سلام دوستان من میخوام روی یه امیج ویو غکس بگیرم و بندازم ولی با دوربین دیفالت گوشی که عکس میگیرم و میخوام لودش کنم یک عکس قبل از عکسی رو که گرفتم نشون میده خوشحال میشم اگه کمک کنید
#Region Project Attributes
#ApplicationLabel: Gallery crop
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim onoff As Boolean
Activity.LoadLayout("main")
Sub Activity_Resume
If onoff Then
onoff = False
ImageView1.Bitmap = LoadBitmap(File.DirRootExternal, "temp.jpg")
Sub ButtonGallery_Click
Galeria(File.DirRootExternal, "temp.jpg")
Sub ButtonCamera_Click
Camera(File.DirRootExternal, "temp.jpg")
Sub Galeria(Directory As String, PictureName As String)
Dim i As Intent
onoff = True
i.Initialize(i.ACTION_PICK, "")
i.SetType("image/*")
i.PutExtra("output", ParseUri("file://" & File.Combine(Directory, PictureName))) 'output folder you set OpenCam(File.DirRootExternal, "1.jpg")
i.PutExtra("crop", "true") 'crop ON
i.PutExtra("aspectX", 1) 'crop aspects
i.PutExtra("aspectY", 1) 'crop aspects
'برای این که مربعی نباشه مقدار aspectX و aspectY رو صفر بزار
i.PutExtra("outputX", 200) 'crop size
i.PutExtra("outputY", 200) 'crop size
StartActivity(i)
'pejman nikravan
'answercenter.ir
Sub Camera(Directory As String, PictureName As String)
Dim i As Intent
onoff = True
i.Initialize("android.media.action.IMAGE_CAPTURE", "")
i.PutExtra("aspectX", 0) 'crop aspects
i.PutExtra("aspectY", 0) 'crop aspects
StartActivity(i)
Sub ParseUri(FileName As String) As Object
Dim r As Reflector
Return r.RunStaticMethod("android.net.Uri", "parse", Array As Object(FileName), Array As String("java.lang.String"))
mohammade79 127
#Region Project Attributes #ApplicationLabel: Gallery crop #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals End Sub Sub Globals Private ImageView1 As ImageView Dim onoff As Boolean End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("main") End Sub Sub Activity_Resume If onoff Then onoff = False ImageView1.Bitmap = LoadBitmap(File.DirRootExternal, "temp.jpg") End If End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub ButtonGallery_Click Galeria(File.DirRootExternal, "temp.jpg") End Sub Sub ButtonCamera_Click Camera(File.DirRootExternal, "temp.jpg") End Sub Sub Galeria(Directory As String, PictureName As String) Dim i As Intent onoff = True i.Initialize(i.ACTION_PICK, "") i.SetType("image/*") i.PutExtra("output", ParseUri("file://" & File.Combine(Directory, PictureName))) 'output folder you set OpenCam(File.DirRootExternal, "1.jpg") i.PutExtra("crop", "true") 'crop ON i.PutExtra("aspectX", 1) 'crop aspects i.PutExtra("aspectY", 1) 'crop aspects 'برای این که مربعی نباشه مقدار aspectX و aspectY رو صفر بزار i.PutExtra("outputX", 200) 'crop size i.PutExtra("outputY", 200) 'crop size StartActivity(i) End Sub 'pejman nikravan 'answercenter.ir Sub Camera(Directory As String, PictureName As String) Dim i As Intent onoff = True i.Initialize("android.media.action.IMAGE_CAPTURE", "") i.PutExtra("crop", "true") 'crop ON i.PutExtra("aspectX", 0) 'crop aspects i.PutExtra("aspectY", 0) 'crop aspects i.PutExtra("outputX", 200) 'crop size i.PutExtra("outputY", 200) 'crop size i.PutExtra("output", ParseUri("file://" & File.Combine(Directory, PictureName))) 'output folder you set OpenCam(File.DirRootExternal, "1.jpg") StartActivity(i) End Sub Sub ParseUri(FileName As String) As Object Dim r As Reflector Return r.RunStaticMethod("android.net.Uri", "parse", Array As Object(FileName), Array As String("java.lang.String")) End Subلینک ارسال
