سلام دوستان و باتونم را مثل سورس زیر میخوام بیاد ولی موقعی که به باتون فهرست کلیک میکنم زود به اکتیویتی بعدی میره پیش نمایشا انجام نمیده چکار کنم
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Sub Process_Globals
Private fehrest As Button
Private nazar As Button
Private khoroj As Button
Dim a6, a7, a8, a9 As Animation
Dim a1, a2, a3 As Animation
Activity.LoadLayout("main")
a1.InitializeScaleCenter("", 1, 1, 0, 0, fehrest)
fehrest.Tag = a1
a2.InitializeScaleCenter("", 1, 1, 0, 0, nazar)
nazar.Tag = a2
a3.InitializeScaleCenter("", 1, 1, 0, 0, khoroj)
khoroj.Tag = a3
Dim animations() As Animation
animations = Array As Animation(a1, a2, a3 )
For i = 0 To animations.Length - 1
animations(i).Duration = 1000
animations(i).RepeatCount = 1
animations(i).RepeatMode = animations(i).REPEAT_REVERSE
Sub Animation_AnimationEnd
If Sender = a6 Then
a7.Start(fehrest)
Else If Sender = a7 Then
a8.Start(nazar)
Else If Sender = a8 Then
a9.Start(khoroj)
Sub fehrest_Click
Dim b As Button
b = Sender
' Safety check. Not really required in this case.
If Not(b.Tag Is Animation) Then Return
Dim a As Animation
a = b.Tag
a.Start(b)
StartActivity(galery)
Sub nazar_Click
Dim b As Button
b = Sender
'Safety check. Not really required in this case.
Dim a As Animation
a = b.Tag
a.Start(b)
Sub khoroj_Click
Dim b As Button
b = Sender
Dim a As Animation
a = b.Tag
a.Start(b)
naser sahami 90
