Mr.Kafiri 221 ارسال شده در 15 دی، 2020 اشتراک گذاری ارسال شده در 15 دی، 2020 سلام آقای شاهپیری کتابخونه های PersianFastNetwork با FirebaseNotification با هم مشکل دارن ، خطای زیر رو میدن B4A Version: 10.2 Java Version: 11 Parsing code. (0.00s) Building folders structure. (0.85s) Compiling code. (0.40s) Compiling layouts code. (0.07s) Organizing libraries. (0.00s) (AndroidX SDK) Generating R file. (2.91s) Compiling generated Java code. (13.39s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/DefaultDateTypeAdapter; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/ExclusionStrategy; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldAttributes; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldNamingPolicy; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldNamingPolicy$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldNamingPolicy$2; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldNamingPolicy$3; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldNamingPolicy$4; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lcom/google/gson/FieldNamingPolicy$5; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:315) at com.android.dx.command.dexer.Main.runDx(Main.java:293) at com.android.dx.command.dexer.Main.main(Main.java:249) at com.android.dx.command.Main.main(Main.java:94) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684) ... 4 more چیکار کنم؟ ویرایش: با FirebaseAdmob هم مشکل داره.. میخوام از چشمک استفاده کنم باید این کتابخونه ها هم تیک بخورنن نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 16 دی، 2020 سازنده اشتراک گذاری ارسال شده در 16 دی، 2020 در 14 ساعت قبل، Mr.Kafiri گفته است : سلام آقای شاهپیری کتابخونه های PersianFastNetwork با FirebaseNotification با هم مشکل دارن ، خطای زیر رو میدن چیکار کنم؟ ویرایش: با FirebaseAdmob هم مشکل داره.. میخوام از چشمک استفاده کنم باید این کتابخونه ها هم تیک بخورنن پکیجهای تکراری رو باید حذف کنید. تو این خطا کتابخونه جیسون تکراریه ظاهرا. از یکی از کتابخونه ها حذفش کنید. برای حذف از کتابخونه فایل aar رو باز کنید و تو پوشه libs فایل per-json.java رو حذف کنید. دقت داشته باشید برای پروژه های دیگه این فایل رو برگردونید 1 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
mosobo 58 ارسال شده در 17 بهمن، 2020 اشتراک گذاری ارسال شده در 17 بهمن، 2020 سلام. خسته نباشید. من این کتابخونه رو خریدم، ولی خیلی مشکلات داره، الان همین سورس هایی که گذاشتین توی صفحه خرید هیچکدوم از پارامتر ها کار نمیکنه مثلا json و تابع executeRequesAsJSONObjectt نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 17 بهمن، 2020 سازنده اشتراک گذاری ارسال شده در 17 بهمن، 2020 در ۱ ساعت قبل، mosobo گفته است : سلام. خسته نباشید. من این کتابخونه رو خریدم، ولی خیلی مشکلات داره، الان همین سورس هایی که گذاشتین توی صفحه خرید هیچکدوم از پارامتر ها کار نمیکنه مثلا json و تابع executeRequesAsJSONObjectt این متدها مال نسخه قدیمی کتابخونه است دوست عزیز. متد executeRequesAsJSONObjectt به executeRequest تغییر پیدا کرده نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
mosobo 58 ارسال شده در 18 بهمن، 2020 اشتراک گذاری ارسال شده در 18 بهمن، 2020 در 23 ساعت قبل، محمدرضا شاهپیری گفته است : این متدها مال نسخه قدیمی کتابخونه است دوست عزیز. متد executeRequesAsJSONObjectt به executeRequest تغییر پیدا کرده خب پس بی زحمت یه سورس متناسب با نسخه جدید لطف کنین در اختیار بزارین نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 18 بهمن، 2020 سازنده اشتراک گذاری ارسال شده در 18 بهمن، 2020 در 2 ساعت قبل، mosobo گفته است : خب پس بی زحمت یه سورس متناسب با نسخه جدید لطف کنین در اختیار بزارین عزیز تو قسمت مدیریت خرید کتابخونه سورس لاگین(ویرایش با آخرین نسخه کتابخانه) موجود هست که با نسخه آخر ویرایش شده. سورسی که توی فایل زیپه رو استفاده نکنید قدیمیه.آموزشهای کتابخونه رو هم ببینید حتما نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
mohsen m 156 ارسال شده در 18 بهمن، 2020 اشتراک گذاری ارسال شده در 18 بهمن، 2020 در 44 دقیقه قبل، محمدرضا شاهپیری گفته است : عزیز تو قسمت مدیریت خرید کتابخونه سورس لاگین(ویرایش با آخرین نسخه کتابخانه) موجود هست که با نسخه آخر ویرایش شده. سورسی که توی فایل زیپه رو استفاده نکنید قدیمیه.آموزشهای کتابخونه رو هم ببینید حتما سلام لطفا سورس های قدیمی را حذف کنید یا عوض کنید ممنون نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MR.B4A 227 ارسال شده در 7 اسفند، 2020 اشتراک گذاری ارسال شده در 7 اسفند، 2020 سلام. دوستان تغییرات روی اندروید 10 خیلی زیاد بوده ظاهرا هر کتابخونه یا دستوری که قبلا روی اندروید مثلا 8 جواب میداده، روی اندروید 10 جواب نمیده!! حالا میخوام بدونم کسی بوده که این کتابخونه رو روی اندروید 10 یا 11 تست کرده باشه؟ نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
Mr.Kafiri 221 ارسال شده در 7 اسفند، 2020 اشتراک گذاری ارسال شده در 7 اسفند، 2020 در 3 ساعت قبل، batman123 گفته است : سلام. دوستان تغییرات روی اندروید 10 خیلی زیاد بوده ظاهرا هر کتابخونه یا دستوری که قبلا روی اندروید مثلا 8 جواب میداده، روی اندروید 10 جواب نمیده!! حالا میخوام بدونم کسی بوده که این کتابخونه رو روی اندروید 10 یا 11 تست کرده باشه؟ بله من تست کردم روی اندروید 10 بخوبی هم کار میکنه 1 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MR.B4A 227 ارسال شده در 8 اسفند، 2020 اشتراک گذاری ارسال شده در 8 اسفند، 2020 من خریدم اما به دوتا خطا برخوردم. یکی این و دیگری این تازه این همون پروژه نمونس که گذاشتید داخل سایت ورژن 6.8 آخرین ورژن ممنون میشم راهنمایی کنید بیسیک 10.2 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 8 اسفند، 2020 سازنده اشتراک گذاری ارسال شده در 8 اسفند، 2020 در 1 ساعت قبل، batman123 گفته است : من خریدم اما به دوتا خطا برخوردم. یکی این و دیگری این تازه این همون پروژه نمونس که گذاشتید داخل سایت ورژن 6.8 آخرین ورژن ممنون میشم راهنمایی کنید بیسیک 10.2 سلام و درود. توی پنل فقط یه دونه سورس هست عزیز. سورس لاگین که با نسخه آخر هم ست هست. لطفا از سورسهای قدیمی استفاده نکنید. تو تصویر زیر مشخصه. 1 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
batman1 13 ارسال شده در 8 اسفند، 2020 اشتراک گذاری ارسال شده در 8 اسفند، 2020 در ۱ ساعت قبل، محمدرضا شاهپیری گفته است : سلام و درود. توی پنل فقط یه دونه سورس هست عزیز. سورس لاگین که با نسخه آخر هم ست هست. لطفا از سورسهای قدیمی استفاده نکنید. تو تصویر زیر مشخصه. ممنون میشم لینکشو بذاری. من پیدا نکردم متاسفانه نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 8 اسفند، 2020 سازنده اشتراک گذاری ارسال شده در 8 اسفند، 2020 در ۱ ساعت قبل، batman1 گفته است : ممنون میشم لینکشو بذاری. من پیدا نکردم متاسفانه دوست عزیز شما محصول رو از کجا دانلود کردین؟ همونجا سورس هم هست. لینک سورس و کتابخونه رو که اینجا نمیزارن 1 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
batman1 13 ارسال شده در 8 اسفند، 2020 اشتراک گذاری ارسال شده در 8 اسفند، 2020 در 5 دقیقه قبل، محمدرضا شاهپیری گفته است : دوست عزیز شما محصول رو از کجا دانلود کردین؟ همونجا سورس هم هست. لینک سورس و کتابخونه رو که اینجا نمیزارن از اینجا نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 8 اسفند، 2020 سازنده اشتراک گذاری ارسال شده در 8 اسفند، 2020 در 7 دقیقه قبل، batman1 گفته است : از اینجا شما سورس و کتابخونه رو باید از قسمت فروشگاه-> مدیریت خرید دانلود کنید 1 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MR.B4A 227 ارسال شده در 8 اسفند، 2020 اشتراک گذاری ارسال شده در 8 اسفند، 2020 در 2 ساعت قبل، محمدرضا شاهپیری گفته است : شما سورس و کتابخونه رو باید از قسمت فروشگاه-> مدیریت خرید دانلود کنید مرسی. دانلود کردم. منتها کتابخونه PersianJSONOBject رو میخواد و ندارم. نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 8 اسفند، 2020 سازنده اشتراک گذاری ارسال شده در 8 اسفند، 2020 در 33 دقیقه قبل، batman123 گفته است : مرسی. دانلود کردم. منتها کتابخونه PersianJSONOBject رو میخواد و ندارم. به دلیل ضعف کتابخونه های جیسون پیشفرض توی سورسها از کتابخونه جیسون انجمن استفاده شده. لینک کتابخونه 1 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MR.B4A 227 ارسال شده در 8 اسفند، 2020 اشتراک گذاری ارسال شده در 8 اسفند، 2020 در 2 دقیقه قبل، محمدرضا شاهپیری گفته است : به دلیل ضعف کتابخونه های جیسون پیشفرض توی سورسها از کتابخونه جیسون انجمن استفاده شده. لینک کتابخونه استاد، به ما بگو چه قدر باید خرج کنیم تا سورس شما درست و بی نقص اجراشه؟ نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MR.B4A 227 ارسال شده در 10 اسفند، 2020 اشتراک گذاری ارسال شده در 10 اسفند، 2020 دوستان، هدف من از این که میخوام از این کتابخونه استفاده کنم، دانلود کردن یک url هست. اما توی پروژه نمونه اصلا به این موضوع نپرداخته. فقط عملیات get رو انجام داده. ممنون میشم یکی برای من تابعش رو بذاره که بتونم باهاش دانلود کنم. نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,631 ارسال شده در 10 اسفند، 2020 سازنده اشتراک گذاری ارسال شده در 10 اسفند، 2020 در 27 دقیقه قبل، batman123 گفته است : دوستان، هدف من از این که میخوام از این کتابخونه استفاده کنم، دانلود کردن یک url هست. اما توی پروژه نمونه اصلا به این موضوع نپرداخته. فقط عملیات get رو انجام داده. ممنون میشم یکی برای من تابعش رو بذاره که بتونم باهاش دانلود کنم. عزیز داکیومنت مربوط به کتابخونه توی پست اول هست. توضیحات لازم در مورد تغییرات داده شده. به موارد زیر دقت کنید. آموزش دانلود تو نسخه 6 هست همچنین متدهای اینشیالایز نیز تغییرات جزئی داشته. به صورت زیر هست اینشیالایز** Dim setup As FastNetSetup setup.SetupFastNet.setUpDownloader.WithCookieManager.WithSSL.Build ******************************************************************************************************************************************** نسخه 6 (نسخه جدید) منتشر شد. آموزش نسخه 6(کار با دانلودر) نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
به گفتگو بپیوندید
