این ارور مال دیزاینر و لایوتمه ولی نمیدونم کجاش مشکل داره . راهنمایی کنید .
Copying updated assets files (1)
** Activity (main) Resume **
** Activity (main) Pause, UserClosed = false **
** Activity (homeact2) Create, isFirst = true **
Error occurred on line: 34 (homeact2)
java.lang.RuntimeException: java.lang.RuntimeException: Field save was declared with the wrong type.
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:166)
at anywheresoftware.b4a.objects.ActivityWrapper.LoadLayout(ActivityWrapper.java:208)
at b4a.example.homeact2._activity_create(homeact2.java:360)
at java.lang.reflect.Method.invoke(Method.java:515)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:668)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:337)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:244)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:132)
at b4a.example.homeact2.afterFirstLayout(homeact2.java:102)
at b4a.example.homeact2.access$000(homeact2.java:17)
at b4a.example.homeact2$WaitForLayout.run(homeact2.java:80)
at android.os.Handler.handleCallback(Handler.java:733)
at android.os.Looper.loop(Looper.java:136)
at android.app.ActivityThread.main(ActivityThread.java:5045)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
Caused by: java.lang.RuntimeException: Field save was declared with the wrong type.
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayoutHelper(LayoutBuilder.java:399)
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayoutHelper(LayoutBuilder.java:425)
at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:144)
... 22 more
** Activity (homeact2) Resume **
mamad20 18
