سلام دوستان و باتونم را مثل سورس زیر میخوام بیاد ولی موقعی که به باتون فهرست کلیک میکنم زود به اکتیویتی بعدی میره پیش نمایشا انجام نمیده چکار کنم
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Private fehrest As Button
Private nazar As Button
Private khoroj As Button
Dim a6, a7, a8, a9 As Animation
Dim a1, a2, a3 As Animation
Activity.LoadLayout("main")
a1.InitializeScaleCenter("", 1, 1, 0, 0, fehrest)
fehrest.Tag = a1
a2.InitializeScaleCenter("", 1, 1, 0, 0, nazar)
nazar.Tag = a2
a3.InitializeScaleCenter("", 1, 1, 0, 0, khoroj)
khoroj.Tag = a3
Dim animations() As Animation
animations = Array As Animation(a1, a2, a3 )
For i = 0 To animations.Length - 1
animations(i).Duration = 1000
animations(i).RepeatCount = 1
animations(i).RepeatMode = animations(i).REPEAT_REVERSE
Sub Animation_AnimationEnd
If Sender = a6 Then
a7.Start(fehrest)
Else If Sender = a7 Then
a8.Start(nazar)
Else If Sender = a8 Then
a9.Start(khoroj)
Sub fehrest_Click
Dim b As Button
b = Sender
' Safety check. Not really required in this case.
If Not(b.Tag Is Animation) Then Return
Dim a As Animation
a = b.Tag
a.Start(b)
StartActivity(galery)
Sub nazar_Click
Dim b As Button
b = Sender
'Safety check. Not really required in this case.
Dim a As Animation
a = b.Tag
a.Start(b)
Sub khoroj_Click
Dim b As Button
b = Sender
Dim a As Animation
a = b.Tag
a.Start(b)
naser sahami 90
#Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private fehrest As Button Private nazar As Button Private khoroj As Button Dim a6, a7, a8, a9 As Animation End Sub Sub Activity_Create(FirstTime As Boolean) Dim a1, a2, a3 As Animation Activity.LoadLayout("main") a1.InitializeScaleCenter("", 1, 1, 0, 0, fehrest) fehrest.Tag = a1 a2.InitializeScaleCenter("", 1, 1, 0, 0, nazar) nazar.Tag = a2 a3.InitializeScaleCenter("", 1, 1, 0, 0, khoroj) khoroj.Tag = a3 Dim animations() As Animation animations = Array As Animation(a1, a2, a3 ) For i = 0 To animations.Length - 1 animations(i).Duration = 1000 animations(i).RepeatCount = 1 animations(i).RepeatMode = animations(i).REPEAT_REVERSE Next End Sub Sub Animation_AnimationEnd If Sender = a6 Then a7.Start(fehrest) Else If Sender = a7 Then a8.Start(nazar) Else If Sender = a8 Then a9.Start(khoroj) End If End Sub Sub fehrest_Click Dim b As Button b = Sender ' Safety check. Not really required in this case. If Not(b.Tag Is Animation) Then Return Dim a As Animation a = b.Tag a.Start(b) StartActivity(galery) End Sub Sub nazar_Click Dim b As Button b = Sender 'Safety check. Not really required in this case. If Not(b.Tag Is Animation) Then Return Dim a As Animation a = b.Tag a.Start(b) End Sub Sub khoroj_Click Dim b As Button b = Sender 'Safety check. Not really required in this case. If Not(b.Tag Is Animation) Then Return Dim a As Animation a = b.Tag a.Start(b) End Subلینک ارسال
