ارور Icon
sadeghkiyani
سلام به اساتید
خواهش دارم راهنمایی کنید که علت ارور زیر چیه چند روزه گیر این ارور هستم
تمام کتابخانه ها  و sdk من آپدیت هست علتشو نمیدونم خواهش میکنم راهنمایی کنید ممنون
B4A Version: 9.50
Java Version: 8
Parsing code.    (0.14s)
Building folders structure.    (0.13s)
Compiling code.    (0.75s)
Compiling layouts code.    (0.38s)
Organizing libraries.    (0.00s)
    (AndroidX SDK)
Generating R file.    Error
g:\sdk\android-sdk-full\tools\..\extras\b4a_remote\androidx\appcompat\appcompat\1.1.0\unpacked-appcompat-1.1.0\res\values\values.xml:1722: error: Attribute "icon" has already been defined
g:\sdk\android-sdk-full\tools\..\extras\b4a_remote\androidx\appcompat\appcompat\1.1.0\unpacked-appcompat-1.1.0\res\values\values.xml:1929: error: Attribute "fontVariationSettings" has already been defined
g:\sdk\android-sdk-full\tools\..\extras\b4a_remote\androidx\appcompat\appcompat\1.1.0\unpacked-appcompat-1.1.0\res\values\values.xml:2597: error: Attribute "iconTint" has already been defined
g:\sdk\android-sdk-full\tools\..\extras\b4a_remote\androidx\appcompat\appcompat\1.1.0\unpacked-appcompat-1.1.0\res\values\values.xml:2675: error: Attribute "closeIcon" has already been defined
g:\sdk\android-sdk-full\tools\..\extras\b4a_remote\androidx\appcompat\appcompat\1.1.0\unpacked-appcompat-1.1.0\res\values\values.xml:2863: error: Attribute "menu" has already been defined
..\resmddialog\values\attrs.xml:5: error: Attribute "md_divider" has already been defined
..\resmddialog\values\attrs.xml:8: error: Attribute "md_dark_theme" has already been defined
..\resmddialog\values\attrs.xml:9: error: Attribute "md_background_color" has already been defined
..\resmddialog\values\attrs.xml:11: error: Attribute "md_icon" has already been defined
..\resmddialog\values\attrs.xml:12: error: Attribute "md_icon_max_size" has already been defined
..\resmddialog\values\attrs.xml:13: error: Attribute "md_icon_limit_icon_to_default_size" has already been defined
..\resmddialog\values\attrs.xml:15: error: Attribute "md_title_color" has already been defined
..\resmddialog\values\attrs.xml:16: error: Attribute "md_content_color" has already been defined
..\resmddialog\values\attrs.xml:18: error: Attribute "md_positive_color" has already been defined
..\resmddialog\values\attrs.xml:19: error: Attribute "md_neutral_color" has already been defined
..\resmddialog\values\attrs.xml:20: error: Attribute "md_negative_color" has already been defined
..\resmddialog\values\attrs.xml:21: error: Attribute "md_widget_color" has already been defined
..\resmddialog\values\attrs.xml:23: error: Attribute "md_item_color" has already been defined
..\resmddialog\values\attrs.xml:24: error: Attribute "md_divider_color" has already been defined
..\resmddialog\values\attrs.xml:25: error: Attribute "md_list_selector" has already been defined
..\resmddialog\values\attrs.xml:27: error: Attribute "md_btn_stacked_selector" has already been defined
..\resmddialog\values\attrs.xml:28: error: Attribute "md_btn_positive_selector" has already been defined
..\resmddialog\values\attrs.xml:29: error: Attribute "md_btn_neutral_selector" has already been defined
..\resmddialog\values\attrs.xml:30: error: Attribute "md_btn_negative_selector" has already been defined
..\resmddialog\values\attrs.xml:32: error: Attribute "md_title_gravity" has already been defined
..\resmddialog\values\attrs.xml:38: error: Attribute "md_content_gravity" has already been defined
..\resmddialog\values\attrs.xml:44: error: Attribute "md_btnstacked_gravity" has already been defined
..\resmddialog\values\attrs.xml:50: error: Attribute "md_items_gravity" has already been defined
..\resmddialog\values\attrs.xml:56: error: Attribute "md_buttons_gravity" has already been defined
..\resmddialog\values\attrs.xml:63: error: Attribute "md_reduce_padding_no_title_no_buttons" has already been defined
..\resmddialog\values\attrs.xml:66: error: Attribute "md_medium_font" has already been defined
..\resmddialog\values\attrs.xml:67: error: Attribute "md_regular_font" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:20: error: Attribute "cardBackgroundColor" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:22: error: Attribute "cardCornerRadius" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:24: error: Attribute "cardElevation" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:26: error: Attribute "cardMaxElevation" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:28: error: Attribute "cardUseCompatPadding" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:30: error: Attribute "cardPreventCornerOverlap" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:32: error: Attribute "contentPadding" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:34: error: Attribute "contentPaddingLeft" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:36: error: Attribute "contentPaddingRight" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:38: error: Attribute "contentPaddingTop" has already been defined
g:\sdk\android-sdk-full\extras\android\support\v7\cardview\res\values\attrs.xml:40: error: Attribute "contentPaddingBottom" has already been defined
شما پوشه Support رو از اینجا دانلود کن و تو آدرس زیر کپی کن.
ببین درست میشه.
Android\AndroidSDK\Extras\Android
البته اگر شما این پوشه رو دارین حتماً ازش کپی بگیرید.
در 16 دقیقه قبل، Salar52 گفته است :
ببین درست میشه.
این کارو کردم بازم درست نشد همون ارور رو داد
در 1 دقیقه قبل، Salar52 گفته است :
از کتابخانه AppCompat استفاده کردید؟
بله همچنین از این کتابخونه ها استفاده کردم
من قبلاً به مشکلی شبیه این برخورد کردم، تیک کتابخونه AppCompat رو که زدم درست شد.
شما هم اینکار رو بکن شاید درست شد.
در 2 دقیقه قبل، Salar52 گفته است :
این کارم کردم نشد  هم کتابخونه هام هم sdk من آپدیت هست نمیدونم مشکلش چیه توی سایت مرجع هم چیزی پیدا نکردم :fekr:
در 2 ساعت قبل، sadeghkiyani گفته است :
این ارورها مربوط به androidx هست عزیر. از طریق sdk همه پکیجهای androidx رو دانلود کنید
در در 28 شهریور 1398 در 22:46، محمدرضا شاهپیری گفته است :
سلام دوست عزیز همه ی Sdk رو آپدیت کردم اما بازم نشد اگه زحمتی نیست امکانش هست پوشه androidx  که داری رو برام پیوست کنی تا جایگزین کنم شاید درست بشه
