Salar82 919 ارسال شده در 22 دی، ۱۳۹۸ اشتراک گذاری ارسال شده در 22 دی، ۱۳۹۸ سلام وقتی از پوش پل استفاده میکنم، موقع کامپایل این ارور رو میده: B4A Version: 9.50 Java Version: 8 Parsing code. (0.12s) Building folders structure. (0.43s) Compiling code. (0.74s) Compiling layouts code. (1.90s) Organizing libraries. (0.00s) (Android Support Library) Generating R file. (9.58s) Compiling debugger engine code. (24.16s) Compiling generated Java code. (17.98s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/app/INotificationSideChannel; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/app/INotificationSideChannel$Stub; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/app/INotificationSideChannel$Stub$Proxy; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/IResultReceiver; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/IResultReceiver$Stub; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/IResultReceiver$Stub$Proxy; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroid/support/v4/os/ResultReceiver$MyResultReceiver; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:315) at com.android.dx.command.dexer.Main.runDx(Main.java:293) at com.android.dx.command.dexer.Main.main(Main.java:249) at com.android.dx.command.Main.main(Main.java:94) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684) ... 4 more باید چیکار کنم؟ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
Salar82 919 ارسال شده در 23 دی، ۱۳۹۸ سازنده اشتراک گذاری ارسال شده در 23 دی، ۱۳۹۸ مشکلم حل شد. طبق عیب یابی خودش لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
Salar82 919
باید چیکار کنم؟
