امین مهدی نژاد 2,142 ارسال شده در 21 فروردین، 2018 اشتراک گذاری ارسال شده در 21 فروردین، 2018 لینک های دانلود دانلود بیسیک فور اندروید کتابخانه ها منبع مهمترین تغیرات: Visual designer properties grid Visual designer views tree Modules tree (new component) Files tree موارد بهبود یافته: Code modules can be loaded from other folders and can be easily shared between projects (including projects targeting other platforms): B4J Tutorial - [B4X] Modules, Files, Groups and Folders | B4X Community - Android, iOS, desktop, server and IoT programming tools Modules and file tree support grouping: Modules are monitored for external changes. Files tree shows the files icons and allows opening the files with external editors: B4J Tutorial - [B4X] External Editors | B4X Community - Android, iOS, desktop, server and IoT programming tools Modules, files and views can be renamed directly from the relevant tree. Full support for drag and dropping files and modules, including support for dragging multiple items. B4A services and activities can be shared with B4J. New options when adding modules: Copy to folder: Copies the module to the project folder (same as the current behavior). Link - relative path: Adds a link to the module with a relative path. Useful when the folder is under or close to the project folder. Link - absolute path: Adds a link to the module with an absolute path. Deleted files are moved to the recycle bin. Properties grid and views tree can be filtered. Properties grid is much faster and includes new types of editors: B4A Sdk Manager is included in the IDE: Support for downloading maven resources from Google online repositories. This is an important improvement as Google no longer updates the offline repositories. Java 9 is supported. WebView.ZoomEnabled hides or shows the zoom controls. Better error handling in CallSub calls. Fix for potential race condition in AsyncStreams. Better handling of edge cases where the Activity life cycle events are called multiple times. CallSubDelayed doesn't raise an error if the target sub is missing. This makes it safer to use CallSubDelayed for raising events, Better support for version control. Files are only written when the contents are actually changed. The modules internal attributes are sorted in lexicographical order to reduce random changes. XUI library is now an internal library. Debugger hover window is resizable. Add New Modules / Existing modules menu items in modules tree. Code editor color picker is based on the designer color picker. Open file with default program in Files tree. Also works with double click. Support for opening multiple files at once. Better handling of locked files. Manifest editor replacements are applied to resources created with CreateResource. Bug fixes and other minor improvements. لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
bahman 165 ارسال شده در 21 فروردین، 2018 اشتراک گذاری ارسال شده در 21 فروردین، 2018 ارور جاوا میده اکثرا لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
