Typeface=Typeface.LoadFromAssets("Mj_Shafigh_ Emperor.Ir.TTF")
Label1.Gravity=Gravity.CENTER
Label1.TextColor=Colors.Black
Label1.TextSize=25
SetlineSacing(Label1,1.5,1.5)
Label1.Top=0dip
Try
			Label1.TextSize = sFontSize
		Catch
		End Try
		If sFontColor = "Red" Then
			Label1.TextColor = Colors.Red
		Else If sFontColor = "Green" Then
			Label1.TextColor= Colors.Green
		Else If sFontColor = "Blue" Then
			Label1.TextColor = Colors.Blue
		Else If sFontColor = "Yellow" Then
			Label1.TextColor = Colors.Yellow
Try
			Label1.Typeface = Typeface.LoadFromAssets(sFontFamily)
		Catch
		End Try
ScrollView1.Panel.Height=x
Label1.Tag=c.GetInt("id")'''''''''''''''''''''''''''
Sub Activity_Resume
Sub Button2_Click
	If s1.Visible=True Then
	s1.HideMenus
	s1.ShowMenu
Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
	If KeyCode = KeyCodes.KEYCODE_MENU Then
		If s1.Visible = False Then
			s1.ShowMenu
			s1.HideMenus
		Return True
Sub panelMenu_ItemClick (Position As Int,Value As Object)
	Select Value
	Case "about"
			Dim c1 As CustomDialog
			Dim p1 As Panel
			p1.Initialize("")
			c1.AddView(p1,0,0,490,250)
			p1.LoadLayout("5")
			c1.Show("درباره ما","خب","","",Null)
		Case "setting"
			setting
		Case "exit"
			If Msgbox2("آیا	می خواهید از برنامه خارج شوید؟","خروج","بله","خیر","",Null) = DialogResponse.POSITIVE Then
				Activity.Finish
				ExitApplication
							    ToastMessageShow("التماس دعا",True)
	End Select
Sub setting
	'StartActivity("ss")
	Dim a1 As AHPreferenceScreen
	a1.Initialize("تنظیمات","تنظیمات مربوط به نمایش")
	a1.AddList("fontSize","اندازه قلم","حالت پیشفرض سایز قلم 18","18","",Array As String("20","21","22","28","36","40","52"))
	a1.AddList("fontColor","رنگ قلم","رنگ پیشفرض قلم سیاه است","black","",Array As String("Red","Green","Blue","Yellow"))
	a1.AddList("fontFamily","نوع قلم","","byekan.ttf","",Array As String("IranNastaliq.ttf","lcn.otf"))
	StartActivity(a1.CreateIntent)
حقیقتا کدهاتون رو نگاه نکردم
فقط 99% شک مشکل اینه :
کدهایی رو که توی Activity Create ابتدای برنامه قرار دادید و داده های تنظیمات رو میخونن
دوباره بعد از ذخیره تنظیمات قرار بدید تا مقادیر بروزرسانی بشن
توی رویداد Button Click ذخیره تنظیمات بنویسید دیگه
تو ذخیره تنظیمات چی بنویسم؟
همون کدی که برای فراخوانی اطلاعات ذخیره شده مربوط به تنظیمات قرار دادید  :S  :S
یعنی اینا دیگه؟
Try
		Catch
		End Try
Try
		Catch
		End Try
من برا تنظیمات لایوت معرفی نکردم با کتابخونه تنظیماتمو نوشتم.یعنی این refresh نمیشه کرد؟
