سلام من میخاستم تو مولتی پنل با تیک دار کردن چک باکس بتونم تکی یا چندین تا دانلود داشته باشم
ولی فقط آخریو دانلود میکنه
یه چیز دیگه وقتی چک باکس هر چنلم فعال شد با استفاده از باتی که جز مولتی پنل نیس دانلود کنم (یه چیزی مثل این)
نمیدونم منظورو رسوندم یا نه
اینم کدهام
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Sub Process_Globals
Private sql1 As SQL
Public link1 As String
Private CheckBox1 As CheckBox
Private ImageView1 As ImageView
Private Label1 As Label
Private Label2 As Label
Private Panel1 As Panel
Private Panel2 As Panel
Dim Stopint As Int=5%y
Private Cur1 As Cursor
Dim btnDownload As Button
Dim paneldownload As Panel
Dim progssbardownload As ProgressBar
Dim labeldownload As Label
Dim btnCancel As Button
Dim btnagindownload As Button
Dim namedownload As Label
Dim nb As NotificationBuilder
Dim name As String
'Activity.LoadLayout("Layout1")
ScrollView1.Initialize(2000dip)
File.MakeDir(File.DirRootExternal, "MusicB4A")
btnDownload.Initialize("btndownload")
btnDownload.BringToFront
btnDownload.Color=Colors.Green
btnDownload.Visible=True
btnDownload.Text="دانلود"
btnDownload.TextColor=Colors.White
btnDownload.TextSize=30
Activity.AddView(btnDownload,0%X,90%Y,100%X,10%y)
Activity.AddView(ScrollView1,0,7%Y,100%x,100%y)
paneldownload.Initialize("paneldownload")
progssbardownload.Initialize("progssbardownload")
labeldownload.Initialize("labeldownload")
btnCancel.Initialize("btnCancel")
btnagindownload.Initialize("btnagindownload")
namedownload.Initialize("namedownload")
Activity.AddView(paneldownload,5%X,15%Y,90%X,20%Y)
paneldownload.AddView(progssbardownload,5%X,2%Y,80%X,5%y)
paneldownload.AddView(labeldownload,35%X,9%Y,50%X,5%y)
paneldownload.AddView(btnCancel,45%x,12%Y,30%X,8%y)
paneldownload.AddView(btnagindownload,15%X,12%Y,30%X,8%y)
paneldownload.AddView(namedownload,28%X,5%Y,30%X,6%y)
paneldownload.Color=Colors.Black
labeldownload.TextSize=22
labeldownload.TextColor=Colors.Green
namedownload.TextSize=20
namedownload.TextColor=Colors.Blue
btnCancel.Text="انصراف"
btnagindownload.Text="دانلود دوباره"
ScrollView1.SendToBack
If File.Exists(File.DirInternal,"mo3madahi.db")=False Then
File.Copy(File.DirAssets,"mo3madahi.db",File.DirInternal,"mo3madahi.db")
sql1.Initialize(File.DirInternal,"mo3madahi.db",False)
Cur1=sql1.ExecQuery("SELECT * From Tmp3madahi")
For i=0 To Cur1.RowCount-1
Cur1.Position=i
Dim p As Panel
p.Initialize("p")
ScrollView1.Panel.AddView(p,0,Stopint-5%Y,100%x,100%Y)
Stopint=Stopint+25%Y
p.LoadLayout("pnl")
Panel1.Color=Colors.Blue
Label1.Text=Cur1.GetString("name")
Label1.Tag=Cur1.GetString("name")
ImageView1.Bitmap=LoadBitmapSample(File.DirAssets,"2mahdvi.jpg",ImageView1.Width,ImageView1.Height)
Label2.Tag=Cur1.GetString("linkdownload")
ScrollView1.Panel.Height=Stopint+7%Y
link1=Label2.Tag
name=Label1.Tag
namedownload.Text=Label1.Text
Panel2.Tag=Cur1.GetString("linkdownload")
ScrollView1.Panel.Height = (Cur1.RowCount * 27%Y)
'11111111111111111111111
nb.Initialize
nb.SmallIcon = "icon"
nb.DefaultSound=False
nb.ContentTitle = Label1.Text
nb.setProgress(100,1,True)
nb.OnGoingEvent = False
'1111111111111
Sub Activity_Resume
Sub Panel2_Click
Dim p As Panel
p=Sender
If File.Exists(File.DirRootExternal & "/MusicB4A",Label1.Text &".mp3") = True Then
' ToastMessageShow(name&".mp3"&TAB&"در مسیر حافظه کارت و پوشه musicB4a ذخیره شده است" ,True)
Dim dd As DownloadData
dd.url = p.Tag
dd.EventName = "dd"
dd.Target = Me
CallSubDelayed2(DownloadService, "StartDownload", dd )
Sub CheckBox1_CheckedChange(Checked As Boolean)
Sub btndownload_Click
ToastMessageShow(Label1.Text&".mp3"&TAB&"در مسیر حافظه کارت و پوشه musicB4a ذخیره شده است" ,True)
dd.url = Label1.Text
dd.EventName = "dd"
dd.Target = Me
CallSubDelayed2(DownloadService, "StartDownload", dd)
Sub dd_Progress(Progress As Long, Total As Long)
progssbardownload.Progress = Progress / Total * 100
labeldownload.Text = NumberFormat(Progress / 1024, 0, 0) & "KB / " & _
NumberFormat(Total / 1024, 0, 0) & "KB"
change( Progress / Total * 100 , labeldownload.Text )
Sub dd_Complete(Job As HttpJob)
Log("Job completed: " & Job.Success)
ToastMessageShow("مداحی" & Label1.Text &".mp3" ,True)
Dim o As OutputStream
o = File.OpenOutput(File.DirRootExternal & "/MusicB4A",Label1.Text &".mp3", False)
File.Copy2(Job.GetInputStream, o)
o.Close
Job.Release
Sub btnCancel_Click
progssbardownload.Progress=0
labeldownload.Text=""
CallSubDelayed2(DownloadService, "CancelDownload", link1)
StopService(HttpUtils2Service1)
StopService(DownloadService)
Sub change(darsad As Int,Text As String)
nb.ContentText = Text
nb.setProgress(100,darsad,False)
nb.Notify(1)
علی علایی 161
اینم کدهام
اینم سورسم
ممنون میشم راهنمایی ام کنید
با تشکر
28 پاسخ به این سوال تاکنون داده شده است
